Date/Time: Wed, 08 May 2024 22:19:32 +0000
Not a Valid Chartbook File
View Count: 1308
[2014-01-03 15:31:29] |
infpz - Posts: 826 |
I have the global settings to where once the program opens, several chartbooks open automatically. It worked fine this morning, but after logging off and back on again, half of the chartbooks wouldn't open. I then upgraded the charts and the same thing happened. Now after logging off and back on for the 5th time so far, none of the charts will open up. I can open up and create a new one and some older chartbooks can open, but all of my current ones that I want to use will not. The error log is attached.
chart log.jpg / V - Attached On 2014-01-03 15:31:23 UTC - Size: 520.68 KB - 384 views |
[2014-01-03 16:33:56] |
Most of the Chartbooks being opened do not exist according to the log. And one of them is not a valid Chartbook file. Seems like something went wrong with the files in your Data folder. The cause of this would be something outside of Sierra Chart. See if there are any backup Chartbooks files: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#BackupChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-04 07:41:27] |
We looked into this problem a little further. We do not see how Sierra Chart in any way would cause a Chartbook file to go missing. This would be impossible so there must be some external cause. We have seen cases where a Chartbook file becomes invalid because it consists of nothing but zeros. This would mean something went wrong during the saving process. When Sierra Chart saves the Chartbook, currently it tells the operating system to truncate the file and probably the operating system first sets the entire file to zeros. This is only a conclusion, we are not sure about this. And then the process of saving begins. This is a very reliable process and nothing should go wrong, but perhaps something is for some unknown reason. We have never seen a problem like us ourselves, but we have seen cases of it among users. There were some recent changes to safeguard against this kind of problem, the method of saving has changed to prevent the operating system from erasing the file at the beginning of the save process, but they were not properly implemented. So we are going to fix that particular issue. However, this will not cause a file to become deleted. Overall this kind of problem with saving a Chartbook would not be a Sierra Chart problem but something external causing a file not to save properly. Possibly even a bug in a custom study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-04 07:46:49
