Date/Time: Sat, 27 Apr 2024 13:54:55 +0000
Quantity Buttons and Flatten
View Count: 896
[2019-12-05 15:35:22] |
Aditya Chopra - Posts: 21 |
Hi, - I have changed the quantity buttons by going into "Set". But it reverts back to the default. Can I change it such that it stays changed permanantly and also changes on all charts/ chartbooks. - If I have a trade with 1 quantity, the trade closes when I pres flatten once. But if the quantity is more that 1, I have to click Flatten number of times. How can I resolve this Thanks and regards Aditya |
[2019-12-05 23:27:39] |
This is not correct. If you change the quantity buttons, then they will stay changed for that chart, even if you close and reopen the Chartbook. Just be aware that the Trade Window is associated with each Chart. So if you change the quantity values for one chart, it does NOT change it for other charts. You need to update each chart individually. This allows you to have different quantities for different symbols. Refer to the information here: Basic Trading and the Trade Window: Introduction Also refer to Chart Linking which can be used for the Trade Window: Working With Charts: Chart Linking If you still notice this, does it happen when changing the symbol of the chart? We need to know under what condition this happens. If I have a trade with 1 quantity, the trade closes when I pres flatten once. But if the quantity is more that 1, I have to click Flatten number of times. How can I resolve this
This does not make technical sense. We do not even see how that is even possible. We need the information requested here: Trade Activity Log Analysis: Support Assisted Trade Activity Log Analysis Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-05 23:30:48
