Date/Time: Sat, 18 May 2024 14:10:30 +0000
Decoupling New Instances
View Count: 517
[2019-12-23 14:57:16] |
ycomp - Posts: 277 |
I have a main Sierra Chart instance I also created a new instance before using the New Instance command. So it is in a subfolder of the main instance. Now I would like to move the new instance to another computer. Can I just move its entire folder to a new computer? It won't affect the new instance or the original instance if I do this? |
[2019-12-23 17:22:08] |
Yes you can move the entire folder. That is not a problem. If you want to change the Data Files Folder you can do that: General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) It will not affect the main instance in any way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
