Date/Time: Sat, 18 May 2024 08:23:42 +0000
I pay SC for data, I use ToS with funded account. What now?
View Count: 1075
[2020-01-02 20:05:12] |
JDMontero - Posts: 34 |
I pay SC for data, I use ToS with funded account. What now? I am not getting live data. Please advise with patience, this is all very confusing. Regards JDM |
[2020-01-03 04:25:27] |
At this point use the Denali Exchange Data Feed. Instructions are on this page: Denali Exchange Data Feed You can still use your TD Ameritrade account to authorize the CME data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-08 15:50:52] |
Is there a way to go back to 2027 version? I made the update when it was not known that TD would keep the API. I don't have the time right now to sit and do the lengthy Denali and small funded account thing so I'm looking for the alternatives. |
[2020-01-08 16:47:32] |
SC Support - Posts: 1801 |
Hi there JDMontero, do you have time to speak about this today?
[2020-01-08 17:07:58] |
Yes follow the instructions here to go back to an earlier version: Software Download: Software Rollback Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-08 17:08:06
[2020-01-08 21:50:35] |
ok I rolled back, now how do I get the live data? Thanks. |
[2020-01-08 22:52:17] |
If you just require CME group data, then therefore you will want to use the new Denali exchange: Denali Exchange Data Feed You currently do not have any Sierra Chart exchange data feed active. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-08 22:52:36
