Date/Time: Sat, 04 May 2024 10:20:12 +0000
Interested in real-time $VIX intraday data
View Count: 861
[2020-01-29 23:01:07] |
User272030 - Posts: 9 |
I'm a client of AMP Futures and paying for my Sierra Chart services thru them acting as my affiliate. I have currently activated thru them... *Sierra Chart - Service Package 5 *Sierra Chart - TT-W (FIX) SC-Denali Exchange Data Feed *Full CME Group With Market Depth for Non-Pro Accounts I want to add access to real-time $VIX data and have been reading about it through old support board posts, but still not clear on what I need to do. I understand that I need to activate access to the Sierra Chart Exchange Data Feed and CBOE Indices Exchange but don't see that as an option thru AMP (unless I switch data to CQG which I don't want to do). Do I just activate Sierra Chart Exchange Data Feed & CBOE Indices thru my AMP-provided Sierra Chart login & deposit the necessary funds to maintain a services balance and it will work seamlessly with what I already have working above? What's the best way to do this and be cost-effective while keeping Full CME Group with Market Depth and just adding real-time $VIX data. Thanks |
[2020-01-30 22:47:29] |
Just found another post where another user was told to cancel their Denali feed and then start the SC Exchange Feed. I can't cancel Denali from within my SC login because SC is provided by an affiliate though. Do I tell AMP to cancel my data subscriptions thru them and then I setup SC Exchange Data Feed within my SC account login provided by AMP?
[2020-01-31 09:08:37] |
For CBOE Indices, you would want to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed For more information about cash indices, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Cash Indexes This will also provide CME group data. Do I tell AMP to cancel my data subscriptions thru them and then I setup SC Exchange Data Feed within my SC account login provided by AMP? Yes this is correct.Do I just activate Sierra Chart Exchange Data Feed & CBOE Indices thru my AMP-provided Sierra Chart login & deposit the necessary funds to maintain a services balance and it will work seamlessly with what I already have working above?
This is correct as well.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-31 09:09:38
