Date/Time: Sun, 05 May 2024 13:13:17 +0000
Problem
View Count: 542
[2020-01-31 15:20:04] |
User675119 - Posts: 13 |
Hello, I have the following problem: I have a future account with Ninjatrader . Since I use Sierra chart for analysis I was paying for SC data with the professional rate. I was happy with SC data . I am not a professional trader so I did not want to pay the professional rate and so I opened a second future account with Cannon Trading ( Dorman FCM ). They set me up with CQG for data. But during this month it did disconnetted several times so I requested a change for market data. They suggested to activate the Denali data feed with CQG as order routing. But it supports only CME and I need also Eurex. So they suggested again CQG or tt. I would like to go back to SC data so my question is : is it possibile to have only one account with Ninjatrader and pay the non professional rate for using Sierra chart data only for analysis ? thank you for your help |
[2020-01-31 21:57:53] |
Sierra_Chart Engineering - Posts: 14232 |
Refer to the following program that is available to help you resolve this issue: Easy Solution to CME Funded Trading Account Requirement And then you can use the Sierra Chart Exchange Data Feed and get the Eurex and the CME at the lower rates. Refer to the information here: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
