Date/Time: Sat, 18 May 2024 21:37:46 +0000
Footprint
View Count: 1320
[2019-12-16 16:39:00] |
User232042 - Posts: 35 |
Hello, I have footprint candles setup with deltas & what not. It looks fine and accurate for a 30m candle, but if I try, for example, a 3 day candle, everything turns blue and unreadable. I will attach images below, thanks.
Screen Shot 2019-12-16 at 8.35.52 AM.png / V - Attached On 2019-12-16 16:37:57 UTC - Size: 224.22 KB - 365 views Screen Shot 2019-12-16 at 8.36.04 AM.png / V - Attached On 2019-12-16 16:38:16 UTC - Size: 173.57 KB - 334 views |
[2019-12-16 21:18:25] |
Start with a new chart and a default Numbers Bars a study. Do you notice the same result?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-16 21:18:32
[2019-12-17 16:54:51] |
It doesn't do this for a new charts. What does this mean ?
[2019-12-17 17:32:26] |
The Numbers Bars study does not function properly on Historical Daily chart data. If you want to use a 3 day period, you would need to change the Chart Data Type to Intraday Chart Only, then you can set the time period to 3 days. Refer to the following: Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu) Also, for reference, the information about the Numbers Bars only working with Intraday data can be found here: Numbers Bars: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-17 17:32:46
