Date/Time: Sat, 18 May 2024 00:08:39 +0000
Real Time Data Connection
View Count: 541
[2020-01-02 21:38:17] |
flowtra8r - Posts: 10 |
Since TD is not being supported by Sierra, I need to get live data through someone else. I have account with Tradestation if you support them.
[2020-01-02 22:10:26] |
We can see that TD Ameritrade is still allowing the connection. So as of the moment nothing has changed. You can continue to use TD Ameritrade. If you want real-time futures data, then reactivate the Denali Exchange Data Feed: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-02 22:10:43
[2020-04-01 17:14:55] |
Due to changes by Ameritrade, this is no longer possible and is a major development effort and ongoing support effort to support the new TD Ameritrade API. We have developed this easy solution: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
