Date/Time: Wed, 15 May 2024 16:03:50 +0000
New User - Trading ES/ZB and Stocks
View Count: 968
[2020-01-06 02:34:09] |
kinobi - Posts: 15 |
I am in the US and currently using TradeStation but I need some functionality present in SC I'm still trying to figure this out as a new user: A - if I trade ES/ZB and stocks/options would Interactive Brokers be the best option?. I need a full integration with DOM etc. If so, what data package I would need? (planning to use SC#5 functionality ) B - if I were to trade ES/ZB/ZN only, what data package/broker would be suggested for full integration? Thank you Date Time Of Last Edit: 2020-01-06 03:13:29
[2020-01-06 12:34:33] |
bump
[2020-01-06 16:24:03] |
You will certainly need to use Interactive Brokers for stocks and stock option trading. For futures trading you can use this service which is supported by many clearing firms: Sierra Chart / Trading Technologies Futures Order Routing Service In either case it sounds like you just need the Standard service package: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-06 16:43:32] |
If I were to limit to Futures only, which broker has the best integration with your software? would IB be on par with others?
[2020-01-06 16:53:37] |
The broker is your choice. The only thing we would recommend is this service is the best integration: Sierra Chart / Trading Technologies Futures Order Routing Service The most common brokers for this service are going to be AMP and Dorman. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
