Date/Time: Sat, 18 May 2024 14:45:15 +0000
waiting to download historical data
View Count: 668
[2019-12-24 15:15:29] |
anguskywong - Posts: 5 |
When I started HSX19 or HSF20 chart, it took over 1 hour to download the data, which is unacceptable.
Date Time Of Last Edit: 2019-12-24 15:22:33
[2019-12-25 15:54:01] |
This must be an issue with the Internet connection. However, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance This data should have been downloaded in a matter of seconds. Here is an example: HD Request # 16 | Received 3243093 records from 2019-09-29 21:19:10.000 to 2019-11-28 02:59:58.000 (59.3 days) and wrote 3243093 records for HSX19 | 2019-12-25 10:54:54.331 So the transfer of 3,000,000 records in four seconds.HD Request # 16 | Completion time: 4s | 2019-12-25 10:54:54.335 HD Request # 16 | Intraday data download complete for HSX19. Unique request ID: 17 | 2019-12-25 10:54:54.335 Maybe try using port 80: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Using Port 80 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-25 15:56:50
[2019-12-26 02:11:00] |
You are right. Solved. Thank you.
