Date/Time: Mon, 13 May 2024 22:06:22 +0000
Hand Tool horizontal dragging
View Count: 1137
[2019-12-20 18:03:32] |
daniel kao - Posts: 3 |
Hi, I use the handtool to drag to see previous price action on my candle price charts, but when dragging left the screen always shifts up and down according to the price movement. is there a way that i can drag it horizontally without the bars shifting up and down, just purely horizontally? thanks |
[2019-12-20 18:42:25] |
Yes. Refer to the documentation here about this: Chart Drawing Tools: Hand However, maybe you are using a Constant Range scale. You will want to use an Automatic scale: Chart Scale and Scale Adjusting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
