Date/Time: Sun, 05 May 2024 16:53:30 +0000
ECIVWAP
View Count: 1591
[2019-11-07 12:33:24] |
User666994 - Posts: 6 |
Good afternoon, I have downloaded the new version of Sierra Chart (2007) and cannot find the study ECIVWAP in Custom studies that I have been using in previous version of Sierra. Can you please advise? |
[2019-11-07 13:30:54] |
Run the installer again through Help >> Download Current Version and enable Install Optional Components.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-07 13:31:08
[2019-11-07 14:43:54] |
Thank you but this still does not show me the custom study
[2019-11-08 02:06:48] |
Are you selecting Add Custom Study and looking under the User Contributed Studies section? Also make sure Sierra Chart is not running in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
