Date/Time: Sat, 18 May 2024 22:27:08 +0000
32/64 bit Custom studies
View Count: 527
[2019-12-17 07:30:20] |
User41512 - Posts: 58 |
Hi per your message that "after 15th Jan 2020 Sierra Chart will no longer be providing a 32 bit version". Can you please confirm that if my PC already runs on a 64 bit operating system,all of my custom Studies will automatically be running as 64 bit versions, and therefore will not be impacted by the 15th January deadline. Alternatively, Is there a way to check each individual study to see if it is a 32 bit version or 64 bit. Thks Date Time Of Last Edit: 2019-12-17 08:49:03
[2019-12-17 14:02:08] |
The first thing to do is to go to Help >> About and see if you are running the 32-bit or 64-bit version. If you are running the 64-bit version you are all set. The 64-bit custom studies are contained in DLLs which end with _64.DLL and are contained within the Data Files Folder: General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-17 14:03:34
