Date/Time: Sat, 04 May 2024 19:20:33 +0000
Euronext equities
View Count: 1365
[2020-02-17 21:57:07] |
stephane1 - Posts: 110 |
Here is... https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=35848 other thing: how quickly can you set up the connection in real time? regards !! |
ALDR.FP 1 Day #1 2020-02-17 22_47_08.124.png / V - Attached On 2020-02-17 21:49:14 UTC - Size: 47.03 KB - 357 views Attachment Deleted. |
[2020-02-18 18:07:37] |
These Intraday chart bars are set to 1 day per bar. Instead just open a standard Historical Daily chart for that symbol through File >> Find Symbol. You have to manually type in the symbol. You also need to understand bar starting times for Intraday charts: Chart Session Times: Bar Starting Times The real-time connection can be set up just in minutes. Instructions are here: Sierra Chart Exchange Data Feed: Setup Instructions If you need help just let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
