Date/Time: Sun, 19 May 2024 05:43:11 +0000
Intra Candle Data Collection
View Count: 690
[2019-12-27 15:08:29] |
SirK - Posts: 16 |
I was wondering if during replay it is possible to pause the replay and take a snapshot of the data at that moment across multiple time charts? For example if if i have a 30, 60, and 240 charts up in a chart book and i pause during a replay am i able to get a data output file that tells me direction/value of the studies i am using at that time/point i paused instead of only posted data? Thanks, |
[2019-12-29 22:14:28] |
If you are replaying a chart and then pause it you can then use the command Edit >> Export Bar and Study Data to Text File. The resulting file will have the most recent information for the current bar. Refer to the following for how to use this command: Edit Menu: Edit >> Export Bar and Study Data to Text File You can also monitor for the replay status in ACSIL and take whatever action you want in the study function: ACSIL Interface Members - Variables and Arrays: sc.ReplayStatus Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-29 22:14:51
[2019-12-29 23:06:34] |
SirK - Posts: 16 |
That is pretty close to what i need. Is there a way for it to include data from other time charts in the same chartbook? If not i can use an overlay study. Also, the file that is created includes all previous posted data is there a way to make it so it only shows current candle, ie the candle i pause on? If not i can work around that. Thanks for your help! |
[2019-12-29 23:22:39] |
SirK - Posts: 16 |
Ok, looks like overlay data isn't included when i export. so that option wont work. any other options for me to get multiple time frames data other than running the export on each time chart? Thanks |
[2019-12-30 04:14:22] |
You really just have to develop a custom solution for this using ACSIL to accomplish what you need which includes writing to a file what you need. Refer to: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-30 04:14:47
