Date/Time: Mon, 13 May 2024 21:20:47 +0000
Moving /SierraChart/Data/ to another hard drive
View Count: 850
[2019-11-29 10:42:35] |
Calculus - Posts: 86 |
Hiya I'm not running out of space yet but might be getting there in the next 6 months. Is it therefore possible to keep Sierra installed on my main C: drive but move the /data/ directory to another hard drive? I assume there would be no problem but I'm checking, thanks. |
[2019-11-29 15:33:08] |
Yes of course. You just need to change this setting: General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-29 15:33:21
