Date/Time: Sun, 28 Apr 2024 12:41:01 +0000
Chart Value Tool as Default
View Count: 576
[2020-01-21 00:21:11] |
User389151 - Posts: 37 |
How to have this Chart Value Tool as my default? see attached. when i draw a line, i want the cursor to automatically turn to the Chart Value Tool. Thanks
CrosshairDefault.JPG / V - Attached On 2020-01-21 00:20:54 UTC - Size: 65.43 KB - 215 views |
[2020-01-21 07:05:02] |
Refer to: Chart Drawing Tools: After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
