Date/Time: Tue, 14 May 2024 20:49:06 +0000
Data connection
View Count: 847
[2020-01-06 16:20:23] |
User813017 - Posts: 4 |
Am new to Sierra. Using Rithmic 01-US. Keep getting connection error messsage from service: Rithmic Trading/Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. Note: Rithmic bridge needs installing. Download keeps being redirected.
[2020-01-06 17:03:39] |
Run the Sierra Chart installer following these instructions: Software Download: Fast Update And enable the option to Install Optional Components. We also recommend switching to this service especially if you are with AMP since it is very well supported by them : Sierra Chart / Trading Technologies Futures Order Routing Service Since we have discontinued support for Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-06 17:03:56
