Date/Time: Sat, 04 May 2024 01:28:56 +0000
Replay - Is it possible to reset/initialize studies as well?
View Count: 1844
[2014-01-04 20:16:15] |
ejtrader - Posts: 688 |
SC Team - At present I have few dependencies between charts and the data gets populated on multiple charts and gets shared between charts in a chartbook. They are all setup to use Proper precedence and uses few shared structures. However I am unable to use the replay feature properly on all charts at present as the study on master charts doesn't get reset and is aware of ALL the data till end of chart. If I do a manual reset - I would have to perform this reset on ALL charts in the chart book - which is really not an elegant solution and tedious task. Would it be possible to include a flag or some sort to "recalculate" all studies for all charts in chartbook as well as part of the replay option below? if this is not possible - Would you please let me know the way to force "recalculate" all studies and for all charts in a chartbook? I came across this keyword from a different thread - "sc.InternalFR = -17" but don't know how to make a call for this. Any example code? Thanks https://www.sierrachart.com/supportboard/showthread.php?t=40838 Date Time Of Last Edit: 2014-01-04 21:20:27
sc_replay_initialization.jpg / V - Attached On 2014-01-04 20:16:35 UTC - Size: 41.92 KB - 444 views |
[2014-01-06 23:47:04] |
There really is not a way to force a recalculate for all the charts in the Chartbook.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-06 23:47:16
[2014-01-06 23:51:54] |
Thanks SC team. I am aware of the fact that - you are not in favor of using "sc.InternalFR = -17". However for my little tricky situation and only for replay condition I would like to use this function. Would you please let me know how to make this call. As this would only be applicable in case of "replay" and not during LIVE - I am prepared to take this inefficient route for now - until I get a chance to re-design the pieces or can clear-up the shared structures cleanly. Thanks Date Time Of Last Edit: 2014-01-07 06:26:01
