Date/Time: Mon, 06 May 2024 10:33:43 +0000
NISS-NYSE Adjusted Cumulative Value
View Count: 832
[2020-01-06 18:36:34] |
Dan the Man - Posts: 82 |
Hi Support, I'm hoping you can help. I'm attempting to duplicate your Overlay OHLC of Adjusted Cumulative Value chart Sierra Chart Market Statistics: Market Statistics Calculations Compared to Other Data Services I just want the Adjusted Cumulative Value applied to Sierra Charts NISS-NYSE. The only study I can find is "Cumulative Adjusted Value" and it cannot be plotted as a OHLC bar, as per your chart. Please see the attached screen shots. 1) Your Overlay OHLC of Adjusted Cumulative Value chart plotted as a OHLC bar 2) My chart plotted as a candle stick because there is no OHLC bar option (that I can find). Thank-you |
[2020-01-07 18:53:56] |
To create the Open, High, Low, Close bars, requires that you use this study : Study Overlay - OHLC (Open, High, Low, Close) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-02 22:07:00] |
bebop - Posts: 13 |
Hi Support, I´m trying to produce the Adjusted Cumulative Tick that you showed as an OHLC bar, but there´s something I just don´t understand. When I use the Cumulative Adjusted Value study - the input is a single value and it produces a single value. How can I then use the Study Overlay OHLC to produce an OHLC bar with this data? What step am I missing? Thanks in advance for your help! |
[2021-06-03 02:02:31] |
Sierra_Chart Engineering - Posts: 14239 |
You need to follow the documentation for this study here: Study Overlay - OHLC (Open, High, Low, Close) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
