Date/Time: Sun, 19 May 2024 06:24:02 +0000
Deselecting Objects and changing default properties
View Count: 636
[2019-11-21 15:17:11] |
Aditya Chopra - Posts: 21 |
Hi, Is there a way that the object gets deselected after it has been drawn, instead of either clicking the pointer or ALT 1 to deselect How can I change the default properties of any object. At the moment I have to draw it and change the config as per my preference Thanks and regards |
[2019-11-21 16:48:37] |
Yes you need to use this setting: Chart Drawing Tools: Using a Tool One Time, and Switching to the Default Tool And for the default configuration, refer to: Chart Drawing Tools: Drawing Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
