Date/Time: Sun, 12 May 2024 16:48:29 +0000
$INX
View Count: 817
[2019-12-10 07:03:52] |
User830978 - Posts: 7 |
Hello, I have a simple question that nowhere can I find an answer. What does $ INX (SP500) or $ NDX (Nasdaq) show for volume? E.g. for ES or NQ volume I understand (number of contracts) but for $ INX I have no idea. Thank you. |
[2019-12-11 13:49:18] |
We had a look at $INX . It does appear to be the actual component volume, but we do see large-volume updates at times which either could be an error or actual, but it does cause a huge jump in volume. So we do not know about the trustworthiness of the volume data.
[2019-12-11 14:03:37] |
Thanks for the information. Is it possible to read traded volume in shares (from which the index is calculated, eg SP500) from market statistics?
[2019-12-11 14:35:56] |
Yes actually that is true. The symbol is TVOL-SP. We have activated your trial so you can test this. More information: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-11 14:36:40
[2019-12-11 18:56:43] |
Thank you very much. last question :) I suppose TVOL will be the number of shares. can we find out this volume in $? according to TVOL I will not detect cash flow ...
[2019-12-11 23:43:25] |
No there is not a way to do that.
[2019-12-12 05:07:37] |
Ok. Thx!
