Date/Time: Sun, 19 May 2024 03:36:43 +0000
Spread sheet study display values on chart problem
View Count: 619
[2019-11-12 23:58:54] |
User884307 - Posts: 173 |
Hi Values that I have calculated in the spreadsheet study are not displaying the correct values when they are displayed on a chart. The values seem to be correct as the bar is drawing (and the spreadsheet values are changing), however just as the bar completes the figure that is displayed on the chart is wildly different than that on the spreadsheet value for the same completed bar? Any he would really be appreciated greatly! Many thanks |
[2019-11-13 22:41:59] |
We do not know precisely what you are doing, but usually problems like this are related to study calculation order: Chart Studies: Study Calculation Precedence And Related Issues Even if there is a case where a value is changing in a cell other than which corresponds to the most recent bar, still if it is within 5 to 10 bars of the last bar, the values will still be gotten from the Spreadsheet and displayed in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-13 22:44:51
[2019-11-13 23:47:40] |
I think this is the issue, I figured this was the issue. Thankyou for getting back to me, it is appreciated greatly 🙏🙏👍👍 |
