Date/Time: Wed, 15 May 2024 10:57:42 +0000
ESH0 Historical Chart
View Count: 548
[2020-01-07 23:54:48] |
User698423 - Posts: 3 |
I am using version AT 2029 32bit, and just recently been having issues with the ES historical chart. When I go to find symbol, and open the historical chart for ESH0, I look at the chart setting date range, which gives me a date from 12/19/2008 to current date. My chart shows me missing data from 3/19/2010 to 12/20/2018, which looks like a huge price gap on the chart. I never had this issue before, is there a problem with this version I'm using, it seem to happen when I upgraded, what would be the fix, also I would like to keep this or any 32bit version. Thanks!
ESH0 Daily #2 2020-01-07 18_36_22.486.png / V - Attached On 2020-01-07 23:51:43 UTC - Size: 27.5 KB - 248 views |
[2020-01-07 23:57:17] |
Follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
