Date/Time: Wed, 08 May 2024 14:53:29 +0000
Numbers bar chart , not clear for nifty future symbol from IB
View Count: 572
[2019-11-26 15:44:31] |
niftylounge - Posts: 1 |
I am not able get a clean chart with good resolution for scripts other than US symbol. 8 tried IB data service for connecting SC for future chart of Nifty50. Chart is very small and numbers are not visible. I need a standard template or setting values to configure it. Time - IST 091500 to 153000 . hrs. I AM ABLE GET CLEAN CHART FOR US SYMBOLS.
[2019-12-01 03:22:14] |
Check the Tick size: Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) And refer to: Numbers Bars: Adjusting Tick Size For Larger Increment Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
