Date/Time: Sat, 18 May 2024 10:41:54 +0000
US2000 symbol data
View Count: 766
[2020-01-06 23:17:18] |
User34124 - Posts: 271 |
I can only manage to get this back to 2018-11-20 ?
[2020-01-07 03:45:01] |
The data for this symbol starts at: 2018-11-19
[2020-01-07 10:33:35] |
Can you get more please, at least match the others similar symbols, US30 etc.. on a daily chart it looks ridiculous and it is an important index.
[2020-01-07 19:06:53] |
You will want to use this symbol instead: RTYH20 And then set the chart to a Continuous Futures Contract chart: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-07 19:07:11
[2020-01-08 11:39:53] |
Thanks but I am trading on FXCM via Sierra .. so would need a compatible feed? Also it says 'not available on this service' when I try to load anyway. I have also asked FXCM on their end to look into it, as I assume they supply the feed. |
[2020-01-08 14:42:34] |
We will make sure you have access to this symbol. Should be done in a couple of hours.
[2020-01-08 14:50:11] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You will now see the symbol listed in File >> Find Symbol >> Futures - CME. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-09 10:35:13] |
Thanks, but will I still be able to trade on this symbol as I can with 'US2000' Similarly, how do I get more data on SOYF or WHEATF (in the CFDs section, so the Continuous Futures Contract chart setting does not seem to work. N.b. Spoke to FXCM who confirmed their data only goes back to 6 months previous to launching US2000 ... they are looking into increasing the data they hold as I explained it is a deterrent to trading via them when my other providers have 10+ years of data available. Date Time Of Last Edit: 2020-01-09 12:46:31
[2020-01-09 13:45:54] |
There is limited historical data for some of these CFDs. There just is not more historical data available.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-09 13:46:01
