Date/Time: Sat, 18 May 2024 17:03:51 +0000
unable to connect
View Count: 562
[2019-12-23 09:49:29] |
User298588 - Posts: 19 |
Reading Internal Order ID file. | 2019-12-23 09:37:25.886 Reading Trade Orders file. | 2019-12-23 09:37:25.971 Reading Trade Positions file. | 2019-12-23 09:37:25.971 Reading Account Balance file. | 2019-12-23 09:37:25.972 UDPListener (1204). Port 22904 | Listening on UDP port 22904. | 2019-12-23 09:37:25.990 Software version: 2028 64-bit | 2019-12-23 09:37:25.990 Usage end date: 2020-01-06 | 2019-12-23 09:37:25.990 Enabled for: Sierra Chart Historical Data Service. | 2019-12-23 09:37:25.990 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-12-23 09:37:25.990 Current selected Data/Trading service: Rithmic Trading | 2019-12-23 09:37:25.990 Custom symbol settings values: enabled | 2019-12-23 09:37:25.990 Chart Update Interval: 500 | 2019-12-23 09:37:25.990 Intraday Data Storage Time Unit: 1 | 2019-12-23 09:37:25.990 Time Zone: +00:00:00 (UTC+00) | 2019-12-23 09:37:25.990 2019-12-23 17:37:25 Local computer time | 2019-12-23 09:37:25.990 2019-12-23 09:37:25 Local computer time in UTC | 2019-12-23 09:37:25.990 2019-12-23 09:37:25 Local computer time in SC Time Zone | 2019-12-23 09:37:25.990 2019-12-23 09:37:24 Server time in UTC | 2019-12-23 09:37:25.990 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-12-23 09:37:25.990 Program path: C:\SierraChart\ | 2019-12-23 09:37:25.990 Data Files path: C:\SierraChart\Data\ | 2019-12-23 09:37:25.990 OS Version Number: 10.0 | 2019-12-23 09:37:25.991 Locale Setting: C | 2019-12-23 09:37:25.991 DLLs: UserContributedStudies_64.dll | 2019-12-23 09:37:25.991 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2019-12-23 09:37:26.010 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-12-23 09:37:26.055 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-12-23 09:37:26.055 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-12-23 09:37:26.055 Received 5 login tokens. | 2019-12-23 09:37:27.304 Symbol settings MD5 received. Request ID: 1. | 2019-12-23 09:37:27.494 Symbol settings are up-to-date for rithmic.trading. | 2019-12-23 09:37:27.494 Files to Open on Start up | Opening file: ExampleChartbook.cht | 2019-12-23 09:37:30.171 Rithmic Trading | Port for executable: 54752 | 2019-12-23 09:37:32.194 Listening socket (984). Port 54752 | Closed. | 2019-12-23 09:37:32.194 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:37:32.195 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54752. Current folder: C:\SierraChart\Rim | 2019-12-23 09:37:32.227 Rithmic Trading | Bridge process is running. | 2019-12-23 09:37:34.200 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54752 | 2019-12-23 09:37:34.200 DTC Client socket (1) | Creating socket. | 2019-12-23 09:37:34.201 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:37:34.201 Rithmic Trading | Connected to server. | 2019-12-23 09:37:34.205 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:37:34.205 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:37:34.205 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:37:34.209 Rithmic Trading | Sending logon request message. | 2019-12-23 09:37:34.209 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:37:34.213 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:37:34.219 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:37:34.219 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:37:37.629 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:37:57.327 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:37:57.328 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:37:57.328 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-12-23 09:37:57.328 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:37:57.328 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:37:57.328 DTC Client socket (1) | Closed. | 2019-12-23 09:37:57.328 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:37:57.330 Rithmic Trading | Disconnected. | 2019-12-23 09:37:57.331 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:37:57.331 Rithmic Trading | Port for executable: 54779 | 2019-12-23 09:37:59.350 Listening socket (1012). Port 54779 | Closed. | 2019-12-23 09:37:59.350 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:37:59.352 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54779. Current folder: C:\SierraChart\Rim | 2019-12-23 09:37:59.385 Rithmic Trading | Bridge process is running. | 2019-12-23 09:38:01.373 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54779 | 2019-12-23 09:38:01.373 DTC Client socket (1) | Creating socket. | 2019-12-23 09:38:01.373 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:38:01.373 Rithmic Trading | Connected to server. | 2019-12-23 09:38:01.375 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:38:01.375 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:38:01.375 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:38:01.375 Rithmic Trading | Sending logon request message. | 2019-12-23 09:38:01.375 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:38:01.377 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:38:01.378 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:38:01.378 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:38:04.795 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:38:24.490 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:38:24.490 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:38:24.490 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-12-23 09:38:24.490 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:38:24.490 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:24.490 DTC Client socket (1) | Closed. | 2019-12-23 09:38:24.490 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:38:24.509 Rithmic Trading | Disconnected. | 2019-12-23 09:38:24.509 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:24.509 Rithmic Trading | Port for executable: 54808 | 2019-12-23 09:38:26.509 Listening socket (1384). Port 54808 | Closed. | 2019-12-23 09:38:26.509 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:38:26.510 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54808. Current folder: C:\SierraChart\Rim | 2019-12-23 09:38:26.542 Rithmic Trading | Bridge process is running. | 2019-12-23 09:38:28.536 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54808 | 2019-12-23 09:38:28.536 DTC Client socket (1) | Creating socket. | 2019-12-23 09:38:28.536 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:38:28.536 Rithmic Trading | Connected to server. | 2019-12-23 09:38:28.538 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:38:28.538 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:38:28.538 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:38:28.540 Rithmic Trading | Sending logon request message. | 2019-12-23 09:38:28.540 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:38:28.540 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:38:28.541 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:38:28.541 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:38:32.206 Rithmic Trading | Received logon response. | 2019-12-23 09:38:32.207 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:38:32.207 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:38:32.207 Rithmic Trading | Logon error received from server | 2019-12-23 09:38:32.207 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:38:32.207 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:32.207 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:38:32.224 Rithmic Trading | Disconnected. | 2019-12-23 09:38:32.224 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:32.224 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-23 09:38:32.224 Rithmic Trading | Port for executable: 54844 | 2019-12-23 09:38:34.221 Listening socket (1376). Port 54844 | Closed. | 2019-12-23 09:38:34.221 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:38:34.222 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54844. Current folder: C:\SierraChart\Rim | 2019-12-23 09:38:34.253 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:38:36.244 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54844 | 2019-12-23 09:38:36.244 DTC Client socket (2) | Creating socket. | 2019-12-23 09:38:36.244 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:38:36.244 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:38:37.274 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:38:37.274 DTC Client socket (2) | Closed. | 2019-12-23 09:38:37.274 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:38:37.274 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:37.274 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:38:37.284 Rithmic Trading | Disconnected. | 2019-12-23 09:38:37.284 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:37.284 Rithmic Trading | Port for executable: 54852 | 2019-12-23 09:38:39.300 Listening socket (1012). Port 54852 | Closed. | 2019-12-23 09:38:39.300 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:38:39.304 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54852. Current folder: C:\SierraChart\Rim | 2019-12-23 09:38:39.339 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:38:41.336 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54852 | 2019-12-23 09:38:41.336 DTC Client socket (2) | Creating socket. | 2019-12-23 09:38:41.336 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:38:41.336 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:38:42.360 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:38:42.364 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:38:42.364 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:42.364 DTC Client socket (2) | Closed. | 2019-12-23 09:38:42.364 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:38:42.376 Rithmic Trading | Disconnected. | 2019-12-23 09:38:42.376 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:42.376 Rithmic Trading | Port for executable: 54858 | 2019-12-23 09:38:44.378 Listening socket (1040). Port 54858 | Closed. | 2019-12-23 09:38:44.378 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:38:44.379 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54858. Current folder: C:\SierraChart\Rim | 2019-12-23 09:38:44.411 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:38:46.405 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54858 | 2019-12-23 09:38:46.405 DTC Client socket (2) | Creating socket. | 2019-12-23 09:38:46.405 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:38:46.405 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:38:47.421 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:38:47.421 DTC Client socket (2) | Closed. | 2019-12-23 09:38:47.421 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:38:47.422 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:47.422 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:38:47.436 Rithmic Trading | Disconnected. | 2019-12-23 09:38:47.436 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:47.436 Rithmic Trading | Port for executable: 54863 | 2019-12-23 09:38:49.445 Listening socket (1012). Port 54863 | Closed. | 2019-12-23 09:38:49.445 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:38:49.446 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54863. Current folder: C:\SierraChart\Rim | 2019-12-23 09:38:49.479 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:38:51.462 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54863 | 2019-12-23 09:38:51.462 DTC Client socket (2) | Creating socket. | 2019-12-23 09:38:51.462 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:38:51.462 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:38:51.656 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:38:51.656 DTC Client socket (1) | Closed. | 2019-12-23 09:38:51.656 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:38:52.489 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:38:52.490 DTC Client socket (2) | Closed. | 2019-12-23 09:38:52.490 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:38:52.490 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:52.490 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:38:52.505 Rithmic Trading | Disconnected. | 2019-12-23 09:38:52.506 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:38:52.506 Rithmic Trading | Port for executable: 54872 | 2019-12-23 09:38:54.507 Listening socket (1040). Port 54872 | Closed. | 2019-12-23 09:38:54.507 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:38:54.507 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54872. Current folder: C:\SierraChart\Rim | 2019-12-23 09:38:54.538 Rithmic Trading | Bridge process is running. | 2019-12-23 09:38:56.537 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54872 | 2019-12-23 09:38:56.537 DTC Client socket (1) | Creating socket. | 2019-12-23 09:38:56.537 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:38:56.537 Rithmic Trading | Connected to server. | 2019-12-23 09:38:56.539 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:38:56.539 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:38:56.539 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:38:56.540 Rithmic Trading | Sending logon request message. | 2019-12-23 09:38:56.540 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:38:56.541 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:38:56.542 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:38:56.542 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:39:00.007 Rithmic Trading | Received logon response. | 2019-12-23 09:39:00.009 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:39:00.009 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:39:00.009 Rithmic Trading | Logon error received from server | 2019-12-23 09:39:00.009 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:00.009 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:00.009 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:39:00.014 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-23 09:39:00.014 Rithmic Trading | Disconnected. | 2019-12-23 09:39:00.014 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:00.014 Rithmic Trading | Port for executable: 54914 | 2019-12-23 09:39:02.028 Listening socket (1356). Port 54914 | Closed. | 2019-12-23 09:39:02.028 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:02.029 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54914. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:02.078 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:39:04.062 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54914 | 2019-12-23 09:39:04.062 DTC Client socket (2) | Creating socket. | 2019-12-23 09:39:04.062 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:04.062 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:39:05.080 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:39:05.081 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:05.081 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:05.081 DTC Client socket (2) | Closed. | 2019-12-23 09:39:05.081 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:39:05.096 Rithmic Trading | Disconnected. | 2019-12-23 09:39:05.097 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:05.097 Rithmic Trading | Port for executable: 54924 | 2019-12-23 09:39:07.111 Listening socket (1032). Port 54924 | Closed. | 2019-12-23 09:39:07.111 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:07.112 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54924. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:07.142 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:39:09.148 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54924 | 2019-12-23 09:39:09.148 DTC Client socket (2) | Creating socket. | 2019-12-23 09:39:09.148 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:09.148 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:39:10.166 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:39:10.167 DTC Client socket (2) | Closed. | 2019-12-23 09:39:10.167 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:10.167 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:10.167 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:39:10.181 Rithmic Trading | Disconnected. | 2019-12-23 09:39:10.181 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:10.181 Rithmic Trading | Port for executable: 54929 | 2019-12-23 09:39:12.173 Listening socket (1356). Port 54929 | Closed. | 2019-12-23 09:39:12.173 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:12.174 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54929. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:12.205 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:39:14.205 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54929 | 2019-12-23 09:39:14.205 DTC Client socket (2) | Creating socket. | 2019-12-23 09:39:14.205 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:14.205 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:39:15.245 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:39:15.245 DTC Client socket (2) | Closed. | 2019-12-23 09:39:15.245 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:15.246 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:15.246 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:39:15.261 Rithmic Trading | Disconnected. | 2019-12-23 09:39:15.261 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:15.261 Rithmic Trading | Port for executable: 54937 | 2019-12-23 09:39:17.257 Listening socket (1356). Port 54937 | Closed. | 2019-12-23 09:39:17.257 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:17.258 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54937. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:17.291 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:39:19.282 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54937 | 2019-12-23 09:39:19.282 DTC Client socket (2) | Creating socket. | 2019-12-23 09:39:19.282 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:19.282 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:39:19.648 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:39:19.648 DTC Client socket (1) | Closed. | 2019-12-23 09:39:19.648 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:39:20.290 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:39:20.290 DTC Client socket (2) | Closed. | 2019-12-23 09:39:20.290 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:20.291 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:20.291 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:39:20.306 Rithmic Trading | Disconnected. | 2019-12-23 09:39:20.307 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:20.307 Rithmic Trading | Port for executable: 54939 | 2019-12-23 09:39:22.298 Listening socket (1356). Port 54939 | Closed. | 2019-12-23 09:39:22.298 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:22.298 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54939. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:22.330 Rithmic Trading | Bridge process is running. | 2019-12-23 09:39:24.334 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54939 | 2019-12-23 09:39:24.334 DTC Client socket (1) | Creating socket. | 2019-12-23 09:39:24.334 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:24.334 Rithmic Trading | Connected to server. | 2019-12-23 09:39:24.335 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:39:24.335 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:39:24.336 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:39:24.336 Rithmic Trading | Sending logon request message. | 2019-12-23 09:39:24.336 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:39:24.337 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:39:24.338 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:39:24.338 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:39:27.634 Rithmic Trading | Received logon response. | 2019-12-23 09:39:27.636 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:39:27.636 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:39:27.636 Rithmic Trading | Logon error received from server | 2019-12-23 09:39:27.636 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:27.636 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:27.636 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:39:27.674 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-23 09:39:27.674 Rithmic Trading | Disconnected. | 2019-12-23 09:39:27.674 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:27.674 Rithmic Trading | Port for executable: 54968 | 2019-12-23 09:39:29.685 Listening socket (1356). Port 54968 | Closed. | 2019-12-23 09:39:29.685 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:29.686 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54968. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:29.717 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:39:31.704 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54968 | 2019-12-23 09:39:31.704 DTC Client socket (2) | Creating socket. | 2019-12-23 09:39:31.704 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:31.704 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:39:32.721 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:39:32.721 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:32.721 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:32.721 DTC Client socket (2) | Closed. | 2019-12-23 09:39:32.721 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:39:32.733 Rithmic Trading | Disconnected. | 2019-12-23 09:39:32.734 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:32.734 Rithmic Trading | Port for executable: 54971 | 2019-12-23 09:39:34.745 Listening socket (1356). Port 54971 | Closed. | 2019-12-23 09:39:34.745 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:34.746 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54971. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:34.777 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:39:36.764 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54971 | 2019-12-23 09:39:36.764 DTC Client socket (2) | Creating socket. | 2019-12-23 09:39:36.764 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:36.764 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:39:37.772 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:39:37.772 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:37.772 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:37.772 DTC Client socket (2) | Closed. | 2019-12-23 09:39:37.772 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:39:37.779 Rithmic Trading | Disconnected. | 2019-12-23 09:39:37.779 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:37.779 Rithmic Trading | Port for executable: 54990 | 2019-12-23 09:39:39.808 Listening socket (968). Port 54990 | Closed. | 2019-12-23 09:39:39.808 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:39.809 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54990. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:39.845 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:39:41.825 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54990 | 2019-12-23 09:39:41.825 DTC Client socket (2) | Creating socket. | 2019-12-23 09:39:41.825 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:41.825 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:39:42.843 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:39:42.843 DTC Client socket (2) | Closed. | 2019-12-23 09:39:42.843 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:42.843 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:42.843 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:39:42.858 Rithmic Trading | Disconnected. | 2019-12-23 09:39:42.858 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:42.858 Rithmic Trading | Port for executable: 55009 | 2019-12-23 09:39:44.860 Listening socket (1040). Port 55009 | Closed. | 2019-12-23 09:39:44.860 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:44.860 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55009. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:44.898 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:39:46.877 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55009 | 2019-12-23 09:39:46.877 DTC Client socket (2) | Creating socket. | 2019-12-23 09:39:46.877 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:46.878 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:39:47.441 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:39:47.441 DTC Client socket (1) | Closed. | 2019-12-23 09:39:47.441 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:39:47.893 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:39:47.893 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:47.893 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:47.893 DTC Client socket (2) | Closed. | 2019-12-23 09:39:47.893 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:39:47.905 Rithmic Trading | Disconnected. | 2019-12-23 09:39:47.906 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:47.906 Rithmic Trading | Port for executable: 55017 | 2019-12-23 09:39:49.918 Listening socket (1356). Port 55017 | Closed. | 2019-12-23 09:39:49.918 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:49.919 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55017. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:49.950 Rithmic Trading | Bridge process is running. | 2019-12-23 09:39:51.942 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55017 | 2019-12-23 09:39:51.942 DTC Client socket (1) | Creating socket. | 2019-12-23 09:39:51.942 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:51.942 Rithmic Trading | Connected to server. | 2019-12-23 09:39:51.946 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:39:51.946 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:39:51.946 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:39:51.948 Rithmic Trading | Sending logon request message. | 2019-12-23 09:39:51.948 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:39:51.949 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:39:51.950 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:39:51.950 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:39:55.242 Rithmic Trading | Received logon response. | 2019-12-23 09:39:55.246 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:39:55.246 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:39:55.246 Rithmic Trading | Logon error received from server | 2019-12-23 09:39:55.246 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:39:55.246 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:55.246 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:39:55.258 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-23 09:39:55.258 Rithmic Trading | Disconnected. | 2019-12-23 09:39:55.259 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:39:55.260 Rithmic Trading | Port for executable: 55055 | 2019-12-23 09:39:57.265 Listening socket (1420). Port 55055 | Closed. | 2019-12-23 09:39:57.265 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:39:57.265 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55055. Current folder: C:\SierraChart\Rim | 2019-12-23 09:39:57.304 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:39:59.299 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55055 | 2019-12-23 09:39:59.299 DTC Client socket (2) | Creating socket. | 2019-12-23 09:39:59.299 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:39:59.299 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:40:00.301 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:40:00.302 DTC Client socket (2) | Closed. | 2019-12-23 09:40:00.302 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:40:00.302 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:00.302 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:40:00.324 Rithmic Trading | Disconnected. | 2019-12-23 09:40:00.325 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:00.325 Rithmic Trading | Port for executable: 55065 | 2019-12-23 09:40:02.316 Listening socket (1412). Port 55065 | Closed. | 2019-12-23 09:40:02.316 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:40:02.316 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55065. Current folder: C:\SierraChart\Rim | 2019-12-23 09:40:02.349 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:40:04.354 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55065 | 2019-12-23 09:40:04.354 DTC Client socket (2) | Creating socket. | 2019-12-23 09:40:04.354 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:40:04.354 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:40:05.371 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:40:05.372 DTC Client socket (2) | Closed. | 2019-12-23 09:40:05.372 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:40:05.372 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:05.372 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:40:05.387 Rithmic Trading | Disconnected. | 2019-12-23 09:40:05.388 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:05.388 Rithmic Trading | Port for executable: 55074 | 2019-12-23 09:40:07.377 Listening socket (1420). Port 55074 | Closed. | 2019-12-23 09:40:07.377 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:40:07.378 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55074. Current folder: C:\SierraChart\Rim | 2019-12-23 09:40:07.412 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:40:09.413 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55074 | 2019-12-23 09:40:09.413 DTC Client socket (2) | Creating socket. | 2019-12-23 09:40:09.413 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:40:09.414 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:40:10.431 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:40:10.431 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:40:10.431 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:10.431 DTC Client socket (2) | Closed. | 2019-12-23 09:40:10.431 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:40:10.441 Rithmic Trading | Disconnected. | 2019-12-23 09:40:10.441 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:10.442 Rithmic Trading | Port for executable: 55076 | 2019-12-23 09:40:12.441 Listening socket (1412). Port 55076 | Closed. | 2019-12-23 09:40:12.441 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:40:12.442 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55076. Current folder: C:\SierraChart\Rim | 2019-12-23 09:40:12.472 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:40:14.474 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55076 | 2019-12-23 09:40:14.474 DTC Client socket (2) | Creating socket. | 2019-12-23 09:40:14.475 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:40:14.475 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:40:15.049 DTC Client socket (1) | Closed. | 2019-12-23 09:40:15.049 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:40:15.499 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:40:15.500 DTC Client socket (2) | Closed. | 2019-12-23 09:40:15.500 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:40:15.501 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:15.501 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:40:15.515 Rithmic Trading | Disconnected. | 2019-12-23 09:40:15.515 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:15.516 Rithmic Trading | Port for executable: 55078 | 2019-12-23 09:40:17.516 Listening socket (1420). Port 55078 | Closed. | 2019-12-23 09:40:17.516 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:40:17.517 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55078. Current folder: C:\SierraChart\Rim | 2019-12-23 09:40:17.548 Rithmic Trading | Bridge process is running. | 2019-12-23 09:40:19.544 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55078 | 2019-12-23 09:40:19.544 DTC Client socket (1) | Creating socket. | 2019-12-23 09:40:19.544 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:40:19.544 Rithmic Trading | Connected to server. | 2019-12-23 09:40:19.548 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:40:19.548 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:40:19.548 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:40:19.549 Rithmic Trading | Sending logon request message. | 2019-12-23 09:40:19.549 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:40:19.550 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:40:19.551 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:40:19.551 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:40:23.826 Rithmic Trading | Received logon response. | 2019-12-23 09:40:23.827 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:40:23.827 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:40:23.827 Rithmic Trading | Logon error received from server | 2019-12-23 09:40:23.827 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:40:23.827 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:23.827 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:40:23.827 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:40:23.828 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-12-23 09:40:23.828 DTC Client socket (1) | Closed. | 2019-12-23 09:40:23.828 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:40:23.860 Rithmic Trading | Disconnected. | 2019-12-23 09:40:23.860 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:23.860 Rithmic Trading | Port for executable: 55107 | 2019-12-23 09:40:25.866 Listening socket (1412). Port 55107 | Closed. | 2019-12-23 09:40:25.866 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:40:25.867 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55107. Current folder: C:\SierraChart\Rim | 2019-12-23 09:40:25.900 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:40:27.894 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55107 | 2019-12-23 09:40:27.894 DTC Client socket (1) | Creating socket. | 2019-12-23 09:40:27.894 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:40:27.894 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:40:28.897 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:40:28.898 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:40:28.898 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:28.898 DTC Client socket (1) | Closed. | 2019-12-23 09:40:28.898 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:40:28.904 Rithmic Trading | Disconnected. | 2019-12-23 09:40:28.905 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:28.905 Rithmic Trading | Port for executable: 55109 | 2019-12-23 09:40:30.913 Listening socket (1420). Port 55109 | Closed. | 2019-12-23 09:40:30.913 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:40:30.914 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55109. Current folder: C:\SierraChart\Rim | 2019-12-23 09:40:30.945 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:40:32.940 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55109 | 2019-12-23 09:40:32.940 DTC Client socket (1) | Creating socket. | 2019-12-23 09:40:32.940 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:40:32.940 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:40:33.949 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:40:33.949 DTC Client socket (1) | Closed. | 2019-12-23 09:40:33.949 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:40:33.949 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:33.949 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:40:33.961 Rithmic Trading | Disconnected. | 2019-12-23 09:40:33.961 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:33.962 Rithmic Trading | Port for executable: 55112 | 2019-12-23 09:40:35.962 Listening socket (956). Port 55112 | Closed. | 2019-12-23 09:40:35.962 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:40:35.962 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55112. Current folder: C:\SierraChart\Rim | 2019-12-23 09:40:35.994 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:40:37.985 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55112 | 2019-12-23 09:40:37.985 DTC Client socket (1) | Creating socket. | 2019-12-23 09:40:37.985 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:40:37.985 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:40:38.988 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:40:38.989 DTC Client socket (1) | Closed. | 2019-12-23 09:40:38.989 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:40:38.990 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:38.990 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:40:39.004 Rithmic Trading | Disconnected. | 2019-12-23 09:40:39.004 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:39.005 Rithmic Trading | Port for executable: 55114 | 2019-12-23 09:40:41.001 Listening socket (972). Port 55114 | Closed. | 2019-12-23 09:40:41.001 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:40:41.001 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55114. Current folder: C:\SierraChart\Rim | 2019-12-23 09:40:41.032 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:40:43.028 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55114 | 2019-12-23 09:40:43.028 DTC Client socket (1) | Creating socket. | 2019-12-23 09:40:43.028 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:40:43.028 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:40:44.034 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:40:44.034 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:40:44.034 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:44.034 DTC Client socket (1) | Closed. | 2019-12-23 09:40:44.034 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:40:44.050 Rithmic Trading | Disconnected. | 2019-12-23 09:40:44.050 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:44.051 Rithmic Trading | Port for executable: 55122 | 2019-12-23 09:40:46.063 Listening socket (956). Port 55122 | Closed. | 2019-12-23 09:40:46.063 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:40:46.063 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55122. Current folder: C:\SierraChart\Rim | 2019-12-23 09:40:46.100 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:40:48.099 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55122 | 2019-12-23 09:40:48.099 DTC Client socket (1) | Creating socket. | 2019-12-23 09:40:48.099 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:40:48.099 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:40:49.116 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:40:49.117 DTC Client socket (1) | Closed. | 2019-12-23 09:40:49.117 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:40:49.117 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:49.117 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:40:49.133 Rithmic Trading | Disconnected. | 2019-12-23 09:40:49.134 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:40:49.134 Rithmic Trading | Port for executable: 55124 | 2019-12-23 09:40:51.142 Listening socket (1012). Port 55124 | Closed. | 2019-12-23 09:40:51.142 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:40:51.143 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55124. Current folder: C:\SierraChart\Rim | 2019-12-23 09:40:51.176 Rithmic Trading | Bridge process is running. | 2019-12-23 09:40:53.177 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55124 | 2019-12-23 09:40:53.177 DTC Client socket (1) | Creating socket. | 2019-12-23 09:40:53.177 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:40:53.177 Rithmic Trading | Connected to server. | 2019-12-23 09:40:53.181 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:40:53.181 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:40:53.181 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:40:53.183 Rithmic Trading | Sending logon request message. | 2019-12-23 09:40:53.183 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:40:53.185 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:40:53.187 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:40:53.187 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:41:00.600 Rithmic Trading | Received logon response. | 2019-12-23 09:41:00.602 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:41:00.602 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:41:00.602 Rithmic Trading | Logon error received from server | 2019-12-23 09:41:00.602 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:41:00.602 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:00.602 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:41:00.624 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-23 09:41:00.624 Rithmic Trading | Disconnected. | 2019-12-23 09:41:00.625 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:00.626 Rithmic Trading | Port for executable: 55153 | 2019-12-23 09:41:02.611 Listening socket (1012). Port 55153 | Closed. | 2019-12-23 09:41:02.611 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:41:02.612 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55153. Current folder: C:\SierraChart\Rim | 2019-12-23 09:41:02.647 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:41:04.644 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55153 | 2019-12-23 09:41:04.644 DTC Client socket (2) | Creating socket. | 2019-12-23 09:41:04.644 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:41:04.645 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:41:05.656 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:41:05.657 DTC Client socket (2) | Closed. | 2019-12-23 09:41:05.658 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:41:05.659 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:05.659 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:41:05.672 Rithmic Trading | Disconnected. | 2019-12-23 09:41:05.672 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:05.672 Rithmic Trading | Port for executable: 55155 | 2019-12-23 09:41:07.672 Listening socket (1032). Port 55155 | Closed. | 2019-12-23 09:41:07.672 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:41:07.673 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55155. Current folder: C:\SierraChart\Rim | 2019-12-23 09:41:07.703 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:41:09.714 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55155 | 2019-12-23 09:41:09.714 DTC Client socket (2) | Creating socket. | 2019-12-23 09:41:09.714 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:41:09.715 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:41:10.732 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:41:10.732 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:41:10.732 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:10.732 DTC Client socket (2) | Closed. | 2019-12-23 09:41:10.732 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:41:10.755 Rithmic Trading | Disconnected. | 2019-12-23 09:41:10.755 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:10.755 Rithmic Trading | Port for executable: 55157 | 2019-12-23 09:41:12.753 Listening socket (1380). Port 55157 | Closed. | 2019-12-23 09:41:12.753 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:41:12.753 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55157. Current folder: C:\SierraChart\Rim | 2019-12-23 09:41:12.787 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:41:14.785 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55157 | 2019-12-23 09:41:14.785 DTC Client socket (2) | Creating socket. | 2019-12-23 09:41:14.785 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:41:14.785 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:41:15.787 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:41:15.787 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:41:15.787 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:15.787 DTC Client socket (2) | Closed. | 2019-12-23 09:41:15.788 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:41:15.803 Rithmic Trading | Disconnected. | 2019-12-23 09:41:15.804 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:15.804 Rithmic Trading | Port for executable: 55162 | 2019-12-23 09:41:17.798 Listening socket (972). Port 55162 | Closed. | 2019-12-23 09:41:17.798 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:41:17.798 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55162. Current folder: C:\SierraChart\Rim | 2019-12-23 09:41:17.830 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:41:19.830 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55162 | 2019-12-23 09:41:19.830 DTC Client socket (2) | Creating socket. | 2019-12-23 09:41:19.830 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:41:19.830 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:41:20.846 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:41:20.847 DTC Client socket (2) | Closed. | 2019-12-23 09:41:20.847 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:41:20.847 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:20.847 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:41:20.863 Rithmic Trading | Disconnected. | 2019-12-23 09:41:20.864 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:20.865 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:41:21.290 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:41:21.290 DTC Client socket (1) | Closed. | 2019-12-23 09:41:21.290 Rithmic Trading | Port for executable: 55164 | 2019-12-23 09:41:22.860 Listening socket (968). Port 55164 | Closed. | 2019-12-23 09:41:22.860 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:41:22.860 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55164. Current folder: C:\SierraChart\Rim | 2019-12-23 09:41:22.897 Rithmic Trading | Bridge process is running. | 2019-12-23 09:41:24.899 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55164 | 2019-12-23 09:41:24.899 DTC Client socket (1) | Creating socket. | 2019-12-23 09:41:24.899 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:41:24.899 Rithmic Trading | Connected to server. | 2019-12-23 09:41:24.900 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:41:24.900 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:41:24.900 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:41:24.901 Rithmic Trading | Sending logon request message. | 2019-12-23 09:41:24.901 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:41:24.902 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:41:24.904 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:41:24.904 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:41:28.739 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:41:47.956 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:41:47.956 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:41:47.956 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-12-23 09:41:47.956 DTC Client socket (1) | Closed. | 2019-12-23 09:41:47.956 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:41:47.956 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:47.956 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:41:47.967 Rithmic Trading | Disconnected. | 2019-12-23 09:41:47.967 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:47.967 Rithmic Trading | Port for executable: 55194 | 2019-12-23 09:41:49.978 Listening socket (1392). Port 55194 | Closed. | 2019-12-23 09:41:49.979 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:41:49.982 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55194. Current folder: C:\SierraChart\Rim | 2019-12-23 09:41:50.013 Rithmic Trading | Bridge process is running. | 2019-12-23 09:41:52.006 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55194 | 2019-12-23 09:41:52.006 DTC Client socket (1) | Creating socket. | 2019-12-23 09:41:52.006 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:41:52.007 Rithmic Trading | Connected to server. | 2019-12-23 09:41:52.008 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:41:52.008 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:41:52.008 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:41:52.009 Rithmic Trading | Sending logon request message. | 2019-12-23 09:41:52.009 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:41:52.010 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:41:52.011 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:41:52.011 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:41:55.517 Rithmic Trading | Received logon response. | 2019-12-23 09:41:55.520 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:41:55.520 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:41:55.520 Rithmic Trading | Logon error received from server | 2019-12-23 09:41:55.520 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:41:55.520 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:55.520 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:41:55.532 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-23 09:41:55.532 Rithmic Trading | Disconnected. | 2019-12-23 09:41:55.532 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:41:55.532 Rithmic Trading | Port for executable: 55220 | 2019-12-23 09:41:57.532 Listening socket (1408). Port 55220 | Closed. | 2019-12-23 09:41:57.532 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:41:57.532 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55220. Current folder: C:\SierraChart\Rim | 2019-12-23 09:41:57.581 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:41:59.579 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55220 | 2019-12-23 09:41:59.579 DTC Client socket (2) | Creating socket. | 2019-12-23 09:41:59.579 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:41:59.579 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:42:00.598 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:42:00.599 DTC Client socket (2) | Closed. | 2019-12-23 09:42:00.599 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:00.600 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:00.600 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:42:00.615 Rithmic Trading | Disconnected. | 2019-12-23 09:42:00.615 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:00.615 Rithmic Trading | Port for executable: 55224 | 2019-12-23 09:42:02.612 Listening socket (1356). Port 55224 | Closed. | 2019-12-23 09:42:02.612 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:02.612 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55224. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:02.645 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:42:04.642 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55224 | 2019-12-23 09:42:04.642 DTC Client socket (2) | Creating socket. | 2019-12-23 09:42:04.642 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:04.642 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:42:05.660 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:42:05.660 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:05.660 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:05.660 DTC Client socket (2) | Closed. | 2019-12-23 09:42:05.660 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:42:05.676 Rithmic Trading | Disconnected. | 2019-12-23 09:42:05.676 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:05.676 Rithmic Trading | Port for executable: 55226 | 2019-12-23 09:42:07.682 Listening socket (1632). Port 55226 | Closed. | 2019-12-23 09:42:07.682 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:07.684 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55226. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:07.714 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:42:09.703 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55226 | 2019-12-23 09:42:09.703 DTC Client socket (2) | Creating socket. | 2019-12-23 09:42:09.703 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:09.703 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:42:10.705 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:42:10.705 DTC Client socket (2) | Closed. | 2019-12-23 09:42:10.705 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:10.706 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:10.706 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:42:10.727 Rithmic Trading | Disconnected. | 2019-12-23 09:42:10.728 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:10.728 Rithmic Trading | Port for executable: 55228 | 2019-12-23 09:42:12.719 Listening socket (1640). Port 55228 | Closed. | 2019-12-23 09:42:12.719 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:12.720 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55228. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:12.750 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:42:14.746 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55228 | 2019-12-23 09:42:14.746 DTC Client socket (2) | Creating socket. | 2019-12-23 09:42:14.746 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:14.747 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:42:15.142 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:42:15.142 DTC Client socket (1) | Closed. | 2019-12-23 09:42:15.142 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:42:15.752 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:42:15.752 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:15.752 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:15.752 DTC Client socket (2) | Closed. | 2019-12-23 09:42:15.752 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:42:15.768 Rithmic Trading | Disconnected. | 2019-12-23 09:42:15.768 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:15.768 Rithmic Trading | Port for executable: 55230 | 2019-12-23 09:42:17.772 Listening socket (1632). Port 55230 | Closed. | 2019-12-23 09:42:17.772 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:17.773 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55230. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:17.804 Rithmic Trading | Bridge process is running. | 2019-12-23 09:42:19.802 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55230 | 2019-12-23 09:42:19.802 DTC Client socket (1) | Creating socket. | 2019-12-23 09:42:19.802 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:19.802 Rithmic Trading | Connected to server. | 2019-12-23 09:42:19.808 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:42:19.808 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:42:19.808 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:42:19.811 Rithmic Trading | Sending logon request message. | 2019-12-23 09:42:19.811 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:42:19.812 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:42:19.813 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:42:19.813 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:42:23.151 Rithmic Trading | Received logon response. | 2019-12-23 09:42:23.151 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:42:23.151 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:42:23.151 Rithmic Trading | Logon error received from server | 2019-12-23 09:42:23.151 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:23.151 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:23.151 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:42:23.166 Rithmic Trading | Disconnected. | 2019-12-23 09:42:23.166 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:23.166 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-23 09:42:23.166 Rithmic Trading | Port for executable: 55258 | 2019-12-23 09:42:25.159 Listening socket (1632). Port 55258 | Closed. | 2019-12-23 09:42:25.159 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:25.160 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55258. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:25.196 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:42:27.193 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55258 | 2019-12-23 09:42:27.193 DTC Client socket (2) | Creating socket. | 2019-12-23 09:42:27.193 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:27.193 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:42:28.199 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:42:28.200 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:28.200 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:28.200 DTC Client socket (2) | Closed. | 2019-12-23 09:42:28.200 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:42:28.215 Rithmic Trading | Disconnected. | 2019-12-23 09:42:28.216 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:28.216 Rithmic Trading | Port for executable: 55263 | 2019-12-23 09:42:30.210 Listening socket (1636). Port 55263 | Closed. | 2019-12-23 09:42:30.210 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:30.211 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55263. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:30.244 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:42:32.241 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55263 | 2019-12-23 09:42:32.241 DTC Client socket (2) | Creating socket. | 2019-12-23 09:42:32.241 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:32.241 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:42:33.245 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:42:33.246 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:33.246 DTC Client socket (2) | Closed. | 2019-12-23 09:42:33.246 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:33.246 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:42:33.253 Rithmic Trading | Disconnected. | 2019-12-23 09:42:33.253 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:33.253 Rithmic Trading | Port for executable: 55266 | 2019-12-23 09:42:35.258 Listening socket (1632). Port 55266 | Closed. | 2019-12-23 09:42:35.258 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:35.258 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55266. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:35.292 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:42:37.280 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55266 | 2019-12-23 09:42:37.280 DTC Client socket (2) | Creating socket. | 2019-12-23 09:42:37.280 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:37.280 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:42:38.295 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:42:38.296 DTC Client socket (2) | Closed. | 2019-12-23 09:42:38.296 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:38.296 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:38.296 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:42:38.312 Rithmic Trading | Disconnected. | 2019-12-23 09:42:38.312 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:38.312 Rithmic Trading | Port for executable: 55268 | 2019-12-23 09:42:40.321 Listening socket (1636). Port 55268 | Closed. | 2019-12-23 09:42:40.321 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:40.321 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55268. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:40.354 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:42:42.352 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55268 | 2019-12-23 09:42:42.352 DTC Client socket (2) | Creating socket. | 2019-12-23 09:42:42.352 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:42.352 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:42:42.865 DTC Client socket (1) | Closed. | 2019-12-23 09:42:42.865 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:42:43.355 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:42:43.355 DTC Client socket (2) | Closed. | 2019-12-23 09:42:43.356 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:43.356 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:43.356 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:42:43.371 Rithmic Trading | Disconnected. | 2019-12-23 09:42:43.371 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:43.371 Rithmic Trading | Port for executable: 55270 | 2019-12-23 09:42:45.364 Listening socket (1644). Port 55270 | Closed. | 2019-12-23 09:42:45.364 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:45.364 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55270. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:45.397 Rithmic Trading | Bridge process is running. | 2019-12-23 09:42:47.377 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55270 | 2019-12-23 09:42:47.377 DTC Client socket (1) | Creating socket. | 2019-12-23 09:42:47.377 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:47.377 Rithmic Trading | Connected to server. | 2019-12-23 09:42:47.382 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:42:47.382 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:42:47.382 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:42:47.385 Rithmic Trading | Sending logon request message. | 2019-12-23 09:42:47.385 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:42:47.388 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:42:47.401 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:42:47.401 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:42:50.769 Rithmic Trading | Received logon response. | 2019-12-23 09:42:50.772 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:42:50.772 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:42:50.772 Rithmic Trading | Logon error received from server | 2019-12-23 09:42:50.772 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:50.772 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:50.772 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:42:50.785 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-23 09:42:50.786 Rithmic Trading | Disconnected. | 2019-12-23 09:42:50.786 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:50.786 Rithmic Trading | Port for executable: 55301 | 2019-12-23 09:42:52.785 Listening socket (1644). Port 55301 | Closed. | 2019-12-23 09:42:52.785 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:52.785 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55301. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:52.815 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:42:54.831 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55301 | 2019-12-23 09:42:54.831 DTC Client socket (2) | Creating socket. | 2019-12-23 09:42:54.831 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:54.831 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:42:55.853 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:42:55.854 DTC Client socket (2) | Closed. | 2019-12-23 09:42:55.854 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:42:55.854 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:55.854 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:42:55.870 Rithmic Trading | Disconnected. | 2019-12-23 09:42:55.871 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:42:55.871 Rithmic Trading | Port for executable: 55303 | 2019-12-23 09:42:57.867 Listening socket (1636). Port 55303 | Closed. | 2019-12-23 09:42:57.867 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:42:57.868 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55303. Current folder: C:\SierraChart\Rim | 2019-12-23 09:42:57.898 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:42:59.896 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55303 | 2019-12-23 09:42:59.896 DTC Client socket (2) | Creating socket. | 2019-12-23 09:42:59.896 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:42:59.896 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:43:00.900 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:43:00.901 DTC Client socket (2) | Closed. | 2019-12-23 09:43:00.901 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:43:00.901 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:00.901 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:43:00.915 Rithmic Trading | Disconnected. | 2019-12-23 09:43:00.915 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:00.916 Rithmic Trading | Port for executable: 55305 | 2019-12-23 09:43:02.904 Listening socket (1636). Port 55305 | Closed. | 2019-12-23 09:43:02.904 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:43:02.905 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55305. Current folder: C:\SierraChart\Rim | 2019-12-23 09:43:02.936 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:43:04.944 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55305 | 2019-12-23 09:43:04.944 DTC Client socket (2) | Creating socket. | 2019-12-23 09:43:04.944 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:43:04.945 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:43:05.973 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:43:05.973 DTC Client socket (2) | Closed. | 2019-12-23 09:43:05.974 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:43:05.974 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:05.974 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:43:05.989 Rithmic Trading | Disconnected. | 2019-12-23 09:43:05.989 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:05.989 Rithmic Trading | Port for executable: 55307 | 2019-12-23 09:43:07.987 Listening socket (1656). Port 55307 | Closed. | 2019-12-23 09:43:07.987 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:43:07.988 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55307. Current folder: C:\SierraChart\Rim | 2019-12-23 09:43:08.020 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:43:10.028 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55307 | 2019-12-23 09:43:10.028 DTC Client socket (2) | Creating socket. | 2019-12-23 09:43:10.028 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:43:10.028 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:43:10.522 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:43:10.523 DTC Client socket (1) | Closed. | 2019-12-23 09:43:10.523 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:43:11.046 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:43:11.047 DTC Client socket (2) | Closed. | 2019-12-23 09:43:11.047 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:43:11.048 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:11.048 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:43:11.062 Rithmic Trading | Disconnected. | 2019-12-23 09:43:11.063 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:11.063 Rithmic Trading | Port for executable: 55309 | 2019-12-23 09:43:13.065 Listening socket (1636). Port 55309 | Closed. | 2019-12-23 09:43:13.065 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:43:13.066 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55309. Current folder: C:\SierraChart\Rim | 2019-12-23 09:43:13.099 Rithmic Trading | Bridge process is running. | 2019-12-23 09:43:15.078 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55309 | 2019-12-23 09:43:15.078 DTC Client socket (1) | Creating socket. | 2019-12-23 09:43:15.078 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:43:15.078 Rithmic Trading | Connected to server. | 2019-12-23 09:43:15.079 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:43:15.079 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:43:15.079 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:43:15.080 Rithmic Trading | Sending logon request message. | 2019-12-23 09:43:15.080 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:43:15.081 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:43:15.083 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:43:15.083 Service is currently connecting. | 2019-12-23 09:43:17.724 * Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:43:18.639 Rithmic Trading | Received logon response. | 2019-12-23 09:43:18.640 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:43:18.640 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:43:18.640 Rithmic Trading | Logon error received from server | 2019-12-23 09:43:18.640 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:43:18.640 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:18.640 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:43:18.640 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:43:18.658 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-12-23 09:43:18.658 DTC Client socket (1) | Closed. | 2019-12-23 09:43:18.658 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:43:18.661 Rithmic Trading | Disconnected. | 2019-12-23 09:43:18.661 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:18.661 File >> Disconnect selected. | 2019-12-23 09:43:36.202 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:43:36.202 Rithmic Trading | Disconnected. | 2019-12-23 09:43:36.202 Rithmic Trading | Port for executable: 55346 | 2019-12-23 09:43:37.929 Listening socket (1636). Port 55346 | Closed. | 2019-12-23 09:43:37.929 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:43:37.930 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55346. Current folder: C:\SierraChart\Rim | 2019-12-23 09:43:37.960 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:43:39.961 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55346 | 2019-12-23 09:43:39.961 DTC Client socket (1) | Creating socket. | 2019-12-23 09:43:39.961 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:43:39.961 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:43:40.975 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:43:40.976 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:43:40.976 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:40.976 DTC Client socket (1) | Closed. | 2019-12-23 09:43:40.976 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:43:40.986 Rithmic Trading | Disconnected. | 2019-12-23 09:43:40.986 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:40.986 Rithmic Trading | Port for executable: 55348 | 2019-12-23 09:43:42.985 Listening socket (1680). Port 55348 | Closed. | 2019-12-23 09:43:42.985 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:43:42.986 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55348. Current folder: C:\SierraChart\Rim | 2019-12-23 09:43:43.018 Rithmic Trading | Bridge process is running. | 2019-12-23 09:43:45.016 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55348 | 2019-12-23 09:43:45.016 DTC Client socket (1) | Creating socket. | 2019-12-23 09:43:45.016 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:43:45.016 Rithmic Trading | Connected to server. | 2019-12-23 09:43:45.018 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:43:45.018 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:43:45.018 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:43:45.019 Rithmic Trading | Sending logon request message. | 2019-12-23 09:43:45.019 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:43:45.020 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:43:45.021 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:43:45.021 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:43:48.447 Rithmic Trading | Received logon response. | 2019-12-23 09:43:48.447 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:43:48.447 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:43:48.447 Rithmic Trading | Logon error received from server | 2019-12-23 09:43:48.447 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:43:48.447 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:48.447 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:43:48.448 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:43:48.470 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-12-23 09:43:48.470 DTC Client socket (1) | Closed. | 2019-12-23 09:43:48.471 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:43:48.473 Rithmic Trading | Disconnected. | 2019-12-23 09:43:48.473 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:48.473 Rithmic Trading | Port for executable: 55374 | 2019-12-23 09:43:50.458 Listening socket (1656). Port 55374 | Closed. | 2019-12-23 09:43:50.458 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:43:50.459 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55374. Current folder: C:\SierraChart\Rim | 2019-12-23 09:43:50.490 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:43:52.487 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55374 | 2019-12-23 09:43:52.487 DTC Client socket (1) | Creating socket. | 2019-12-23 09:43:52.487 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:43:52.487 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:43:53.489 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:43:53.490 DTC Client socket (1) | Closed. | 2019-12-23 09:43:53.490 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:43:53.490 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:53.490 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:43:53.505 Rithmic Trading | Disconnected. | 2019-12-23 09:43:53.505 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:53.506 Rithmic Trading | Port for executable: 55376 | 2019-12-23 09:43:55.514 Listening socket (1668). Port 55376 | Closed. | 2019-12-23 09:43:55.514 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:43:55.514 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55376. Current folder: C:\SierraChart\Rim | 2019-12-23 09:43:55.546 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:43:57.529 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55376 | 2019-12-23 09:43:57.529 DTC Client socket (1) | Creating socket. | 2019-12-23 09:43:57.530 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:43:57.530 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:43:58.530 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:43:58.531 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:43:58.531 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:58.531 DTC Client socket (1) | Closed. | 2019-12-23 09:43:58.531 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:43:58.549 Rithmic Trading | Disconnected. | 2019-12-23 09:43:58.549 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:43:58.550 Rithmic Trading | Port for executable: 55378 | 2019-12-23 09:44:00.548 Listening socket (1656). Port 55378 | Closed. | 2019-12-23 09:44:00.548 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:44:00.549 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55378. Current folder: C:\SierraChart\Rim | 2019-12-23 09:44:00.580 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:44:02.563 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55378 | 2019-12-23 09:44:02.563 DTC Client socket (1) | Creating socket. | 2019-12-23 09:44:02.564 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:44:02.564 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:44:03.576 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:44:03.577 DTC Client socket (1) | Closed. | 2019-12-23 09:44:03.577 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:44:03.578 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:03.578 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:44:03.592 Rithmic Trading | Disconnected. | 2019-12-23 09:44:03.592 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:03.592 Rithmic Trading | Port for executable: 55380 | 2019-12-23 09:44:05.600 Listening socket (1668). Port 55380 | Closed. | 2019-12-23 09:44:05.600 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:44:05.601 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55380. Current folder: C:\SierraChart\Rim | 2019-12-23 09:44:05.633 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:44:07.624 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55380 | 2019-12-23 09:44:07.624 DTC Client socket (1) | Creating socket. | 2019-12-23 09:44:07.624 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:44:07.624 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:44:08.638 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:44:08.639 DTC Client socket (1) | Closed. | 2019-12-23 09:44:08.639 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:44:08.640 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:08.640 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:44:08.654 Rithmic Trading | Disconnected. | 2019-12-23 09:44:08.654 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:08.655 Rithmic Trading | Port for executable: 55382 | 2019-12-23 09:44:10.666 Listening socket (1640). Port 55382 | Closed. | 2019-12-23 09:44:10.666 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:44:10.666 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55382. Current folder: C:\SierraChart\Rim | 2019-12-23 09:44:10.697 Rithmic Trading | Bridge process is running. | 2019-12-23 09:44:12.685 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55382 | 2019-12-23 09:44:12.685 DTC Client socket (1) | Creating socket. | 2019-12-23 09:44:12.685 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:44:12.685 Rithmic Trading | Connected to server. | 2019-12-23 09:44:12.686 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:44:12.686 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:44:12.686 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:44:12.687 Rithmic Trading | Sending logon request message. | 2019-12-23 09:44:12.687 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:44:12.688 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:44:12.689 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:44:12.689 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:44:16.110 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:44:35.814 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:44:35.814 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:44:35.814 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-12-23 09:44:35.814 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:44:35.814 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:35.814 DTC Client socket (1) | Closed. | 2019-12-23 09:44:35.814 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:44:35.821 Rithmic Trading | Disconnected. | 2019-12-23 09:44:35.821 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:35.821 Rithmic Trading | Port for executable: 55424 | 2019-12-23 09:44:37.814 Listening socket (1356). Port 55424 | Closed. | 2019-12-23 09:44:37.814 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:44:37.814 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55424. Current folder: C:\SierraChart\Rim | 2019-12-23 09:44:37.849 Rithmic Trading | Bridge process is running. | 2019-12-23 09:44:39.849 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55424 | 2019-12-23 09:44:39.849 DTC Client socket (1) | Creating socket. | 2019-12-23 09:44:39.849 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:44:39.849 Rithmic Trading | Connected to server. | 2019-12-23 09:44:39.850 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:44:39.850 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:44:39.850 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:44:39.851 Rithmic Trading | Sending logon request message. | 2019-12-23 09:44:39.851 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:44:39.852 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:44:39.853 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:44:39.853 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:44:43.311 Rithmic Trading | Received logon response. | 2019-12-23 09:44:43.312 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:44:43.312 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:44:43.312 Rithmic Trading | Logon error received from server | 2019-12-23 09:44:43.312 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:44:43.312 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:43.312 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:44:43.312 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:44:43.313 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-12-23 09:44:43.313 DTC Client socket (1) | Closed. | 2019-12-23 09:44:43.313 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:44:43.330 Rithmic Trading | Disconnected. | 2019-12-23 09:44:43.334 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:43.334 Rithmic Trading | Port for executable: 55450 | 2019-12-23 09:44:45.342 Listening socket (1680). Port 55450 | Closed. | 2019-12-23 09:44:45.342 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:44:45.342 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55450. Current folder: C:\SierraChart\Rim | 2019-12-23 09:44:45.375 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:44:47.367 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55450 | 2019-12-23 09:44:47.367 DTC Client socket (1) | Creating socket. | 2019-12-23 09:44:47.368 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:44:47.368 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:44:48.371 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:44:48.371 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:44:48.371 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:48.371 DTC Client socket (1) | Closed. | 2019-12-23 09:44:48.371 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:44:48.394 Rithmic Trading | Disconnected. | 2019-12-23 09:44:48.394 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:48.394 Rithmic Trading | Port for executable: 55455 | 2019-12-23 09:44:50.403 Listening socket (1356). Port 55455 | Closed. | 2019-12-23 09:44:50.403 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:44:50.404 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55455. Current folder: C:\SierraChart\Rim | 2019-12-23 09:44:50.440 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:44:52.421 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55455 | 2019-12-23 09:44:52.421 DTC Client socket (1) | Creating socket. | 2019-12-23 09:44:52.421 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:44:52.421 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:44:53.430 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:44:53.431 DTC Client socket (1) | Closed. | 2019-12-23 09:44:53.431 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:44:53.431 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:53.431 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:44:53.446 Rithmic Trading | Disconnected. | 2019-12-23 09:44:53.447 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:53.447 Rithmic Trading | Port for executable: 55458 | 2019-12-23 09:44:55.447 Listening socket (1680). Port 55458 | Closed. | 2019-12-23 09:44:55.447 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:44:55.448 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55458. Current folder: C:\SierraChart\Rim | 2019-12-23 09:44:55.482 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:44:57.468 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55458 | 2019-12-23 09:44:57.468 DTC Client socket (1) | Creating socket. | 2019-12-23 09:44:57.468 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:44:57.468 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:44:58.473 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:44:58.473 DTC Client socket (1) | Closed. | 2019-12-23 09:44:58.474 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:44:58.474 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:58.474 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:44:58.489 Rithmic Trading | Disconnected. | 2019-12-23 09:44:58.489 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:44:58.489 Rithmic Trading | Port for executable: 55460 | 2019-12-23 09:45:00.498 Listening socket (1356). Port 55460 | Closed. | 2019-12-23 09:45:00.498 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:45:00.498 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55460. Current folder: C:\SierraChart\Rim | 2019-12-23 09:45:00.532 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:45:02.514 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55460 | 2019-12-23 09:45:02.514 DTC Client socket (1) | Creating socket. | 2019-12-23 09:45:02.515 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:45:02.515 DTC Client socket (1) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:45:03.543 * DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:45:03.544 DTC Client socket (1) | Closed. | 2019-12-23 09:45:03.544 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:45:03.545 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:45:03.545 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:45:03.559 Rithmic Trading | Disconnected. | 2019-12-23 09:45:03.560 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:45:03.560 Rithmic Trading | Port for executable: 55462 | 2019-12-23 09:45:05.567 Listening socket (1676). Port 55462 | Closed. | 2019-12-23 09:45:05.567 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:45:05.567 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55462. Current folder: C:\SierraChart\Rim | 2019-12-23 09:45:05.597 Rithmic Trading | Bridge process is running. | 2019-12-23 09:45:07.595 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55462 | 2019-12-23 09:45:07.595 DTC Client socket (1) | Creating socket. | 2019-12-23 09:45:07.595 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:45:07.595 Rithmic Trading | Connected to server. | 2019-12-23 09:45:07.597 Rithmic Trading | Starting socket receive thread. | 2019-12-23 09:45:07.597 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-23 09:45:07.597 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-23 09:45:07.599 Rithmic Trading | Sending logon request message. | 2019-12-23 09:45:07.599 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-23 09:45:07.600 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-23 09:45:07.600 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-23 09:45:07.600 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:45:10.917 Rithmic Trading | Received logon response. | 2019-12-23 09:45:10.918 Rithmic Trading | Server Name: DTC Bridge. | 2019-12-23 09:45:10.918 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-23 09:45:10.918 Rithmic Trading | Logon error received from server | 2019-12-23 09:45:10.918 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:45:10.918 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:45:10.918 DTC Client socket (1) | CloseSocket call. | 2019-12-23 09:45:10.932 Rithmic Trading | Disconnected. | 2019-12-23 09:45:10.932 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:45:10.932 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-23 09:45:10.932 Rithmic Trading | Port for executable: 55488 | 2019-12-23 09:45:12.923 Listening socket (1728). Port 55488 | Closed. | 2019-12-23 09:45:12.923 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:45:12.925 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55488. Current folder: C:\SierraChart\Rim | 2019-12-23 09:45:12.958 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:45:14.950 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55488 | 2019-12-23 09:45:14.950 DTC Client socket (2) | Creating socket. | 2019-12-23 09:45:14.950 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:45:14.950 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:45:15.952 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:45:15.952 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:45:15.952 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:45:15.952 DTC Client socket (2) | Closed. | 2019-12-23 09:45:15.952 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:45:15.968 Rithmic Trading | Disconnected. | 2019-12-23 09:45:15.968 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:45:15.968 Rithmic Trading | Port for executable: 55490 | 2019-12-23 09:45:17.974 Listening socket (1656). Port 55490 | Closed. | 2019-12-23 09:45:17.974 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:45:17.974 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55490. Current folder: C:\SierraChart\Rim | 2019-12-23 09:45:18.007 Rithmic Trading | Bridge process is not running! | 2019-12-23 09:45:20.001 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55490 | 2019-12-23 09:45:20.001 DTC Client socket (2) | Creating socket. | 2019-12-23 09:45:20.001 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-23 09:45:20.001 DTC Client socket (2) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2019-12-23 09:45:21.020 * DTC Client socket (2) | CloseSocket call. | 2019-12-23 09:45:21.021 DTC Client socket (2) | Closed. | 2019-12-23 09:45:21.021 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-23 09:45:21.021 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:45:21.021 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:45:21.036 Rithmic Trading | Disconnected. | 2019-12-23 09:45:21.037 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-23 09:45:21.038 Rithmic Trading | Port for executable: 55512 | 2019-12-23 09:45:23.037 Listening socket (1728). Port 55512 | Closed. | 2019-12-23 09:45:23.037 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-23 09:45:23.037 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55512. Current folder: C:\SierraChart\Rim | 2019-12-23 09:45:23.068 File >> Disconnect selected. | 2019-12-23 09:45:23.431 DTC Client socket (0) | CloseSocket call. | 2019-12-23 09:45:23.431 Rithmic Trading | Disconnected. | 2019-12-23 09:45:23.431 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-12-23 09:45:30.740 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-23 09:45:30.740 DTC Client socket (1) | Closed. | 2019-12-23 09:45:30.741 please check |
[2019-12-23 14:02:49] |
This is a Rithmic software error: Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-12-23 09:44:16.110 This is not something we are able to help with. Do you use Rithmic for Live trading? If so we recommend changing to this service: Sierra Chart / Trading Technologies Futures Order Routing Service We can help you with this, if you let us know who your clearing firm is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
