Date/Time: Sat, 18 May 2024 11:37:02 +0000
Demo with TT & Sierrachart
View Count: 839
[2020-01-03 14:47:15] |
User344042 - Posts: 41 |
Hello SC, As the problem of my Chartbook is still pending regarding its optimization at your side, I asked yesterday TT a demo account to use their Datafeed with SC_v1915 32bit as this version is running fine with my Chartbook. I asked them the configuration to connect and they answered this : ------------------------------------------- Molly McMahonYesterday 2:05 PMLatest Hello, Sierra Chart is not currently set up to receive prices via TT FIX. If you can please reach out to them, they should be able to help you get configured for a data feed. Regards, Molly ----- Can you please help to connect |
Private File |
[2020-01-03 22:31:15] |
We do not support the TT data feed directly. You need to use one of these data feeds instead: Real-Time Exchange Data Feeds Available From Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
