Date/Time: Mon, 29 Apr 2024 22:55:12 +0000
TPO chart overlapping clean chart
View Count: 794
[2020-01-11 09:53:02] |
User442073 - Posts: 2 |
When i insert my TPO chart, it takes over the whole current clean chart screen, is there a way to have a TPO chart while also having a clean chart screen that interacts with each other. In other words, when i use crosshair for chart values, i should see that happening over on the clean chart aswell?
[2020-01-11 14:33:51] |
We are not clear what you are looking for exactly. But you cannot have standard chart bars on a chart with the TPO Profile Chart study.
[2020-01-11 20:37:38] |
My question is how can i minimize the TPO chart and draw lines on it that would appear automatically on the standard chart?
[2020-01-13 16:26:24] |
mtomas - Posts: 21 |
what about scaling the chart to reduce the size...go to the price scale and left click mouse and hold, move mouse up, this will reduce the chart height and compress it... is this what you are referring to?
[2020-01-13 17:01:37] |
In regards to post #3, refer to: Copying Chart Drawings from Other Charts Automatically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
