Date/Time: Sat, 18 May 2024 13:22:51 +0000
See market depth without ladder
View Count: 912
[2019-11-11 18:01:40] |
User474409 - Posts: 10 |
Hi I know there are two ways too see market depth,chart dom and trading dom. Is there a way to see complete market depth without using price ladder,like the one in the attached picture. Thank you |
mktDepth885.gif / V - Attached On 2019-11-11 18:00:20 UTC - Size: 29.08 KB - 293 views |
[2019-11-11 18:48:30] |
User907968 - Posts: 804 |
This? File Menu: Open Market Depth Window (File) |
[2019-11-12 03:54:21] |
Yes here is the relevant documentation: File Menu: Open Market Depth Window (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-12 06:45:31] |
Thank you all for that Is there a way to hide Bid Orders/Ask Orders columns? Also can the summed values rows be always visible even when scrolled all the way to the top like in Excel? If not I would like to request this feature in the subsequent release of the software Thank you |
[2019-11-12 15:28:29] |
You can only change the width of the columns but not completely remove them. Also can the summed values rows be always visible even when scrolled all the way to the top like in Excel? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
