Date/Time: Sat, 18 May 2024 08:43:52 +0000
spreadsheet limitation
View Count: 588
[2020-01-04 16:10:56] |
LucentTrader - Posts: 35 |
Are spreadsheets limited to 200 rows? Having added 500 instruments to a quote sheet quotes stop at row 201.
[2020-01-04 16:22:04] |
We will check on this and increase the limit.
[2020-01-04 17:10:32] |
Inserting a column formulas do not update for modified references. Is this by design?
[2020-01-06 04:53:08] |
The number of quote rows has been increased to 1000. This will be out in the next release. In regards to the question at post #3, refer to: Working with Spreadsheets: Inserting and Deleting Rows and Columns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
