Date/Time: Mon, 29 Apr 2024 10:29:33 +0000
trial data feed
View Count: 521
[2019-11-08 22:28:52] |
User82032 - Posts: 35 |
I am currently using the Denali data feed along with order routing through Sierra. I am using Denali because I currently only trade the CME, CBOT, and Nymex products. I am interested in evaluating products from the NYSE and Nasdaq to see how my trading methodology might fair in certain common stocks. I think historical data will be fine for my purposes and I should need less than 48 hours for my evaluations. Please let me know how this might be set up. Thanks |
[2019-11-10 05:48:48] |
You have access to this data. Just make sure you are running the current version of Sierra Chart: Software Download: Fast Update And then just open stock symbols using the standard US stock symbols following the instructions here: Getting Started, Opening Charts and Basic Trading: Open Chart For example, open a chart for AA and you will get the historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-10 21:55:46
