Date/Time: Sun, 19 May 2024 02:18:44 +0000
Session Times
View Count: 721
[2019-11-26 13:24:14] |
User612649 - Posts: 40 |
How can I make my chart bars look like this: Bar 1 Monday (9:30AM) - Tuesday (9:29:59) Bar 2 Tuesday (9:30AM) - Wednesday (9:29:59) Bar 3 Wednesday (9:30AM) - Thursday (9:29:59) Bar 4 Thursday (9:30AM) - Friday (9:29:59) Bar 5 (To include the weekend data) Friday (9:30AM) - Next Monday (9:29:59) I am set to Days-Min-Sec Per Bar 1-0-0 but can't get the Start and Evening times right |
[2019-11-26 23:38:01] |
You can do this except for this: Bar 5 (To include the weekend data)
Friday (9:30AM) - Next Monday (9:29:59) In Chart >> Chart Settings set the following: - Start Time: 09:30:00 - End Time: 09:29:59 - Use Evening Session: No (unchecked) - Chart Data Type: Intraday Only Refer to the information here: Chart Session Times: Start Time (Chart >> Chart Settings >> Session Times) and here: Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-27 20:08:32] |
This does not work as expected. In putting the recommended settings in: In Chart >> Chart Settings set the following: - Start Time: 09:30:00 - End Time: 09:29:59 - Use Evening Session: No (unchecked) - Chart Data Type: Intraday Only I still have a random 6th bar that is labelled Sunday 9:30 when the market is not even open. I do not want this bar. I want that information to either be included in the previous Friday's data bar, or eliminated/dropped completely such as the "Do Not Load Weekend data" drop-down implies that even when selected DOES still load the weekend data. Date Time Of Last Edit: 2019-11-27 20:09:06
[2019-11-28 06:26:19] |
Sunday is considered Monday because of reversed session times: Chart Session Times: Understanding Trading Day Dates Based on Session Times Understand we cannot provide any further help. What you want to do is not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
