Date/Time: Sat, 18 May 2024 23:29:59 +0000
No commissions when using SC Data feed?
View Count: 772
[2019-11-08 18:07:26] |
j4ytr4der_ - Posts: 918 |
I've run into issues with the TransAct data feed when using Replay, so I'm trying on the SC Data feed which appears to work better for my needs. However for some reason no commissions are ever accounted for when using SC Data. They show up fine when doing backtesting on the TransAct feed. Symbol settings are set to use global default of 4.40 roundtrip commission. I also tried setting the default commission for the symbol itself (RTY) but that made no difference either. I have also tried using the "Use Symbol Commission Setting in Trade List and Statistics Calculations" option, again no change. All commissions are zero if I'm on the SC Data feed. Any idea why? |
[2019-11-08 18:41:13] |
Figured it out. The SC Data feed uses a different symbol convention so running it on my existing RTY chart wasn't behaving properly. Commissions are properly appearing now.
[2019-11-10 05:51:45] |
Translate the symbols: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-08 14:39:37] |
Barabaszek1 - Posts: 10 |
How to set commission on micro E-mini symbols, after entering 0.78 $ in the symbol settings form and selecting MES? ## _ FUT_CME> round turn commission and inserting 0.78 in custom in Trade activity log commission lists for Micro E-mini is calculated as for E-mini.
Złe naliczanie prowizji.png / V - Attached On 2020-02-08 14:36:43 UTC - Size: 148.87 KB - 301 views Attachment Deleted. |
[2020-02-10 09:19:57] |
Be sure to follow the instructions here for this including enabling the option Use Custom Symbol Settings Values: Global Symbol Settings: Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
