Date/Time: Sun, 05 May 2024 18:26:31 +0000
Sim Trading
View Count: 913
[2019-11-19 00:03:07] |
User703334 - Posts: 59 |
As of a couple of days ago taking trades in Sim Mode has been impossible. 1. When I select any of the 3 options presented to me after I hit "Replay, none of them seem to work, including "clear all trade data from account." 2. When I select Buy Market; no position is indicated, yet multiple position bells sound, and a completely erroneous P/L is instantly indicated. 3. When price hits a resting Buy limit order, no position is indicated at all, all attached orders disappear, and again and even different erroneous P/L is indicated. How do I get Sim trade in Sim mode to work correctly again? Thank you, |
[2019-11-20 02:45:46] |
1. How do you come to this conclusion? We need a lot more details and screenshots. 2. It sounds like a Position was opened and then closed immediately . You need to analyze what has happened through the Trade Activity Log: Trade Activity Log: Viewing Historical Trade Activity 3. Same answer as above. In regards to "erroneous profit/loss", this really does not make sense in the case of simulated trading. Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-20 02:46:10
[2019-11-20 03:31:28] |
The above crazy scenarios occur when Sim Trading with "Micro" E-minis. I tried with standard E-minis and works fine. Not sure why it suddenly stopped working when Sim trading the Micros, but I'll use Standard E-minis from now on as long as they work.
[2019-11-20 03:58:09] |
Probably because of the bid and ask pricing is not as expected but that may not be so much of a problem anymore as the liquidity is increasing for the micro contracts.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-21 04:20:10
