Date/Time: Tue, 07 May 2024 03:56:25 +0000
TransAct not connecting.
View Count: 648
[2019-11-25 16:02:53] |
User235082 - Posts: 2 |
Reading Internal Order ID file. | 2019-11-24 08:21:32.890 Reading Trade Orders file. | 2019-11-24 08:21:32.956 Reading Trade Positions file. | 2019-11-24 08:21:32.956 Reading Account Balance file. | 2019-11-24 08:21:32.957 UDPListener (1416). Port 22903 | Listening on UDP port 22903. | 2019-11-24 08:21:32.969 Software version: 2014 64-bit | 2019-11-24 08:21:32.969 Enabled for: Advanced Features 2. | 2019-11-24 08:21:32.969 Enabled for: Sierra Chart Historical Data Service. | 2019-11-24 08:21:32.969 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2019-11-24 08:21:32.969 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-11-24 08:21:32.969 Current selected Data/Trading service: TransAct WS | 2019-11-24 08:21:32.969 Custom symbol settings values: disabled | 2019-11-24 08:21:32.969 Chart Update Interval: 10 | 2019-11-24 08:21:32.969 Intraday Data Storage Time Unit: 0 | 2019-11-24 08:21:32.969 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-11-24 08:21:32.969 2019-11-24 15:21:32 Local computer time | 2019-11-24 08:21:32.969 2019-11-24 13:21:32 Local computer time in UTC | 2019-11-24 08:21:32.969 2019-11-24 08:21:32 Local computer time in SC Time Zone | 2019-11-24 08:21:32.969 2019-11-24 13:21:31 Server time in UTC | 2019-11-24 08:21:32.969 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-11-24 08:21:32.969 Program path: C:\SierraChart\SierraChartTransActMA\ | 2019-11-24 08:21:32.969 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2019-11-24 08:21:32.969 OS Version Number: 10.0 | 2019-11-24 08:21:32.969 Locale Setting: C | 2019-11-24 08:21:32.969 DLLs: ETOFSv2.0.dll, ETOFSv2.0_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, VCValueLevels.dll | 2019-11-24 08:21:32.970 .... TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:00:51.563 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:00:51.563 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:00:51.563 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:00:51.563 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:00:54.839 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:00:54.839 Auth Websocket | WebSocket closed. | 2019-11-25 10:00:54.839 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:00:54.839 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:00:54.839 Auth Websocket socket (1) | Closed. | 2019-11-25 10:00:54.839 TransAct WS | Disconnected. | 2019-11-25 10:00:54.875 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:00:54.875 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:00:57.871 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:00:57.871 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:00:57.872 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:00:57.872 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:01:01.106 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:01:01.106 Auth Websocket | WebSocket closed. | 2019-11-25 10:01:01.106 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:01:01.106 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:01.106 Auth Websocket socket (1) | Closed. | 2019-11-25 10:01:01.106 TransAct WS | Disconnected. | 2019-11-25 10:01:01.129 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:01.129 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:01:04.120 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:01:04.120 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:01:04.120 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:01:04.120 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:01:07.395 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:01:07.396 Auth Websocket | WebSocket closed. | 2019-11-25 10:01:07.396 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:01:07.396 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:07.396 Auth Websocket socket (1) | Closed. | 2019-11-25 10:01:07.396 TransAct WS | Disconnected. | 2019-11-25 10:01:07.404 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:07.404 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:01:10.405 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:01:10.405 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:01:10.405 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:01:10.405 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:01:13.677 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:01:13.677 Auth Websocket | WebSocket closed. | 2019-11-25 10:01:13.677 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:01:13.677 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:13.677 Auth Websocket socket (1) | Closed. | 2019-11-25 10:01:13.677 TransAct WS | Disconnected. | 2019-11-25 10:01:13.681 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:13.682 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:01:16.683 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:01:16.683 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:01:16.683 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:01:16.683 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:01:19.920 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:01:19.920 Auth Websocket | WebSocket closed. | 2019-11-25 10:01:19.920 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:01:19.920 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:19.920 Auth Websocket socket (1) | Closed. | 2019-11-25 10:01:19.920 TransAct WS | Disconnected. | 2019-11-25 10:01:19.936 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:19.936 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:01:22.938 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:01:22.938 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:01:22.938 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:01:22.938 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:01:26.220 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:01:26.220 Auth Websocket | WebSocket closed. | 2019-11-25 10:01:26.220 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:01:26.220 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:26.220 Auth Websocket socket (1) | Closed. | 2019-11-25 10:01:26.220 TransAct WS | Disconnected. | 2019-11-25 10:01:26.232 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:26.232 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:01:29.234 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:01:29.234 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:01:29.234 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:01:29.234 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:01:32.505 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:01:32.505 Auth Websocket | WebSocket closed. | 2019-11-25 10:01:32.505 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:01:32.505 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:32.505 Auth Websocket socket (1) | Closed. | 2019-11-25 10:01:32.505 TransAct WS | Disconnected. | 2019-11-25 10:01:32.512 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:32.512 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:01:35.520 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:01:35.520 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2019-11-25 10:01:35.520 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:01:35.520 Auth Websocket socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:01:38.769 * Auth Websocket socket (2) | CloseSocket call. | 2019-11-25 10:01:38.770 Auth Websocket | WebSocket closed. | 2019-11-25 10:01:38.770 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:01:38.770 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:38.770 Auth Websocket socket (2) | Closed. | 2019-11-25 10:01:38.770 TransAct WS | Disconnected. | 2019-11-25 10:01:38.782 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:01:38.782 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:03:38.779 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:03:38.779 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:03:38.779 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:03:38.779 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:03:42.046 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:03:42.046 Auth Websocket | WebSocket closed. | 2019-11-25 10:03:42.046 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:03:42.046 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:03:42.046 Auth Websocket socket (1) | Closed. | 2019-11-25 10:03:42.046 TransAct WS | Disconnected. | 2019-11-25 10:03:42.063 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:03:42.063 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:05:42.060 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:05:42.060 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2019-11-25 10:05:42.060 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:05:42.060 Auth Websocket socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:05:45.340 * Auth Websocket socket (2) | CloseSocket call. | 2019-11-25 10:05:45.340 Auth Websocket | WebSocket closed. | 2019-11-25 10:05:45.340 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:05:45.340 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:05:45.340 Auth Websocket socket (2) | Closed. | 2019-11-25 10:05:45.340 TransAct WS | Disconnected. | 2019-11-25 10:05:45.387 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:05:45.387 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:07:45.403 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:07:45.403 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2019-11-25 10:07:45.403 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:07:45.403 Auth Websocket socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:07:48.664 * Auth Websocket socket (2) | CloseSocket call. | 2019-11-25 10:07:48.664 Auth Websocket | WebSocket closed. | 2019-11-25 10:07:48.664 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:07:48.664 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:07:48.664 Auth Websocket socket (2) | Closed. | 2019-11-25 10:07:48.664 TransAct WS | Disconnected. | 2019-11-25 10:07:48.675 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:07:48.675 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:09:48.669 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:09:48.669 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2019-11-25 10:09:48.669 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:09:48.670 Auth Websocket socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:09:51.932 * Auth Websocket socket (2) | CloseSocket call. | 2019-11-25 10:09:51.932 Auth Websocket | WebSocket closed. | 2019-11-25 10:09:51.932 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:09:51.932 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:09:51.932 Auth Websocket socket (2) | Closed. | 2019-11-25 10:09:51.932 TransAct WS | Disconnected. | 2019-11-25 10:09:51.959 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:09:51.959 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:11:51.954 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:11:51.954 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2019-11-25 10:11:51.954 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:11:51.954 Auth Websocket socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:11:55.228 * Auth Websocket socket (2) | CloseSocket call. | 2019-11-25 10:11:55.228 Auth Websocket | WebSocket closed. | 2019-11-25 10:11:55.228 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:11:55.228 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:11:55.228 Auth Websocket socket (2) | Closed. | 2019-11-25 10:11:55.228 TransAct WS | Disconnected. | 2019-11-25 10:11:55.245 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:11:55.245 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:13:55.251 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:13:55.251 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:13:55.251 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:13:55.251 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:13:58.511 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:13:58.511 Auth Websocket | WebSocket closed. | 2019-11-25 10:13:58.511 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:13:58.511 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:13:58.511 Auth Websocket socket (1) | Closed. | 2019-11-25 10:13:58.511 TransAct WS | Disconnected. | 2019-11-25 10:13:58.531 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:13:58.532 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:15:58.535 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:15:58.535 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2019-11-25 10:15:58.535 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:15:58.535 Auth Websocket socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:16:01.803 * Auth Websocket socket (2) | CloseSocket call. | 2019-11-25 10:16:01.803 Auth Websocket | WebSocket closed. | 2019-11-25 10:16:01.803 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:16:01.803 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:16:01.803 Auth Websocket socket (2) | Closed. | 2019-11-25 10:16:01.803 TransAct WS | Disconnected. | 2019-11-25 10:16:01.815 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:16:01.815 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:18:01.813 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:18:01.813 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:18:01.813 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:18:01.813 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:18:05.079 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:18:05.080 Auth Websocket | WebSocket closed. | 2019-11-25 10:18:05.080 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:18:05.080 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:18:05.080 Auth Websocket socket (1) | Closed. | 2019-11-25 10:18:05.081 TransAct WS | Disconnected. | 2019-11-25 10:18:05.093 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:18:05.093 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:20:05.090 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:20:05.090 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:20:05.090 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:20:05.090 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:20:08.345 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:20:08.346 Auth Websocket | WebSocket closed. | 2019-11-25 10:20:08.346 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:20:08.346 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:20:08.346 Auth Websocket socket (1) | Closed. | 2019-11-25 10:20:08.346 TransAct WS | Disconnected. | 2019-11-25 10:20:08.353 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:20:08.353 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:22:08.357 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:22:08.357 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:22:08.357 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:22:08.357 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:22:11.597 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:22:11.597 Auth Websocket | WebSocket closed. | 2019-11-25 10:22:11.597 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:22:11.597 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:22:11.597 Auth Websocket socket (1) | Closed. | 2019-11-25 10:22:11.597 TransAct WS | Disconnected. | 2019-11-25 10:22:11.614 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:22:11.614 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:24:11.606 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:24:11.606 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:24:11.606 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:24:11.606 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:24:14.855 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:24:14.855 Auth Websocket | WebSocket closed. | 2019-11-25 10:24:14.855 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:24:14.855 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:24:14.855 Auth Websocket socket (1) | Closed. | 2019-11-25 10:24:14.856 TransAct WS | Disconnected. | 2019-11-25 10:24:14.876 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:24:14.876 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:26:14.869 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:26:14.869 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:26:14.870 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:26:14.870 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:26:18.122 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:26:18.122 Auth Websocket | WebSocket closed. | 2019-11-25 10:26:18.122 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:26:18.122 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:26:18.122 Auth Websocket socket (1) | Closed. | 2019-11-25 10:26:18.122 TransAct WS | Disconnected. | 2019-11-25 10:26:18.134 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:26:18.135 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:28:18.138 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:28:18.138 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:28:18.138 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:28:18.138 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:28:21.379 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:28:21.379 Auth Websocket | WebSocket closed. | 2019-11-25 10:28:21.379 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:28:21.379 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:28:21.379 Auth Websocket socket (1) | Closed. | 2019-11-25 10:28:21.379 TransAct WS | Disconnected. | 2019-11-25 10:28:21.389 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:28:21.389 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:30:21.408 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:30:21.409 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:30:21.409 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:30:21.409 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:30:24.651 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:30:24.651 Auth Websocket | WebSocket closed. | 2019-11-25 10:30:24.651 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:30:24.651 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:30:24.651 Auth Websocket socket (1) | Closed. | 2019-11-25 10:30:24.651 TransAct WS | Disconnected. | 2019-11-25 10:30:24.671 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:30:24.671 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:32:24.671 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:32:24.671 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:32:24.671 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:32:24.671 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:32:27.907 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:32:27.908 Auth Websocket | WebSocket closed. | 2019-11-25 10:32:27.908 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:32:27.908 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:32:27.908 Auth Websocket socket (1) | Closed. | 2019-11-25 10:32:27.908 TransAct WS | Disconnected. | 2019-11-25 10:32:27.916 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:32:27.916 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:34:27.923 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:34:27.923 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:34:27.923 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:34:27.923 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:34:31.185 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:34:31.185 Auth Websocket | WebSocket closed. | 2019-11-25 10:34:31.185 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:34:31.185 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:34:31.185 Auth Websocket socket (1) | Closed. | 2019-11-25 10:34:31.185 TransAct WS | Disconnected. | 2019-11-25 10:34:31.197 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:34:31.197 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:36:31.203 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:36:31.203 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:36:31.203 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:36:31.203 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:36:34.459 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:36:34.459 Auth Websocket | WebSocket closed. | 2019-11-25 10:36:34.459 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:36:34.459 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:36:34.459 Auth Websocket socket (1) | Closed. | 2019-11-25 10:36:34.459 TransAct WS | Disconnected. | 2019-11-25 10:36:34.463 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:36:34.463 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:38:34.465 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:38:34.465 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:38:34.465 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:38:34.465 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:38:37.712 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:38:37.712 Auth Websocket | WebSocket closed. | 2019-11-25 10:38:37.712 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:38:37.712 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:38:37.712 Auth Websocket socket (1) | Closed. | 2019-11-25 10:38:37.712 TransAct WS | Disconnected. | 2019-11-25 10:38:37.728 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:38:37.728 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:40:37.735 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:40:37.735 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:40:37.735 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:40:37.735 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:40:41.011 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:40:41.011 Auth Websocket | WebSocket closed. | 2019-11-25 10:40:41.011 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:40:41.011 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:40:41.011 Auth Websocket socket (1) | Closed. | 2019-11-25 10:40:41.011 TransAct WS | Disconnected. | 2019-11-25 10:40:41.031 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:40:41.031 File >> Disconnect selected. | 2019-11-25 10:42:23.118 TransAct WS | Disconnected. | 2019-11-25 10:42:23.119 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:42:25.730 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:42:25.730 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:42:25.730 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:42:25.730 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:42:28.983 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:42:28.983 Auth Websocket | WebSocket closed. | 2019-11-25 10:42:28.983 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:42:28.983 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:42:28.983 Auth Websocket socket (1) | Closed. | 2019-11-25 10:42:28.983 TransAct WS | Disconnected. | 2019-11-25 10:42:29.001 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:42:29.002 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:42:31.995 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:42:31.995 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:42:31.995 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:42:31.996 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:42:35.242 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:42:35.243 Auth Websocket | WebSocket closed. | 2019-11-25 10:42:35.243 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:42:35.243 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:42:35.243 Auth Websocket socket (1) | Closed. | 2019-11-25 10:42:35.243 TransAct WS | Disconnected. | 2019-11-25 10:42:35.245 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:42:35.245 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:42:38.244 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:42:38.244 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:42:38.244 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:42:38.244 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:42:41.476 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:42:41.476 Auth Websocket | WebSocket closed. | 2019-11-25 10:42:41.476 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:42:41.476 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:42:41.476 Auth Websocket socket (1) | Closed. | 2019-11-25 10:42:41.476 TransAct WS | Disconnected. | 2019-11-25 10:42:41.478 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:42:41.478 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:42:44.480 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:42:44.480 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:42:44.480 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:42:44.480 Auth Websocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-11-25 10:42:47.741 * Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:42:47.741 Auth Websocket | WebSocket closed. | 2019-11-25 10:42:47.741 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 10:42:47.741 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:42:47.741 Auth Websocket socket (1) | Closed. | 2019-11-25 10:42:47.742 TransAct WS | Disconnected. | 2019-11-25 10:42:47.748 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 10:42:47.749 TransAct WS | Connecting to Authorization server 208.97.219.30:1870 | 2019-11-25 10:42:50.748 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 10:42:50.748 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 10:42:50.748 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 10:42:50.748 File >> Disconnect selected. | 2019-11-25 10:42:53.828 Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 10:42:53.828 Auth Websocket | WebSocket closed. | 2019-11-25 10:42:53.828 TransAct WS | Disconnected. | 2019-11-25 10:42:53.828 Auth Websocket socket (1) | Closed. | 2019-11-25 10:42:53.828 |
[2019-11-25 16:36:48] |
You need to update to version 2015 by following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-25 16:53:26] |
Updated still not connecting log Reading Internal Order ID file. | 2019-11-25 11:46:43.820 Reading Trade Orders file. | 2019-11-25 11:46:44.359 Reading Trade Positions file. | 2019-11-25 11:46:44.360 Reading Account Balance file. | 2019-11-25 11:46:44.361 UDPListener (1196). Port 22903 | Listening on UDP port 22903. | 2019-11-25 11:46:44.426 Software version: 2015 64-bit | 2019-11-25 11:46:44.426 Enabled for: Advanced Features 2. | 2019-11-25 11:46:44.426 Enabled for: Sierra Chart Historical Data Service. | 2019-11-25 11:46:44.426 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2019-11-25 11:46:44.426 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-11-25 11:46:44.426 Current selected Data/Trading service: TransAct WS | 2019-11-25 11:46:44.426 Custom symbol settings values: disabled | 2019-11-25 11:46:44.426 Chart Update Interval: 10 | 2019-11-25 11:46:44.426 Intraday Data Storage Time Unit: 0 | 2019-11-25 11:46:44.426 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-11-25 11:46:44.426 2019-11-25 18:46:44 Local computer time | 2019-11-25 11:46:44.426 2019-11-25 16:46:44 Local computer time in UTC | 2019-11-25 11:46:44.426 2019-11-25 11:46:44 Local computer time in SC Time Zone | 2019-11-25 11:46:44.426 2019-11-25 16:46:41 Server time in UTC | 2019-11-25 11:46:44.426 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-11-25 11:46:44.426 Program path: C:\SierraChart\SierraChartTransActMA\ | 2019-11-25 11:46:44.426 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2019-11-25 11:46:44.426 OS Version Number: 10.0 | 2019-11-25 11:46:44.427 Locale Setting: C | 2019-11-25 11:46:44.427 DLLs: ETOFSv2.0.dll, ETOFSv2.0_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, VCValueLevels.dll | 2019-11-25 11:46:44.427 Created the DTC Protocol server. | 2019-11-25 11:46:44.513 DTC Protocol Server listening on port 11099. | 2019-11-25 11:46:44.519 Created the DTC Protocol historical data server. | 2019-11-25 11:46:44.519 HD Server Manager | Listening on port 11098 | 2019-11-25 11:46:44.524 Checking for new symbol settings. Requested symbol settings MD5 for service code transact.trading. Request ID: 1. | 2019-11-25 11:46:44.525 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:46:44.612 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-11-25 11:46:44.832 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-11-25 11:46:44.832 Received 5 login tokens. | 2019-11-25 11:46:45.354 Symbol settings MD5 received. Request ID: 1. | 2019-11-25 11:46:45.470 Requested symbol settings for service code transact.trading. Request ID: 2. | 2019-11-25 11:46:45.470 Symbol settings received. Request ID: 2. | 2019-11-25 11:46:46.641 Files to Open on Start up | Opening file: ES_2RTY_R.Cht | 2019-11-25 11:46:48.541 RTYZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:46:48.586 ESZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:46:48.624 ESZ9 30 Min #3 | Reloading chart. | 2019-11-25 11:46:48.727 Files to Open on Start up | Opening file: DOM-Labels.cht | 2019-11-25 11:46:48.749 ESZ9 #1 | Reloading chart. | 2019-11-25 11:46:48.839 ESM9 #2 | Reloading chart. | 2019-11-25 11:46:48.873 Files to Open on Start up | Opening file: ES-footrpint-dom.cht | 2019-11-25 11:46:48.891 ESZ9 Point & Figure 1-8 #1 | Reloading chart. | 2019-11-25 11:46:48.979 + Loading market depth data. | 2019-11-25 11:46:48.985 ESZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:46:49.019 Files to Open on Start up | Opening file: RR_Master.cht | 2019-11-25 11:46:49.046 ESZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:46:49.158 YMZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:46:49.197 RTYZ9 30 Min #3 | Reloading chart. | 2019-11-25 11:46:49.242 NQZ9 30 Min #4 | Reloading chart. | 2019-11-25 11:46:49.286 Files to Open on Start up | Opening file: IB_CL.Cht | 2019-11-25 11:46:49.321 Loading DLL C:\SierraChart\SierraChartTransActMA\Data\UserContributedStudies_64.dll | 2019-11-25 11:46:49.379 CLZ1 5 Min #1 | Reloading chart. | 2019-11-25 11:46:49.432 CLZ1 5 Min #2 | Reloading chart. | 2019-11-25 11:46:49.487 Files to Open on Start up | Opening file: IB_RTY.Cht | 2019-11-25 11:46:49.506 RTYZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:46:49.546 RTYZ9 5 Min #2 | Reloading chart. | 2019-11-25 11:46:49.620 Files to Open on Start up | Opening file: IB_YM.Cht | 2019-11-25 11:46:49.635 YMZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:46:49.658 YMZ9 5 Min #2 | Reloading chart. | 2019-11-25 11:46:49.716 Files to Open on Start up | Opening file: IB_NQ.Cht | 2019-11-25 11:46:49.741 NQZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:46:49.778 NQZ9 5 Min #2 | Reloading chart. | 2019-11-25 11:46:49.831 Files to Open on Start up | Opening file: IB_ES.Cht | 2019-11-25 11:46:49.855 ESZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:46:49.882 ESZ9 5 Min #2 | Reloading chart. | 2019-11-25 11:46:49.942 Loading DLL C:\SierraChart\SierraChartTransActMA\Data\ETOFSv2.0_64.dll | 2019-11-25 11:46:49.949 ESH9 2.50 Range #3 | Reloading chart. | 2019-11-25 11:46:49.998 Files to Open on Start up | Opening file: ES_HM.Cht | 2019-11-25 11:46:50.008 ESM9 10 Sec #1 | Reloading chart. | 2019-11-25 11:46:50.059 ESM9 #2 | Reloading chart. | 2019-11-25 11:46:50.078 ESM9 10 Sec #3 | Reloading chart. | 2019-11-25 11:46:50.189 ESM9 #4 | Reloading chart. | 2019-11-25 11:46:50.214 + Loading market depth data. | 2019-11-25 11:46:50.240 ESM9 2.50 Range #5 | Reloading chart. | 2019-11-25 11:46:50.341 Loaded depth data records for ESM9 2019-06-18 from 2019-06-18 15:15:06 to 2019-06-18 19:59:53. | 2019-11-25 11:46:50.346 Files to Open on Start up | Opening file: 11-19-18 Webinar PZ ES Min Max Delta.Cht | 2019-11-25 11:46:50.361 Loaded depth data records for ESM9 2019-06-19 from 2019-06-18 20:00:00 to 2019-06-19 19:59:58. | 2019-11-25 11:46:50.445 ESZ9 3.00 Range #1 | Reloading chart. | 2019-11-25 11:46:50.487 TICK-NYSE 1 Min #2 | Reloading chart. | 2019-11-25 11:46:50.521 Loaded depth data records for ESM9 2019-06-20 from 2019-06-19 20:00:00 to 2019-06-20 16:59:55. | 2019-11-25 11:46:50.528 Files to Open on Start up | Opening file: SOT_CL.GC.Cht | 2019-11-25 11:46:50.542 Loaded depth data records for ESM9 2019-06-21 from 2019-06-21 01:13:36 to 2019-06-21 09:29:58. | 2019-11-25 11:46:50.545 CLZ1 500 Trades #1 | Reloading chart. | 2019-11-25 11:46:50.591 + Loading market depth data. | 2019-11-25 11:46:50.665 GCZ9 350 Trades #2 | Reloading chart. | 2019-11-25 11:46:50.713 Files to Open on Start up | Opening file: SOT_4IND.Cht | 2019-11-25 11:46:50.731 Loaded depth data records for ESM9 2019-06-18 from 2019-06-18 02:06:28 to 2019-06-18 19:59:53. | 2019-11-25 11:46:50.736 NQZ9 1129 Trades #1 | Reloading chart. | 2019-11-25 11:46:50.792 Loaded depth data records for ESM9 2019-06-19 from 2019-06-18 20:00:00 to 2019-06-19 19:59:58. | 2019-11-25 11:46:50.810 ESZ9 3138 Trades #4 | Reloading chart. | 2019-11-25 11:46:50.818 RTYZ9 342 Trades #5 | Reloading chart. | 2019-11-25 11:46:50.861 Loaded depth data records for ESM9 2019-06-20 from 2019-06-19 20:00:00 to 2019-06-20 16:59:55. | 2019-11-25 11:46:50.877 Loaded depth data records for ESM9 2019-06-21 from 2019-06-21 01:13:36 to 2019-06-21 09:29:58. | 2019-11-25 11:46:50.883 YMZ9 422 Trades #2 | Reloading chart. | 2019-11-25 11:46:50.907 Files to Open on Start up | Opening file: ES-footrpint_MZ.cht | 2019-11-25 11:46:50.949 ESZ9 2.50 Range #1 | Reloading chart. | 2019-11-25 11:46:51.035 ESZ9 [CB] #2 | Reloading chart. | 2019-11-25 11:46:51.257 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:46:51.263 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:46:51.264 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 11:46:51.264 Starting DelayedDownloadMonitoringTimer | 2019-11-25 11:46:51.264 Starting HDTimeoutTimer | 2019-11-25 11:46:51.264 Added historical Intraday data request for ESU9 to the queue. | 2019-11-25 11:46:51.264 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:46:51.264 Triggering next historical data download in queue. | 2019-11-25 11:46:51.264 Added historical Intraday data request for ESZ9 to the queue. | 2019-11-25 11:46:51.274 ESZ9 [CB] #2 | Performing historical Daily data download for symbol ESZ19 starting at last date in file. | 2019-11-25 11:46:51.281 Starting DelayedDownloadMonitoringTimer | 2019-11-25 11:46:51.281 Starting HDTimeoutTimer | 2019-11-25 11:46:51.281 Added historical Daily data request for ESZ19 to the queue. | 2019-11-25 11:46:51.282 Triggering next historical data download in queue. | 2019-11-25 11:46:51.282 ESZ9 [CB] #2 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2019-11-25 11:46:51.307 Files to Open on Start up | Opening file: Trade_ES_RTY_NQ.Cht | 2019-11-25 11:46:51.319 ESZ9 [CB] #1 | Reloading chart. | 2019-11-25 11:46:51.390 ESZ9 [CB] #1 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2019-11-25 11:46:51.426 RTYZ9 [CB] #2 | Reloading chart. | 2019-11-25 11:46:51.585 Added historical Intraday data request for RTYU9 to the queue. | 2019-11-25 11:46:51.590 Added historical Intraday data request for RTYZ9 to the queue. | 2019-11-25 11:46:51.597 RTYZ9 [CB] #2 | Performing historical Daily data download for symbol QRZ19 starting at last date in file. | 2019-11-25 11:46:51.605 Added historical Daily data request for QRZ19 to the queue. | 2019-11-25 11:46:51.605 RTYZ9 [CB] #2 | Waiting for historical downloads to complete with the IDs: 4, 5, 6, | 2019-11-25 11:46:51.629 NQZ9 [CB] #3 | Reloading chart. | 2019-11-25 11:46:51.694 Added historical Intraday data request for NQU9 to the queue. | 2019-11-25 11:46:51.699 Added historical Intraday data request for NQZ9 to the queue. | 2019-11-25 11:46:51.709 NQZ9 [CB] #3 | Performing historical Daily data download for symbol NQZ19 starting at last date in file. | 2019-11-25 11:46:51.714 Added historical Daily data request for NQZ19 to the queue. | 2019-11-25 11:46:51.715 NQZ9 [CB] #3 | Waiting for historical downloads to complete with the IDs: 7, 8, 9, | 2019-11-25 11:46:51.737 CLZ1 5 Min #5 | Reloading chart. | 2019-11-25 11:46:51.767 YMZ9 [CB] #4 | Reloading chart. | 2019-11-25 11:46:51.839 Added historical Intraday data request for YMU9 to the queue. | 2019-11-25 11:46:51.843 Added historical Intraday data request for YMZ9 to the queue. | 2019-11-25 11:46:51.877 YMZ9 [CB] #4 | Performing historical Daily data download for symbol YMZ19 starting at last date in file. | 2019-11-25 11:46:51.883 Added historical Daily data request for YMZ19 to the queue. | 2019-11-25 11:46:51.883 YMZ9 [CB] #4 | Waiting for historical downloads to complete with the IDs: 10, 11, 12, | 2019-11-25 11:46:51.909 Files to Open on Start up | Opening file: T.Alex_CL.Cht | 2019-11-25 11:46:51.927 CLZ1 5 Min #1 | Reloading chart. | 2019-11-25 11:46:51.976 CLZ1 30 Min #2 | Reloading chart. | 2019-11-25 11:46:52.116 CLZ1 Daily #3 | Reloading chart. | 2019-11-25 11:46:52.144 CLU9 [CB] #4 | Reloading chart. | 2019-11-25 11:46:52.191 CLU9 [CB] #4 | Performing historical Daily data download for symbol CLU19 starting at last date in file. | 2019-11-25 11:46:52.230 Added historical Daily data request for CLU19 to the queue. | 2019-11-25 11:46:52.230 CLU9 [CB] #4 | Waiting for historical downloads to complete with the IDs: 13, | 2019-11-25 11:46:52.248 CLZ1 30 Min #5 | Reloading chart. | 2019-11-25 11:46:52.280 Files to Open on Start up | Opening file: T.Alex_YM.Cht | 2019-11-25 11:46:52.315 YMZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:46:52.467 YMZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:46:52.504 YMZ9 Daily #3 | Reloading chart. | 2019-11-25 11:46:52.541 YMM9 [CB] #4 | Reloading chart. | 2019-11-25 11:46:52.599 YMM9 [CB] #4 | Performing historical Daily data download for symbol YMM19 starting at last date in file. | 2019-11-25 11:46:52.605 Added historical Daily data request for YMM19 to the queue. | 2019-11-25 11:46:52.605 YMM9 [CB] #4 | Waiting for historical downloads to complete with the IDs: 14, | 2019-11-25 11:46:52.620 YMZ9 30 Min #5 | Reloading chart. | 2019-11-25 11:46:52.641 Files to Open on Start up | Opening file: T.Alex_RTY.Cht | 2019-11-25 11:46:52.661 RTYZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:46:52.752 RTYZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:46:52.779 RTYZ9 Daily #3 | Reloading chart. | 2019-11-25 11:46:52.804 RTYZ9 [CB] #4 | Reloading chart. | 2019-11-25 11:46:52.847 RTYZ9 [CB] #4 | Waiting for historical downloads to complete with the IDs: 4, 5, 6, | 2019-11-25 11:46:52.870 RTYZ9 30 Min #5 | Reloading chart. | 2019-11-25 11:46:52.897 Files to Open on Start up | Opening file: T.Alex_ES.Cht | 2019-11-25 11:46:52.914 ESZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:46:52.947 ESZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:46:52.974 ESZ9 Daily #3 | Reloading chart. | 2019-11-25 11:46:53.013 ESZ9 [CB] #4 | Reloading chart. | 2019-11-25 11:46:53.128 ESZ9 [CB] #4 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2019-11-25 11:46:53.157 ESZ9 30 Min #5 | Reloading chart. | 2019-11-25 11:46:53.200 ESZ9 2.50 Range #6 | Reloading chart. | 2019-11-25 11:46:53.268 Files to Open on Start up | Opening file: T.Alex_NQ.Cht | 2019-11-25 11:46:53.289 NQZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:46:53.414 NQZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:46:53.455 NQZ9 Daily #3 | Reloading chart. | 2019-11-25 11:46:53.489 NQZ9 [CB] #4 | Reloading chart. | 2019-11-25 11:46:53.548 NQZ9 [CB] #4 | Waiting for historical downloads to complete with the IDs: 7, 8, 9, | 2019-11-25 11:46:53.574 NQZ9 30 Min #5 | Reloading chart. | 2019-11-25 11:46:53.600 Files to Open on Start up | Opening file: ES_HM.Cht | 2019-11-25 11:46:53.623 Files to Open on Start up | Opening file: ES_RR_MZOF.Cht | 2019-11-25 11:46:53.680 ESZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:46:53.857 ESM9 2.50 Range #2 | Reloading chart. | 2019-11-25 11:46:53.921 Files to Open on Start up | Opening file: ES-footrpint_MZ.cht | 2019-11-25 11:46:53.941 Files to Open on Start up | Opening file: GC_RR.Cht | 2019-11-25 11:46:53.994 GCZ9 15 Min #1 | Reloading chart. | 2019-11-25 11:46:54.035 GCZ9 5 Min #2 | Reloading chart. | 2019-11-25 11:46:54.392 Files to Open on Start up | Opening file: 1minVolumeBand.Cht | 2019-11-25 11:46:54.445 ESZ9 3 Min #1 | Reloading chart. | 2019-11-25 11:46:54.720 Files to Open on Start up | Opening file: SOT_Trend.Cht | 2019-11-25 11:46:54.747 YMZ9 3000 Trades #1 | Reloading chart. | 2019-11-25 11:46:54.855 ESZ9 5000 Trades #2 | Reloading chart. | 2019-11-25 11:46:54.880 RTYZ9 1000 Trades #3 | Reloading chart. | 2019-11-25 11:46:54.901 NQZ9 4100 Trades #4 | Reloading chart. | 2019-11-25 11:46:54.927 Files to Open on Start up | Opening file: OB_Trader.Cht | 2019-11-25 11:46:54.953 YMZ9 4 Range #1 | Reloading chart. | 2019-11-25 11:46:54.981 RTYZ9 0.4 Range #2 | Reloading chart. | 2019-11-25 11:46:55.013 NQZ9 1.00 Range #3 | Reloading chart. | 2019-11-25 11:46:55.123 ESZ9 1.00 Range #4 | Reloading chart. | 2019-11-25 11:46:55.187 ESZ9 Rev. 4t #5 | Reloading chart. | 2019-11-25 11:46:55.220 RTYZ9 Rev. 10t #6 | Reloading chart. | 2019-11-25 11:46:55.253 Files to Open on Start up | Opening file: Sot_Trend_CL_GC.Cht | 2019-11-25 11:46:55.291 CLZ1 5000 Trades #1 | Reloading chart. | 2019-11-25 11:46:55.448 GCZ9 1000 Trades #2 | Reloading chart. | 2019-11-25 11:46:55.485 CLZ1 500 Trades #3 | Reloading chart. | 2019-11-25 11:46:55.511 GCZ9 255 Trades #4 | Reloading chart. | 2019-11-25 11:46:55.535 Files to Open on Start up | Opening file: OBTrader_GC_CL.Cht | 2019-11-25 11:46:55.563 GCZ9 0.4 Range #2 | Reloading chart. | 2019-11-25 11:46:55.761 CLF0 0.04 Range #3 | Reloading chart. | 2019-11-25 11:46:55.805 Files to Open on Start up | Opening file: ES NQ YM RTY_5DTPO_.Cht | 2019-11-25 11:46:55.848 ESZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:46:55.887 NQZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:46:55.921 YMZ9 30 Min #3 | Reloading chart. | 2019-11-25 11:46:55.952 RTYZ9 30 Min #4 | Reloading chart. | 2019-11-25 11:46:56.111 Files to Open on Start up | Opening file: 1H.Cht | 2019-11-25 11:46:56.169 RTYZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:46:56.497 RTYZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:46:56.531 Files to Open on Start up | Opening file: MP_RRx4.Cht | 2019-11-25 11:46:56.628 ESZ9 #1 | Reloading chart. | 2019-11-25 11:46:56.670 RTYZ9 #3 | Reloading chart. | 2019-11-25 11:46:56.717 NQZ9 #4 | Reloading chart. | 2019-11-25 11:46:56.960 YMZ9 #5 | Reloading chart. | 2019-11-25 11:46:56.995 YMZ9 #2 | Reloading chart. | 2019-11-25 11:46:57.032 Files to Open on Start up | Opening file: ES_Overlay-example.cht | 2019-11-25 11:46:57.069 ESZ9 #1 | Reloading chart. | 2019-11-25 11:46:57.232 ESZ9 30 Min #3 | Reloading chart. | 2019-11-25 11:46:57.264 ESZ9 #2 | Reloading chart. | 2019-11-25 11:46:57.295 ESZ9 2.00 Range #4 | Reloading chart. | 2019-11-25 11:46:57.391 Files to Open on Start up | Opening file: !Overlay-example.cht | 2019-11-25 11:46:57.450 RTYZ9 #1 | Reloading chart. | 2019-11-25 11:46:57.507 RTYZ9 30 Min #3 | Reloading chart. | 2019-11-25 11:46:57.663 RTYZ9 #2 | Reloading chart. | 2019-11-25 11:46:57.718 RTYZ9 0.8 Range #4 | Reloading chart. | 2019-11-25 11:46:57.785 ESZ9 #5 | Reloading chart. | 2019-11-25 11:46:57.886 Files to Open on Start up | Opening file: PFA.Cht | 2019-11-25 11:46:57.985 YMZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:46:58.044 NQZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:46:58.101 ESZ9 30 Min #3 | Reloading chart. | 2019-11-25 11:46:58.149 RTYZ9 30 Min #4 | Reloading chart. | 2019-11-25 11:46:58.540 Files to Open on Start up | Opening file: ES_D_W_M_MP.Cht | 2019-11-25 11:46:58.585 ESZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:46:58.658 ESZ9 10 Sec #2 | Reloading chart. | 2019-11-25 11:46:58.708 + Loading market depth data. | 2019-11-25 11:46:58.719 ESZ9 1 Min #3 | Reloading chart. | 2019-11-25 11:46:58.817 + Loading market depth data. | 2019-11-25 11:46:58.822 Files to Open on Start up | Opening file: RTY_D_W_M_MP.Cht | 2019-11-25 11:46:58.840 RTYZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:46:59.035 Files to Open on Start up | Opening file: NQ_D_W_M_MP.Cht | 2019-11-25 11:46:59.068 NQZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:46:59.622 Files to Open on Start up | Opening file: NQ_D_W_M_MP.Cht | 2019-11-25 11:46:59.752 Files to Open on Start up | Opening file: YM_D_W_M_MP.Cht | 2019-11-25 11:46:59.752 YMZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:47:00.108 Files to Open on Start up | Opening file: CL_D_W_M_MP.Cht | 2019-11-25 11:47:00.152 CLZ1 30 Min #1 | Reloading chart. | 2019-11-25 11:47:00.674 Files to Open on Start up | Opening file: GC_D_W_M_MP.Cht | 2019-11-25 11:47:00.732 GCZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:47:01.143 Files to Open on Start up | Opening file: POC_0.25-0.75.Cht | 2019-11-25 11:47:01.220 ESZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:47:01.322 RTYZ9 5 Min #2 | Reloading chart. | 2019-11-25 11:47:01.397 NQZ9 5 Min #3 | Reloading chart. | 2019-11-25 11:47:01.566 YMZ9 5 Min #4 | Reloading chart. | 2019-11-25 11:47:01.622 NQZ9 2 Min #5 | Reloading chart. | 2019-11-25 11:47:01.655 Files to Open on Start up | Opening file: POC_0.25-0.75.Cht | 2019-11-25 11:47:01.686 Files to Open on Start up | Opening file: Trend.Cht | 2019-11-25 11:47:01.687 RTYZ9 30 Min #2 | Reloading chart. | 2019-11-25 11:47:01.711 YMZ9 30 Min #1 | Reloading chart. | 2019-11-25 11:47:01.976 NQZ9 30 Min #3 | Reloading chart. | 2019-11-25 11:47:02.011 ESZ9 30 Min #5 | Reloading chart. | 2019-11-25 11:47:02.038 Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-11-25 11:47:02.078 Files to Open on Start up | Opening file: Daily_YM_GC_CL.Cht | 2019-11-25 11:47:02.084 YMZ9 Daily #1 | Reloading chart. | 2019-11-25 11:47:02.159 CLF0 Daily #2 | Reloading chart. | 2019-11-25 11:47:02.442 GCZ9 Daily #3 | Reloading chart. | 2019-11-25 11:47:02.478 Files to Open on Start up | Opening file: Daily_ES_RTY_NQ.Cht | 2019-11-25 11:47:02.568 ESZ9 Daily #1 | Reloading chart. | 2019-11-25 11:47:02.866 RTYZ9 Daily #2 | Reloading chart. | 2019-11-25 11:47:02.923 NQZ9 Daily #3 | Reloading chart. | 2019-11-25 11:47:02.959 NQZ9 5 Min #4 | Reloading chart. | 2019-11-25 11:47:02.990 Files to Open on Start up | Opening file: TPO_DayOnly.Cht | 2019-11-25 11:47:03.224 RTYZ9 [CB] #1 | Reloading chart. | 2019-11-25 11:47:03.308 RTYZ9 [CB] #1 | Waiting for historical downloads to complete with the IDs: 4, 5, 6, | 2019-11-25 11:47:03.333 ESZ9 [CB] #2 | Reloading chart. | 2019-11-25 11:47:03.392 ESZ9 [CB] #2 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2019-11-25 11:47:03.419 NQZ9 [CB] #3 | Reloading chart. | 2019-11-25 11:47:03.577 NQZ9 [CB] #3 | Waiting for historical downloads to complete with the IDs: 7, 8, 9, | 2019-11-25 11:47:03.599 YMZ9 [CB] #4 | Reloading chart. | 2019-11-25 11:47:03.651 YMZ9 [CB] #4 | Waiting for historical downloads to complete with the IDs: 10, 11, 12, | 2019-11-25 11:47:03.675 Files to Open on Start up | Opening file: ES_YearlyMP_HLVN.Cht | 2019-11-25 11:47:03.699 ESZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:47:03.920 RTYZ9 5 Min #2 | Reloading chart. | 2019-11-25 11:47:03.957 Files to Open on Start up | Opening file: NQ_YM_YearlyMP_HLVN.Cht | 2019-11-25 11:47:03.991 NQZ9 5 Min #1 | Reloading chart. | 2019-11-25 11:47:04.112 YMZ9 5 Min #2 | Reloading chart. | 2019-11-25 11:47:04.136 Files to Open on Start up | Opening file: CL_GC_YearlyMP_HLVN.Cht | 2019-11-25 11:47:04.170 CLZ1 5 Min #1 | Reloading chart. | 2019-11-25 11:47:04.351 GCZ9 5 Min #2 | Reloading chart. | 2019-11-25 11:47:04.379 Files to Open on Start up | Opening file: Korbs ES.cht | 2019-11-25 11:47:04.407 ESZ9 15 Min #1 | Reloading chart. | 2019-11-25 11:47:04.522 ESZ9 1.25 Range #7 | Reloading chart. | 2019-11-25 11:47:04.583 ESZ9 [CV] 30 Min #13 | Reloading chart. | 2019-11-25 11:47:04.614 ESZ9 [CV] 30 Min #13 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2019-11-25 11:47:04.674 ESZ9 1 Day #3 | Reloading chart. | 2019-11-25 11:47:04.707 ESZ9 Point & Figure 1-8 #2 | Reloading chart. | 2019-11-25 11:47:04.764 + Loading market depth data. | 2019-11-25 11:47:04.773 ESZ9 Rev. 8t #4 | Reloading chart. | 2019-11-25 11:47:05.028 + Loading market depth data. | 2019-11-25 11:47:05.038 Files to Open on Start up | Opening file: MP-ES_RTH_ETH_V2.cht | 2019-11-25 11:47:05.078 ESZ9 [CB] #4 | Reloading chart. | 2019-11-25 11:47:05.113 ESZ9 [CB] #4 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2019-11-25 11:47:05.136 ESZ9 Daily #1 | Reloading chart. | 2019-11-25 11:47:05.319 RTYZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.833 ESZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.834 ESZ9 30 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.834 ESZ9 #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.834 ESM9 #2 | StartDateTimeForLoadingOrderFills: 2019-06-19 09:29:59 | 2019-11-25 11:47:05.835 ESZ9 Point & Figure 1-8 #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.836 ESZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.837 ESZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.837 YMZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.838 RTYZ9 30 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.838 NQZ9 30 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.838 CLZ1 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:05.839 CLZ1 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:05.841 RTYZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.843 RTYZ9 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.844 YMZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.845 YMZ9 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.845 NQZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.846 NQZ9 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.847 ESZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.847 ESZ9 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.848 ESM9 #2 | StartDateTimeForLoadingOrderFills: 2019-06-18 15:15:00 | 2019-11-25 11:47:05.849 ESM9 #4 | StartDateTimeForLoadingOrderFills: 2019-06-18 15:15:00 | 2019-11-25 11:47:05.850 ESZ9 3.00 Range #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.850 ESM9 10 Sec #1 | StartDateTimeForLoadingOrderFills: 2019-06-18 15:15:00 | 2019-11-25 11:47:05.852 CLZ1 500 Trades #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:05.863 GCZ9 350 Trades #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\GCZ9.scid | 2019-11-25 11:47:05.865 NQZ9 1129 Trades #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.865 ESZ9 3138 Trades #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.866 RTYZ9 342 Trades #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.866 ESM9 10 Sec #3 | StartDateTimeForLoadingOrderFills: 2019-06-16 18:00:00 | 2019-11-25 11:47:05.867 YMZ9 422 Trades #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.872 ESZ9 2.50 Range #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.873 HD Request # 1 | Downloading Historical Daily chart data for ESZ19. Starting date: 2019-11-21. Service: TransAct.Trading | 2019-11-25 11:47:05.874 HD Request # 1 | Requesting historical Daily data for ESZ19 starting at 2019-11-20 | 2019-11-25 11:47:05.874 Auth Websocket | Opening WebSocket. | 2019-11-25 11:47:05.874 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:47:05.874 CLZ1 5 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:05.875 CLZ1 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:05.875 CLZ1 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:05.876 CLZ1 30 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:05.878 YMZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.878 YMZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.879 YMZ9 30 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.882 RTYZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.884 RTYZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.884 RTYZ9 30 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.886 ESZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.887 ESZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.888 ESZ9 30 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.892 ESZ9 2.50 Range #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.893 NQZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.894 NQZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.895 NQZ9 30 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.897 ESZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.898 GCZ9 15 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\GCZ9.scid | 2019-11-25 11:47:05.899 GCZ9 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\GCZ9.scid | 2019-11-25 11:47:05.900 ESZ9 3 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.901 YMZ9 3000 Trades #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.901 ESZ9 5000 Trades #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.904 RTYZ9 1000 Trades #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.905 NQZ9 4100 Trades #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.906 YMZ9 4 Range #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.906 RTYZ9 0.4 Range #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.907 NQZ9 1.00 Range #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.907 ESZ9 1.00 Range #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.908 ESZ9 Rev. 4t #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.908 RTYZ9 Rev. 10t #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.909 CLZ1 5000 Trades #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:05.914 GCZ9 1000 Trades #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\GCZ9.scid | 2019-11-25 11:47:05.915 CLZ1 500 Trades #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:05.916 GCZ9 255 Trades #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\GCZ9.scid | 2019-11-25 11:47:05.917 GCZ9 0.4 Range #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\GCZ9.scid | 2019-11-25 11:47:05.917 CLF0 0.04 Range #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLF0.scid | 2019-11-25 11:47:05.918 ESZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.918 NQZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.918 YMZ9 30 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.920 RTYZ9 30 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.927 RTYZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.938 RTYZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.944 ESH9 2.50 Range #3 | StartDateTimeForLoadingOrderFills: 2019-02-13 16:30:00 | 2019-11-25 11:47:05.947 ESZ9 #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.968 RTYZ9 #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.969 NQZ9 #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:05.970 YMZ9 #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.971 YMZ9 #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:05.971 ESZ9 #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.971 ESZ9 30 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.974 ESZ9 #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-25 11:47:05.976 ESZ9 2.00 Range #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:05.978 RTYZ9 #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.979 RTYZ9 30 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.980 RTYZ9 #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-25 11:47:05.981 RTYZ9 0.8 Range #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:05.981 ESZ9 #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-25 11:47:05.994 ESM9 2.50 Range #5 | StartDateTimeForLoadingOrderFills: 2019-05-22 16:30:00 | 2019-11-25 11:47:05.996 YMZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:06.032 NQZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:06.034 ESZ9 30 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.036 RTYZ9 30 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:06.037 ESZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.038 ESZ9 10 Sec #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.040 ESZ9 1 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.041 RTYZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:06.042 NQZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:06.044 YMZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:06.047 CLZ1 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:06.049 GCZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\GCZ9.scid | 2019-11-25 11:47:06.050 ESZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.051 RTYZ9 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:06.052 ESM9 2.50 Range #2 | StartDateTimeForLoadingOrderFills: 2019-05-22 16:30:00 | 2019-11-25 11:47:06.053 NQZ9 5 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:06.084 YMZ9 5 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:06.086 NQZ9 2 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:06.089 RTYZ9 30 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:06.091 YMZ9 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:06.092 NQZ9 30 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:06.093 ESZ9 30 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.095 Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 11:47:06.095 Auth Websocket | Network socket for WebSocket has been closed by remote side or error. | 2019-11-25 11:47:06.095 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-11-25 11:47:06.095 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:47:06.095 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:06.095 NQZ9 5 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:06.106 ESZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.112 RTYZ9 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\RTYZ9.scid | 2019-11-25 11:47:06.113 NQZ9 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\NQZ9.scid | 2019-11-25 11:47:06.114 YMZ9 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\YMZ9.scid | 2019-11-25 11:47:06.115 CLZ1 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\CLZ1.scid | 2019-11-25 11:47:06.116 GCZ9 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\GCZ9.scid | 2019-11-25 11:47:06.117 ESZ9 15 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.118 ESZ9 1.25 Range #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.119 ESZ9 1 Day #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.121 ESZ9 Point & Figure 1-8 #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.123 ESZ9 Rev. 8t #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\ESZ9.scid | 2019-11-25 11:47:06.123 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-11-25 11:47:06.125 Auth Websocket socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-11-25 11:47:06.125 Auth Websocket socket (1) | Closed. | 2019-11-25 11:47:06.125 Added historical Intraday data request for ESM9 to the queue. | 2019-11-25 11:47:06.287 Intraday data recording state for symbol ESM9 is set to download 'Pending'. | 2019-11-25 11:47:06.287 Triggering next historical data download in queue. | 2019-11-25 11:47:06.287 Added historical Intraday data request for CLZ1 to the queue. | 2019-11-25 11:47:06.352 Intraday data recording state for symbol CLZ1 is set to download 'Pending'. | 2019-11-25 11:47:06.352 Triggering next historical data download in queue. | 2019-11-25 11:47:06.352 Added historical Intraday data request for ESH9 to the queue. | 2019-11-25 11:47:06.354 Intraday data recording state for symbol ESH9 is set to download 'Pending'. | 2019-11-25 11:47:06.354 Triggering next historical data download in queue. | 2019-11-25 11:47:06.354 ESM9 10 Sec #1 | Reloading chart. | 2019-11-25 11:47:06.360 ESM9 10 Sec #3 | Reloading chart. | 2019-11-25 11:47:06.367 Added historical Intraday data request for TICK-NYSE to the queue. | 2019-11-25 11:47:06.379 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2019-11-25 11:47:06.379 Triggering next historical data download in queue. | 2019-11-25 11:47:06.379 Added historical Intraday data request for GCZ9 to the queue. | 2019-11-25 11:47:06.380 Intraday data recording state for symbol GCZ9 is set to download 'Pending'. | 2019-11-25 11:47:06.380 Triggering next historical data download in queue. | 2019-11-25 11:47:06.380 Added historical Daily data request for CLZ1 to the queue. | 2019-11-25 11:47:06.382 Triggering next historical data download in queue. | 2019-11-25 11:47:06.382 Added historical Daily data request for YMZ9 to the queue. | 2019-11-25 11:47:06.382 Triggering next historical data download in queue. | 2019-11-25 11:47:06.382 Added historical Daily data request for RTYZ9 to the queue. | 2019-11-25 11:47:06.383 Triggering next historical data download in queue. | 2019-11-25 11:47:06.383 Added historical Daily data request for ESZ9 to the queue. | 2019-11-25 11:47:06.383 Triggering next historical data download in queue. | 2019-11-25 11:47:06.383 Added historical Daily data request for NQZ9 to the queue. | 2019-11-25 11:47:06.395 Triggering next historical data download in queue. | 2019-11-25 11:47:06.395 Added historical Intraday data request for CLF0 to the queue. | 2019-11-25 11:47:06.398 Intraday data recording state for symbol CLF0 is set to download 'Pending'. | 2019-11-25 11:47:06.398 Triggering next historical data download in queue. | 2019-11-25 11:47:06.398 Added historical Daily data request for CLF0 to the queue. | 2019-11-25 11:47:06.410 Triggering next historical data download in queue. | 2019-11-25 11:47:06.410 Added historical Daily data request for GCZ9 to the queue. | 2019-11-25 11:47:06.410 Triggering next historical data download in queue. | 2019-11-25 11:47:06.410 TransAct WS | Disconnected. | 2019-11-25 11:47:06.418 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:06.418 + Loading market depth data. | 2019-11-25 11:47:06.513 Loaded depth data records for ESM9 2019-06-18 from 2019-06-18 15:15:06 to 2019-06-18 19:59:53. | 2019-11-25 11:47:06.629 Loaded depth data records for ESM9 2019-06-19 from 2019-06-18 20:00:00 to 2019-06-19 19:59:58. | 2019-11-25 11:47:06.716 + Loading market depth data. | 2019-11-25 11:47:06.733 Loaded depth data records for ESM9 2019-06-20 from 2019-06-19 20:00:00 to 2019-06-20 16:59:55. | 2019-11-25 11:47:06.812 Loaded depth data records for ESM9 2019-06-21 from 2019-06-21 01:13:36 to 2019-06-21 09:29:58. | 2019-11-25 11:47:06.824 ESM9 10 Sec #1 | StartDateTimeForLoadingOrderFills: 2019-06-18 15:15:00 | 2019-11-25 11:47:06.827 Loaded depth data records for ESM9 2019-06-18 from 2019-06-18 02:06:28 to 2019-06-18 19:59:53. | 2019-11-25 11:47:06.844 Loaded depth data records for ESM9 2019-06-19 from 2019-06-18 20:00:00 to 2019-06-19 19:59:58. | 2019-11-25 11:47:06.937 Loaded depth data records for ESM9 2019-06-20 from 2019-06-19 20:00:00 to 2019-06-20 16:59:55. | 2019-11-25 11:47:06.997 Loaded depth data records for ESM9 2019-06-21 from 2019-06-21 01:13:36 to 2019-06-21 09:29:58. | 2019-11-25 11:47:07.003 ESM9 10 Sec #3 | StartDateTimeForLoadingOrderFills: 2019-06-16 18:00:00 | 2019-11-25 11:47:07.006 HD Request # 1 | Receiving historical Daily data for ESZ19 starting at 2019-11-21 | 2019-11-25 11:47:07.622 HD Request # 1 | Writing historical Daily data to the file ESZ19.dly | 2019-11-25 11:47:07.622 HD Request # 1 | Received 4 records from 2019-11-21 00:00:00 to 2019-11-25 00:00:00 (5.0 days) and wrote 3 records for ESZ19 | 2019-11-25 11:47:07.624 HD Request # 1 | Completion time: 2s | 2019-11-25 11:47:07.631 HD Request # 1 | Daily data download complete for ESZ19. Unique request ID: 3 | 2019-11-25 11:47:07.631 Removing historical data download ID 3. | 2019-11-25 11:47:07.631 Triggering next historical data download in queue. | 2019-11-25 11:47:07.631 HD Request # 2 | Downloading Historical Daily chart data for QRZ19. Starting date: 2019-11-21. Service: TransAct.Trading | 2019-11-25 11:47:07.632 HD Request # 2 | Requesting historical Daily data for QRZ19 starting at 2019-11-20 | 2019-11-25 11:47:07.632 HD Request # 2 | Receiving historical Daily data for QRZ19 starting at 2019-11-21 | 2019-11-25 11:47:09.289 HD Request # 2 | Writing historical Daily data to the file QRZ19.dly | 2019-11-25 11:47:09.289 HD Request # 2 | Received 4 records from 2019-11-21 00:00:00 to 2019-11-25 00:00:00 (5.0 days) and wrote 3 records for QRZ19 | 2019-11-25 11:47:09.291 HD Request # 2 | Completion time: 2s | 2019-11-25 11:47:09.300 HD Request # 2 | Daily data download complete for QRZ19. Unique request ID: 6 | 2019-11-25 11:47:09.300 Removing historical data download ID 6. | 2019-11-25 11:47:09.300 Triggering next historical data download in queue. | 2019-11-25 11:47:09.300 HD Request # 3 | Downloading Historical Daily chart data for NQZ19. Starting date: 2019-11-21. Service: TransAct.Trading | 2019-11-25 11:47:09.301 HD Request # 3 | Requesting historical Daily data for NQZ19 starting at 2019-11-20 | 2019-11-25 11:47:09.301 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:47:09.555 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:47:09.555 Auth Websocket socket (5) | Creating socket. Using TLS 1.2. | 2019-11-25 11:47:09.555 Auth Websocket socket (5) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:47:09.555 Auth Websocket | Opening WebSocket. | 2019-11-25 11:47:09.798 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:47:09.798 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:47:10.526 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:47:10.526 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:47:10.526 Auth Websocket | Server header | Sec-WebSocket-Accept: /6Q+aCyIXKBgBTII4kDqfQIs7bw= | 2019-11-25 11:47:10.526 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:47:10.526 Auth Websocket | Server header | | 2019-11-25 11:47:10.526 Auth Websocket | Web socket state is now open. | 2019-11-25 11:47:10.526 TransAct WS | Sending account logon message. Live | 2019-11-25 11:47:10.526 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:47:10.768 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:47:10.768 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:10.768 HD Request # 3 | Receiving historical Daily data for NQZ19 starting at 2019-11-21 | 2019-11-25 11:47:10.908 HD Request # 3 | Writing historical Daily data to the file NQZ19.dly | 2019-11-25 11:47:10.909 HD Request # 3 | Received 4 records from 2019-11-21 00:00:00 to 2019-11-25 00:00:00 (5.0 days) and wrote 3 records for NQZ19 | 2019-11-25 11:47:10.910 HD Request # 3 | Completion time: 1s | 2019-11-25 11:47:10.916 HD Request # 3 | Daily data download complete for NQZ19. Unique request ID: 9 | 2019-11-25 11:47:10.916 Removing historical data download ID 9. | 2019-11-25 11:47:10.916 Triggering next historical data download in queue. | 2019-11-25 11:47:10.916 HD Request # 4 | Downloading Historical Daily chart data for YMZ19. Starting date: 2019-11-21. Service: TransAct.Trading | 2019-11-25 11:47:10.917 HD Request # 4 | Requesting historical Daily data for YMZ19 starting at 2019-11-20 | 2019-11-25 11:47:10.917 Auth Websocket socket (5) | CloseSocket call. | 2019-11-25 11:47:10.944 Auth Websocket | WebSocket closed. | 2019-11-25 11:47:10.944 TransAct WS | Disconnected. | 2019-11-25 11:47:10.945 Auth Websocket socket (5) | Write in progress. Shutdown being delayed. | 2019-11-25 11:47:10.945 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:10.945 Auth Websocket socket (5) | Write has completed. Shutdown being performed. | 2019-11-25 11:47:11.184 Auth Websocket socket (5) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:47:11.184 Auth Websocket socket (5) | Socket gracefully closed by remote side. | 2019-11-25 11:47:11.444 Auth Websocket socket (5) | Closed. | 2019-11-25 11:47:11.444 HD Request # 4 | Receiving historical Daily data for YMZ19 starting at 2019-11-21 | 2019-11-25 11:47:12.639 HD Request # 4 | Writing historical Daily data to the file YMZ19.dly | 2019-11-25 11:47:12.639 HD Request # 4 | Received 4 records from 2019-11-21 00:00:00 to 2019-11-25 00:00:00 (5.0 days) and wrote 3 records for YMZ19 | 2019-11-25 11:47:12.641 HD Request # 4 | Completion time: 2s | 2019-11-25 11:47:12.645 HD Request # 4 | Daily data download complete for YMZ19. Unique request ID: 12 | 2019-11-25 11:47:12.645 Removing historical data download ID 12. | 2019-11-25 11:47:12.645 Triggering next historical data download in queue. | 2019-11-25 11:47:12.645 HD Request # 5 | Downloading Historical Daily chart data for CLU19. Starting date: 2019-08-19. Service: TransAct.Trading | 2019-11-25 11:47:12.646 HD Request # 5 | Requesting historical Daily data for CLU19 starting at 2019-08-18 | 2019-11-25 11:47:12.646 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:47:13.933 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:47:13.933 Auth Websocket socket (6) | Creating socket. Using TLS 1.2. | 2019-11-25 11:47:13.933 Auth Websocket socket (6) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:47:13.933 Auth Websocket | Opening WebSocket. | 2019-11-25 11:47:14.185 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:47:14.185 HD Request # 5 | Receiving historical Daily data for CLU19 starting at 2019-08-19 | 2019-11-25 11:47:14.289 HD Request # 5 | Writing historical Daily data to the file CLU19.dly | 2019-11-25 11:47:14.289 HD Request # 5 | Received 2 records from 2019-08-19 00:00:00 to 2019-08-20 00:00:00 (2.0 days) and wrote 2 records for CLU19 | 2019-11-25 11:47:14.297 HD Request # 5 | Completion time: 2s | 2019-11-25 11:47:14.304 HD Request # 5 | Daily data download complete for CLU19. Unique request ID: 13 | 2019-11-25 11:47:14.304 Removing historical data download ID 13. | 2019-11-25 11:47:14.304 Triggering next historical data download in queue. | 2019-11-25 11:47:14.304 HD Request # 6 | Downloading Historical Daily chart data for YMM19. Starting date: 2019-06-20. Service: TransAct.Trading | 2019-11-25 11:47:14.305 HD Request # 6 | Requesting historical Daily data for YMM19 starting at 2019-06-19 | 2019-11-25 11:47:14.305 CLU9 [CB] #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2019-11-25 11:47:14.343 CLU9 [CB] #4 | Reloading chart. | 2019-11-25 11:47:14.344 CLU9 [CB] #4 | Reloading chart. | 2019-11-25 11:47:14.444 Added historical Intraday data request for CLU9 to the queue. | 2019-11-25 11:47:14.494 Intraday data recording state for symbol CLU9 is set to download 'Pending'. | 2019-11-25 11:47:14.494 Triggering next historical data download in queue. | 2019-11-25 11:47:14.495 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:47:14.942 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:47:14.942 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:47:14.942 Auth Websocket | Server header | Sec-WebSocket-Accept: 8I652lspbxxpI5fFlwyF5NfGu5w= | 2019-11-25 11:47:14.942 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:47:14.942 Auth Websocket | Server header | | 2019-11-25 11:47:14.942 Auth Websocket | Web socket state is now open. | 2019-11-25 11:47:14.942 TransAct WS | Sending account logon message. Live | 2019-11-25 11:47:14.942 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:47:15.195 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:47:15.195 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:15.195 Auth Websocket socket (6) | CloseSocket call. | 2019-11-25 11:47:15.255 Auth Websocket | WebSocket closed. | 2019-11-25 11:47:15.255 Auth Websocket socket (6) | Write in progress. Shutdown being delayed. | 2019-11-25 11:47:15.256 TransAct WS | Disconnected. | 2019-11-25 11:47:15.256 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:15.256 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:15.435 * Auth Websocket socket (6) | Write has completed. Shutdown being performed. | 2019-11-25 11:47:15.507 Auth Websocket socket (6) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:47:15.507 HD Request # 6 | Receiving historical Daily data for YMM19 starting at 2019-06-20 | 2019-11-25 11:47:15.958 HD Request # 6 | Writing historical Daily data to the file YMM19.dly | 2019-11-25 11:47:15.958 HD Request # 6 | Received 3 records from 2019-06-20 00:00:00 to 2019-06-21 00:00:00 (2.0 days) and wrote 2 records for YMM19 | 2019-11-25 11:47:15.961 HD Request # 6 | Completion time: 1s | 2019-11-25 11:47:15.967 HD Request # 6 | Daily data download complete for YMM19. Unique request ID: 14 | 2019-11-25 11:47:15.967 Removing historical data download ID 14. | 2019-11-25 11:47:15.967 Triggering next historical data download in queue. | 2019-11-25 11:47:15.967 HD Request # 7 | Downloading Historical Daily chart data for CLZ1. Starting date: 2019-11-22. Service: TransAct.Trading | 2019-11-25 11:47:15.969 HD Request # 7 | Requesting historical Daily data for CLZ21 starting at 2019-11-21 | 2019-11-25 11:47:15.969 YMM9 [CB] #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2019-11-25 11:47:15.977 YMM9 [CB] #4 | Reloading chart. | 2019-11-25 11:47:15.978 YMM9 [CB] #4 | Reloading chart. | 2019-11-25 11:47:15.999 Added historical Intraday data request for YMM9 to the queue. | 2019-11-25 11:47:16.028 Intraday data recording state for symbol YMM9 is set to download 'Pending'. | 2019-11-25 11:47:16.028 Triggering next historical data download in queue. | 2019-11-25 11:47:16.028 HD Request # 7 | Receiving historical Daily data for CLZ1 starting at 2019-11-22 | 2019-11-25 11:47:17.653 HD Request # 7 | Writing historical Daily data to the file CLZ1.dly | 2019-11-25 11:47:17.653 HD Request # 7 | Received 3 records from 2019-11-22 00:00:00 to 2019-11-25 00:00:00 (4.0 days) and wrote 2 records for CLZ1 | 2019-11-25 11:47:17.667 HD Request # 7 | Completion time: 2s | 2019-11-25 11:47:17.672 HD Request # 7 | Daily data download complete for CLZ1. Unique request ID: 20 | 2019-11-25 11:47:17.672 Removing historical data download ID 20. | 2019-11-25 11:47:17.672 Triggering next historical data download in queue. | 2019-11-25 11:47:17.672 HD Request # 8 | Downloading Historical Daily chart data for YMZ9. Starting date: 2019-11-22. Service: TransAct.Trading | 2019-11-25 11:47:17.674 HD Request # 8 | Requesting historical Daily data for YMZ19 starting at 2019-11-21 | 2019-11-25 11:47:17.674 CLZ1 Daily #3 | Reloading chart. | 2019-11-25 11:47:17.867 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:47:18.261 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:47:18.261 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2019-11-25 11:47:18.261 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:47:18.261 Auth Websocket | Opening WebSocket. | 2019-11-25 11:47:18.519 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:47:18.519 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:47:19.297 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:47:19.297 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:47:19.297 Auth Websocket | Server header | Sec-WebSocket-Accept: N3vqsI8nIED17QXjlDI3rVdIGRw= | 2019-11-25 11:47:19.297 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:47:19.297 Auth Websocket | Server header | | 2019-11-25 11:47:19.297 Auth Websocket | Web socket state is now open. | 2019-11-25 11:47:19.297 TransAct WS | Sending account logon message. Live | 2019-11-25 11:47:19.297 HD Request # 8 | Receiving historical Daily data for YMZ9 starting at 2019-11-22 | 2019-11-25 11:47:19.319 HD Request # 8 | Writing historical Daily data to the file YMZ9.dly | 2019-11-25 11:47:19.320 HD Request # 8 | Received 3 records from 2019-11-22 00:00:00 to 2019-11-25 00:00:00 (4.0 days) and wrote 2 records for YMZ9 | 2019-11-25 11:47:19.322 HD Request # 8 | Completion time: 2s | 2019-11-25 11:47:19.331 HD Request # 8 | Daily data download complete for YMZ9. Unique request ID: 21 | 2019-11-25 11:47:19.331 Removing historical data download ID 21. | 2019-11-25 11:47:19.331 Triggering next historical data download in queue. | 2019-11-25 11:47:19.331 HD Request # 9 | Downloading Historical Daily chart data for RTYZ9. Starting date: 2019-11-22. Service: TransAct.Trading | 2019-11-25 11:47:19.333 HD Request # 9 | Requesting historical Daily data for QRZ19 starting at 2019-11-21 | 2019-11-25 11:47:19.333 YMZ9 Daily #3 | Reloading chart. | 2019-11-25 11:47:19.413 YMZ9 Daily #1 | Reloading chart. | 2019-11-25 11:47:19.448 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:47:19.555 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:47:19.555 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:19.555 Auth Websocket socket (2) | CloseSocket call. | 2019-11-25 11:47:19.785 Auth Websocket | WebSocket closed. | 2019-11-25 11:47:19.785 TransAct WS | Disconnected. | 2019-11-25 11:47:19.785 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:19.785 Auth Websocket socket (2) | Write in progress. Shutdown being delayed. | 2019-11-25 11:47:19.785 Auth Websocket socket (2) | Write has completed. Shutdown being performed. | 2019-11-25 11:47:20.058 Auth Websocket socket (2) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:47:20.058 YMM9 [CB] #4 | StartDateTimeForLoadingOrderFills: 2019-04-01 00:00:00 | 2019-11-25 11:47:20.321 HD Request # 9 | Receiving historical Daily data for RTYZ9 starting at 2019-11-22 | 2019-11-25 11:47:20.919 HD Request # 9 | Writing historical Daily data to the file RTYZ9.dly | 2019-11-25 11:47:20.919 HD Request # 9 | Received 3 records from 2019-11-22 00:00:00 to 2019-11-25 00:00:00 (4.0 days) and wrote 2 records for RTYZ9 | 2019-11-25 11:47:20.922 HD Request # 9 | Completion time: 1s | 2019-11-25 11:47:20.930 HD Request # 9 | Daily data download complete for RTYZ9. Unique request ID: 22 | 2019-11-25 11:47:20.930 Removing historical data download ID 22. | 2019-11-25 11:47:20.930 Triggering next historical data download in queue. | 2019-11-25 11:47:20.931 HD Request # 10 | Downloading Historical Daily chart data for ESZ9. Starting date: 2019-11-22. Service: TransAct.Trading | 2019-11-25 11:47:20.932 HD Request # 10 | Requesting historical Daily data for ESZ19 starting at 2019-11-21 | 2019-11-25 11:47:20.933 RTYZ9 Daily #2 | Reloading chart. | 2019-11-25 11:47:20.950 RTYZ9 Daily #3 | Reloading chart. | 2019-11-25 11:47:20.968 CLU9 [CB] #4 | StartDateTimeForLoadingOrderFills: 2019-05-06 00:00:00 | 2019-11-25 11:47:22.519 HD Request # 10 | Receiving historical Daily data for ESZ9 starting at 2019-11-22 | 2019-11-25 11:47:22.620 HD Request # 10 | Writing historical Daily data to the file ESZ9.dly | 2019-11-25 11:47:22.620 HD Request # 10 | Received 3 records from 2019-11-22 00:00:00 to 2019-11-25 00:00:00 (4.0 days) and wrote 2 records for ESZ9 | 2019-11-25 11:47:22.622 HD Request # 10 | Completion time: 2s | 2019-11-25 11:47:22.630 HD Request # 10 | Daily data download complete for ESZ9. Unique request ID: 23 | 2019-11-25 11:47:22.630 Removing historical data download ID 23. | 2019-11-25 11:47:22.630 Triggering next historical data download in queue. | 2019-11-25 11:47:22.631 HD Request # 11 | Downloading Historical Daily chart data for NQZ9. Starting date: 2019-11-22. Service: TransAct.Trading | 2019-11-25 11:47:22.632 HD Request # 11 | Requesting historical Daily data for NQZ19 starting at 2019-11-21 | 2019-11-25 11:47:22.632 ESZ9 Daily #3 | Reloading chart. | 2019-11-25 11:47:22.647 ESZ9 Daily #1 | Reloading chart. | 2019-11-25 11:47:22.678 ESZ9 Daily #1 | Reloading chart. | 2019-11-25 11:47:22.692 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:47:22.856 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:47:22.856 Auth Websocket socket (12) | Creating socket. Using TLS 1.2. | 2019-11-25 11:47:22.856 Auth Websocket socket (12) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:47:22.856 Auth Websocket | Opening WebSocket. | 2019-11-25 11:47:23.106 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:47:23.106 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:47:23.865 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:47:23.866 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:47:23.866 Auth Websocket | Server header | Sec-WebSocket-Accept: 74HcXI2+jaQ5IIYULHuSchr78wE= | 2019-11-25 11:47:23.866 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:47:23.866 Auth Websocket | Server header | | 2019-11-25 11:47:23.866 Auth Websocket | Web socket state is now open. | 2019-11-25 11:47:23.866 TransAct WS | Sending account logon message. Live | 2019-11-25 11:47:23.866 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:47:24.116 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:47:24.116 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:24.116 HD Request # 11 | Receiving historical Daily data for NQZ9 starting at 2019-11-22 | 2019-11-25 11:47:24.265 HD Request # 11 | Writing historical Daily data to the file NQZ9.dly | 2019-11-25 11:47:24.266 HD Request # 11 | Received 3 records from 2019-11-22 00:00:00 to 2019-11-25 00:00:00 (4.0 days) and wrote 2 records for NQZ9 | 2019-11-25 11:47:24.268 HD Request # 11 | Completion time: 2s | 2019-11-25 11:47:24.276 HD Request # 11 | Daily data download complete for NQZ9. Unique request ID: 24 | 2019-11-25 11:47:24.276 Removing historical data download ID 24. | 2019-11-25 11:47:24.276 Triggering next historical data download in queue. | 2019-11-25 11:47:24.276 HD Request # 12 | Downloading Historical Daily chart data for CLF0. Starting date: 2019-11-22. Service: TransAct.Trading | 2019-11-25 11:47:24.280 HD Request # 12 | Requesting historical Daily data for CLF20 starting at 2019-11-21 | 2019-11-25 11:47:24.280 NQZ9 Daily #3 | Reloading chart. | 2019-11-25 11:47:24.307 Auth Websocket socket (12) | CloseSocket call. | 2019-11-25 11:47:24.331 Auth Websocket | WebSocket closed. | 2019-11-25 11:47:24.331 TransAct WS | Disconnected. | 2019-11-25 11:47:24.331 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:24.332 Auth Websocket socket (12) | Write in progress. Shutdown being delayed. | 2019-11-25 11:47:24.332 NQZ9 Daily #3 | Reloading chart. | 2019-11-25 11:47:24.338 Auth Websocket socket (12) | Write has completed. Shutdown being performed. | 2019-11-25 11:47:24.581 Auth Websocket socket (12) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:47:24.581 HD Request # 12 | Receiving historical Daily data for CLF0 starting at 2019-11-22 | 2019-11-25 11:47:25.872 HD Request # 12 | Writing historical Daily data to the file CLF0.dly | 2019-11-25 11:47:25.872 HD Request # 12 | Received 3 records from 2019-11-22 00:00:00 to 2019-11-25 00:00:00 (4.0 days) and wrote 2 records for CLF0 | 2019-11-25 11:47:25.879 HD Request # 12 | Completion time: 1s | 2019-11-25 11:47:25.883 HD Request # 12 | Daily data download complete for CLF0. Unique request ID: 26 | 2019-11-25 11:47:25.883 Removing historical data download ID 26. | 2019-11-25 11:47:25.883 Triggering next historical data download in queue. | 2019-11-25 11:47:25.884 HD Request # 13 | Downloading Historical Daily chart data for GCZ9. Starting date: 2019-11-22. Service: TransAct.Trading | 2019-11-25 11:47:25.886 HD Request # 13 | Requesting historical Daily data for GCZ19 starting at 2019-11-21 | 2019-11-25 11:47:25.886 CLF0 Daily #2 | Reloading chart. | 2019-11-25 11:47:25.911 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:47:27.327 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:47:27.327 Auth Websocket socket (14) | Creating socket. Using TLS 1.2. | 2019-11-25 11:47:27.327 Auth Websocket socket (14) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:47:27.327 HD Request # 13 | Receiving historical Daily data for GCZ9 starting at 2019-11-22 | 2019-11-25 11:47:27.675 HD Request # 13 | Writing historical Daily data to the file GCZ9.dly | 2019-11-25 11:47:27.676 HD Request # 13 | Received 3 records from 2019-11-22 00:00:00 to 2019-11-25 00:00:00 (4.0 days) and wrote 2 records for GCZ9 | 2019-11-25 11:47:27.683 HD Request # 13 | Completion time: 2s | 2019-11-25 11:47:27.689 HD Request # 13 | Daily data download complete for GCZ9. Unique request ID: 27 | 2019-11-25 11:47:27.689 Removing historical data download ID 27. | 2019-11-25 11:47:27.689 Triggering next historical data download in queue. | 2019-11-25 11:47:27.689 Auth Websocket | Opening WebSocket. | 2019-11-25 11:47:27.689 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:47:27.689 GCZ9 Daily #3 | Reloading chart. | 2019-11-25 11:47:27.697 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:47:28.436 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:47:28.436 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:47:28.436 Auth Websocket | Server header | Sec-WebSocket-Accept: MBCuFmwyJUt3lSF+uLtqnhrHbkE= | 2019-11-25 11:47:28.436 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:47:28.436 Auth Websocket | Server header | | 2019-11-25 11:47:28.436 Auth Websocket | Web socket state is now open. | 2019-11-25 11:47:28.436 TransAct WS | Sending account logon message. Live | 2019-11-25 11:47:28.436 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:47:28.684 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:47:28.684 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:28.684 Auth Websocket socket (14) | CloseSocket call. | 2019-11-25 11:47:28.839 Auth Websocket | WebSocket closed. | 2019-11-25 11:47:28.839 TransAct WS | Disconnected. | 2019-11-25 11:47:28.839 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:28.839 Auth Websocket socket (14) | Write in progress. Shutdown being delayed. | 2019-11-25 11:47:28.839 Auth Websocket socket (14) | Write has completed. Shutdown being performed. | 2019-11-25 11:47:29.084 Auth Websocket socket (14) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:47:29.085 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:47:31.857 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:47:31.857 Auth Websocket socket (15) | Creating socket. Using TLS 1.2. | 2019-11-25 11:47:31.857 Auth Websocket socket (15) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:47:31.857 Auth Websocket | Opening WebSocket. | 2019-11-25 11:47:32.107 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:47:32.107 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:47:32.916 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:47:32.916 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:47:32.916 Auth Websocket | Server header | Sec-WebSocket-Accept: Wceb+zGlleS7v7iySsOv7bVVIm8= | 2019-11-25 11:47:32.916 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:47:32.916 Auth Websocket | Server header | | 2019-11-25 11:47:32.916 Auth Websocket | Web socket state is now open. | 2019-11-25 11:47:32.916 TransAct WS | Sending account logon message. Live | 2019-11-25 11:47:32.916 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:47:33.163 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:47:33.163 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:33.163 Auth Websocket socket (15) | CloseSocket call. | 2019-11-25 11:47:33.440 Auth Websocket | WebSocket closed. | 2019-11-25 11:47:33.440 TransAct WS | Disconnected. | 2019-11-25 11:47:33.440 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:47:33.440 Auth Websocket socket (15) | Write in progress. Shutdown being delayed. | 2019-11-25 11:47:33.440 Auth Websocket socket (15) | Write has completed. Shutdown being performed. | 2019-11-25 11:47:33.686 Auth Websocket socket (15) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:47:33.686 Auth Websocket socket (15) | Socket gracefully closed by remote side. | 2019-11-25 11:47:33.934 Auth Websocket socket (15) | Closed. | 2019-11-25 11:47:33.934 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:47:36.432 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:47:36.432 Auth Websocket socket (3) | Creating socket. Using TLS 1.2. | 2019-11-25 11:47:36.432 Auth Websocket socket (3) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:47:36.432 File >> Disconnect selected. | 2019-11-25 11:47:36.617 Auth Websocket socket (3) | CloseSocket call. | 2019-11-25 11:47:36.617 Auth Websocket | WebSocket closed. | 2019-11-25 11:47:36.617 Auth Websocket socket (3) | Closed. | 2019-11-25 11:47:36.617 TransAct WS | Disconnected. | 2019-11-25 11:47:36.617 HTTPS connection ID:3 to historicaldata.sierrachart.com:443 for request ID:3 (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:37.419 * Auth Websocket socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:38.358 * Auth Websocket socket (6) | Socket gracefully closed by remote side. | 2019-11-25 11:47:38.358 Auth Websocket socket (6) | Closed. | 2019-11-25 11:47:38.358 HTTPS connection ID:4 to historicaldata.sierrachart.com:443 for request ID:4 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:42.370 * HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:42.569 * Auth Websocket socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:44.608 * Auth Websocket socket (2) | Socket gracefully closed by remote side. | 2019-11-25 11:47:44.608 Auth Websocket socket (2) | Closed. | 2019-11-25 11:47:44.608 Auth Websocket socket (12) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:47.514 * Auth Websocket socket (12) | Socket gracefully closed by remote side. | 2019-11-25 11:47:47.514 Auth Websocket socket (12) | Closed. | 2019-11-25 11:47:47.514 HTTPS connection ID:8 to historicaldata.sierrachart.com:443 for request ID:8 (8) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:48.753 * HTTPS connection ID:9 to historicaldata.sierrachart.com:443 for request ID:9 (9) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:48.774 * HTTPS connection ID:10 to historicaldata.sierrachart.com:443 for request ID:10 (10) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:50.886 * Auth Websocket socket (14) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:51.687 * Auth Websocket socket (14) | Socket gracefully closed by remote side. | 2019-11-25 11:47:51.687 Auth Websocket socket (14) | Closed. | 2019-11-25 11:47:51.687 HTTPS connection ID:12 to historicaldata.sierrachart.com:443 for request ID:12 (13) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:52.110 * HTTPS connection ID:13 to historicaldata.sierrachart.com:443 for request ID:13 (11) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:47:57.883 * TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:48:19.352 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:48:19.352 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 11:48:19.352 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:48:19.352 Auth Websocket | Opening WebSocket. | 2019-11-25 11:48:20.606 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:48:20.606 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:48:21.380 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:48:21.380 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:48:21.380 Auth Websocket | Server header | Sec-WebSocket-Accept: MDcKoOQC6NttlodbDa8zjcYuNYI= | 2019-11-25 11:48:21.380 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:48:21.380 Auth Websocket | Server header | | 2019-11-25 11:48:21.380 Auth Websocket | Web socket state is now open. | 2019-11-25 11:48:21.380 TransAct WS | Sending account logon message. Live | 2019-11-25 11:48:21.380 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:48:21.637 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:48:21.637 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:21.637 Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 11:48:21.749 Auth Websocket | WebSocket closed. | 2019-11-25 11:48:21.749 TransAct WS | Disconnected. | 2019-11-25 11:48:21.749 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:21.749 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-11-25 11:48:21.749 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-11-25 11:48:22.001 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:48:22.001 Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-11-25 11:48:22.256 Auth Websocket socket (1) | Closed. | 2019-11-25 11:48:22.257 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:48:24.753 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:48:24.753 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-11-25 11:48:24.753 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:48:24.753 Auth Websocket | Opening WebSocket. | 2019-11-25 11:48:25.010 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:48:25.010 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:48:25.775 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:48:25.775 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:48:25.775 Auth Websocket | Server header | Sec-WebSocket-Accept: 3B5Ia2Aj4r8l4rB8yiXQre3Rhi8= | 2019-11-25 11:48:25.775 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:48:25.775 Auth Websocket | Server header | | 2019-11-25 11:48:25.775 Auth Websocket | Web socket state is now open. | 2019-11-25 11:48:25.775 TransAct WS | Sending account logon message. Live | 2019-11-25 11:48:25.775 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:48:26.034 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:48:26.034 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:26.034 Auth Websocket socket (1) | CloseSocket call. | 2019-11-25 11:48:26.041 Auth Websocket | WebSocket closed. | 2019-11-25 11:48:26.041 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-11-25 11:48:26.041 TransAct WS | Disconnected. | 2019-11-25 11:48:26.042 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:26.042 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-11-25 11:48:26.296 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:48:26.296 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:48:29.147 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:48:29.147 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2019-11-25 11:48:29.147 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:48:29.148 Auth Websocket | Opening WebSocket. | 2019-11-25 11:48:29.396 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:48:29.396 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:48:30.142 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:48:30.142 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:48:30.142 Auth Websocket | Server header | Sec-WebSocket-Accept: rrMCKbdHHGFST4ccrPSVwwKjBJI= | 2019-11-25 11:48:30.142 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:48:30.142 Auth Websocket | Server header | | 2019-11-25 11:48:30.142 Auth Websocket | Web socket state is now open. | 2019-11-25 11:48:30.142 TransAct WS | Sending account logon message. Live | 2019-11-25 11:48:30.142 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:48:30.387 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:48:30.387 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:30.387 Auth Websocket socket (2) | CloseSocket call. | 2019-11-25 11:48:30.611 Auth Websocket | WebSocket closed. | 2019-11-25 11:48:30.611 TransAct WS | Disconnected. | 2019-11-25 11:48:30.611 Auth Websocket socket (2) | Write in progress. Shutdown being delayed. | 2019-11-25 11:48:30.611 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:30.611 Auth Websocket socket (2) | Write has completed. Shutdown being performed. | 2019-11-25 11:48:30.856 Auth Websocket socket (2) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:48:30.856 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:48:33.611 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:48:33.611 Auth Websocket socket (3) | Creating socket. Using TLS 1.2. | 2019-11-25 11:48:33.611 Auth Websocket socket (3) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:48:33.611 Auth Websocket | Opening WebSocket. | 2019-11-25 11:48:33.852 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:48:33.852 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:48:34.581 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:48:34.581 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:48:34.581 Auth Websocket | Server header | Sec-WebSocket-Accept: 22optPyO4crWQTOWFHM4+i7SOT0= | 2019-11-25 11:48:34.581 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:48:34.581 Auth Websocket | Server header | | 2019-11-25 11:48:34.581 Auth Websocket | Web socket state is now open. | 2019-11-25 11:48:34.581 TransAct WS | Sending account logon message. Live | 2019-11-25 11:48:34.581 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:48:34.825 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:48:34.825 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:34.825 Auth Websocket socket (3) | CloseSocket call. | 2019-11-25 11:48:34.938 Auth Websocket | WebSocket closed. | 2019-11-25 11:48:34.938 TransAct WS | Disconnected. | 2019-11-25 11:48:34.938 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:34.938 Auth Websocket socket (3) | Write in progress. Shutdown being delayed. | 2019-11-25 11:48:34.938 Auth Websocket socket (3) | Write has completed. Shutdown being performed. | 2019-11-25 11:48:35.182 Auth Websocket socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:48:35.182 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:48:37.943 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:48:37.943 Auth Websocket socket (4) | Creating socket. Using TLS 1.2. | 2019-11-25 11:48:37.943 Auth Websocket socket (4) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:48:37.943 Auth Websocket | Opening WebSocket. | 2019-11-25 11:48:38.184 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:48:38.184 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:48:38.910 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:48:38.910 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:48:38.910 Auth Websocket | Server header | Sec-WebSocket-Accept: Gzf7VmnwDljSwbYR5J9rGAbA/io= | 2019-11-25 11:48:38.910 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:48:38.910 Auth Websocket | Server header | | 2019-11-25 11:48:38.910 Auth Websocket | Web socket state is now open. | 2019-11-25 11:48:38.910 TransAct WS | Sending account logon message. Live | 2019-11-25 11:48:38.910 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:48:39.154 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:48:39.154 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:39.154 Auth Websocket socket (4) | CloseSocket call. | 2019-11-25 11:48:39.347 Auth Websocket | WebSocket closed. | 2019-11-25 11:48:39.347 Auth Websocket socket (4) | Write in progress. Shutdown being delayed. | 2019-11-25 11:48:39.347 TransAct WS | Disconnected. | 2019-11-25 11:48:39.347 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:39.347 Auth Websocket socket (4) | Write has completed. Shutdown being performed. | 2019-11-25 11:48:39.588 Auth Websocket socket (4) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:48:39.588 Auth Websocket socket (4) | Socket gracefully closed by remote side. | 2019-11-25 11:48:39.829 Auth Websocket socket (4) | Closed. | 2019-11-25 11:48:39.829 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:48:42.346 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:48:42.346 Auth Websocket socket (4) | Creating socket. Using TLS 1.2. | 2019-11-25 11:48:42.346 Auth Websocket socket (4) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:48:42.346 Auth Websocket | Opening WebSocket. | 2019-11-25 11:48:42.596 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:48:42.596 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-11-25 11:48:43.341 Auth Websocket | Server header | Upgrade: WebSocket | 2019-11-25 11:48:43.341 Auth Websocket | Server header | Connection: Upgrade | 2019-11-25 11:48:43.341 Auth Websocket | Server header | Sec-WebSocket-Accept: DhhIG3MNQixKY7UJDx0UZlGkIOk= | 2019-11-25 11:48:43.341 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-11-25 11:48:43.341 Auth Websocket | Server header | | 2019-11-25 11:48:43.341 Auth Websocket | Web socket state is now open. | 2019-11-25 11:48:43.341 TransAct WS | Sending account logon message. Live | 2019-11-25 11:48:43.341 TransAct WS | Account logon error: -1(-1) | 2019-11-25 11:48:43.590 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-11-25 11:48:43.590 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:43.590 Auth Websocket socket (4) | CloseSocket call. | 2019-11-25 11:48:43.692 Auth Websocket | WebSocket closed. | 2019-11-25 11:48:43.692 TransAct WS | Disconnected. | 2019-11-25 11:48:43.692 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-25 11:48:43.692 Auth Websocket socket (4) | Write in progress. Shutdown being delayed. | 2019-11-25 11:48:43.692 Auth Websocket socket (4) | Write has completed. Shutdown being performed. | 2019-11-25 11:48:43.977 Auth Websocket socket (4) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:48:43.977 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-11-25 11:48:46.739 Auth Websocket | Connecting to WebSocket server. | 2019-11-25 11:48:46.739 Auth Websocket socket (5) | Creating socket. Using TLS 1.2. | 2019-11-25 11:48:46.739 Auth Websocket socket (5) | Connecting to IP: 208.97.219.30. | 2019-11-25 11:48:46.739 Auth Websocket | Opening WebSocket. | 2019-11-25 11:48:46.988 Auth Websocket | Sending WebSocket handshake. | 2019-11-25 11:48:46.988 File >> Disconnect selected. | 2019-11-25 11:48:47.074 Auth Websocket socket (5) | CloseSocket call. | 2019-11-25 11:48:47.074 Auth Websocket | WebSocket closed. | 2019-11-25 11:48:47.074 Auth Websocket socket (5) | Write in progress. Shutdown being delayed. | 2019-11-25 11:48:47.074 TransAct WS | Disconnected. | 2019-11-25 11:48:47.076 Auth Websocket socket (5) | Write has completed. Shutdown being performed. | 2019-11-25 11:48:47.238 Auth Websocket socket (5) | Shutdown started. Waiting for graceful close. | 2019-11-25 11:48:47.238 Auth Websocket socket (5) | Socket gracefully closed by remote side. | 2019-11-25 11:48:47.488 Auth Websocket socket (5) | Closed. | 2019-11-25 11:48:47.488 Auth Websocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:48:49.775 * Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-11-25 11:48:49.775 Auth Websocket socket (1) | Closed. | 2019-11-25 11:48:49.775 Auth Websocket socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:48:53.579 * Auth Websocket socket (2) | Socket gracefully closed by remote side. | 2019-11-25 11:48:53.579 Auth Websocket socket (2) | Closed. | 2019-11-25 11:48:53.579 Auth Websocket socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:48:57.468 * Auth Websocket socket (3) | Socket gracefully closed by remote side. | 2019-11-25 11:48:57.468 Auth Websocket socket (3) | Closed. | 2019-11-25 11:48:57.468 Auth Websocket socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-11-25 11:49:09.223 * Auth Websocket socket (4) | Socket gracefully closed by remote side. | 2019-11-25 11:49:09.223 Auth Websocket socket (4) | Closed. | 2019-11-25 11:49:09.223 |
[2019-11-25 17:36:25] |
This is the relevant message: TransAct WS | Account logon error: -1(-1)
This is a Transact issue. Refer to the following: https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
