Date/Time: Wed, 15 May 2024 11:21:27 +0000
Sierra Chart is Lagging
View Count: 922
[2019-11-27 15:36:58] |
fobglobal - Posts: 51 |
Hi, I was using v1941 with Infinity DOM and everything worked correctly, But now that I am using v2017 with Infinity DOM I have noticed that when there is a sudden and fast move in price in the DOM, the price in Sierra Chart lags behind. When the fast move in price happens in the DOM, the price in the chart stops for some seconds and then shows the price move in the chart. It seems like a pause a moment and resume again. Price in the chart takes some time to catchup the price in the DOM. When the price is moving in normal pace the DOM and Sierra Chart both work in synchrony. Is there a way to solve the Lagging issue? Thanks |
[2019-11-27 16:03:48] |
Refer to: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SolvingLaggingDataFeed_StoppingDataFeed_MissingDataIssues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
