Date/Time: Tue, 14 May 2024 10:41:42 +0000
Topsteptrader Rithmic Data Feed shows only Intraday Data
View Count: 702
[2019-11-28 07:44:01] |
Morenob86 - Posts: 1 |
hello, I recently was using CQG data feed and no problems, but today I started a combine with TST and connected Sierra to Rithmic and only shows me intraday data. no historical data at all. In chart setting the data range is only from 2019-11-28 to 2019-11-28. I can't change it. Thank you |
[2019-11-28 20:23:52] |
We ran a test and we do not observe any problem with this. We want you to go to the main instance of Sierra Chart and follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
