Date/Time: Thu, 02 May 2024 02:46:15 +0000
Using Sierra Chart with Real Time Data without Order Routing
View Count: 909
[2020-01-13 18:50:36] |
FJG - Posts: 3 |
I'm a non-professional Thinkorswim NQ, ES, and CL futures trader that would like to use Sierra Charts with Real Time data due some specific features in Sierra Chart, however, I would like to continue to place my orders through Thinkorswin. Would I be able to use a real time data feed (such as Denali) to populate Sierra Chart and continue to use Thinkorswim to place my orders without an account with a TT compliant broker? If so, is there anything in particular that I will need to know to get set up with this configuration. If not, would you please explain why not? Thank you in advance.
[2020-01-13 20:21:01] |
SC Support - Posts: 1796 |
I can give you a call about this today if you have time, we can speak about options.
[2020-01-13 20:28:28] |
FJG - Posts: 3 |
Please do. Just added my phone number to my account. Thanks!
[2020-01-13 20:52:31] |
Spoke to the user, his current questions are answered.
Date Time Of Last Edit: 2020-01-13 20:52:40
[2020-01-13 21:40:07] |
What you can do for now is documented here: Easy Solution to CME Funded Trading Account Requirement We also want to make it clear, that this solution linked above is only for those who are considered nonprofessional by the CME. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
