Date/Time: Sun, 28 Apr 2024 06:34:50 +0000
Custom Study Distribution with Service Level
View Count: 666
[2020-01-24 21:51:54] |
jmt816 - Posts: 45 |
The User Control Panel for controlling distribution of custom ASCIL studies has a line called "Service Level", but none of the documentation re: IsUserAllowedForSCDLLName mentions how to utilize that. The sample in the documentation shows the test for being authorized as simply a test for true or false. The signature of IsUserAllowedForSCDLLName has a return value of int. Am I correct in interpreting that to mean that the value of a service level set on the control panel would be the return value of the call to IsUserAllowedForSCDLLName? If not, would appreciate some guidance in its correct usage (and update to the documentation either way). Thanks! |
[2020-01-24 23:30:02] |
Sierra_Chart Engineering - Posts: 14111 |
It sets the variable std::int64_t sc.DLLNameUserServiceLevel
[2020-01-24 23:42:47] |
thanks for the quick reply! May i suggest adding that to the documentation? the info at Advanced Custom Study Interface and Language (ACSIL): Redistributing and Allowing Use Only by a Defined List of Users mentions nothing, And now that i KNOW the right name to search for, a site search doesn't return any results. I do see a sample in Studies.cpp, but would not know to look there unless i knew what to look for, which was the problem to start off with. |
[2020-01-27 19:02:51] |
Documentation has been updated.
