Date/Time: Thu, 02 May 2024 05:39:03 +0000
CTS perform hardware ID check
View Count: 880
[2019-12-02 16:19:33] |
DDC - Posts: 28 |
Seems to be gone in the news version of SC. I had to revert to my old version, 1971, in order to find the button so I could operate my CTS front end software on the same computer as sierra chart. Just a heads up... need to put that box back
[2019-12-02 20:10:32] |
This has been removed as part of the process of organizing Sierra Chart code related the operating system to a simple set of functions in a common place. Also understand this is very CTS specific. It is not something used with any other supported data or trading service. CTS needs to allow more than one connection at the same time. This is not due to market data rules from exchanges. They can allow two connections. Please have a look at using this service which has no restrictions like this: Sierra Chart / Trading Technologies Futures Order Routing Service With our own services there are no restrictions for trading but due to CME market data rules you will be limited to two real-time data market data connections at the same time if you are a nonprofessional. But you can use any number of instances of Sierra Chart on the same system that you want without any restrictions.: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-02 20:13:00
[2019-12-02 20:56:59] |
DDC - Posts: 28 |
I'm assuming as long as I don't update SC, I can continue using CTS and SC at the same time as I was before? Or, assuming CTS doesn't change allow 2 connections, you're going to phase them out?
[2019-12-02 22:17:53] |
You can use an earlier version of Sierra Chart as long as you need. At least for about a year. CTS is not going to get phased out. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
