Date/Time: Thu, 02 May 2024 03:02:45 +0000
[User Discussion] - Numbers Bars additional range / color
View Count: 741
[2019-11-05 14:54:35] |
User351605 - Posts: 76 |
Hello, is it somehow possible to add a fifth range / color to the numbers bars study? I need another color for an extreme value. Is it maybe possible with overlaying another study? Thank you! |
[2019-11-05 16:18:36] |
No, this will not be supported.
[2019-11-05 17:40:09] |
Ackin - Posts: 1865 |
I need another color for an extreme value. Is it maybe possible with overlaying another study? Volume At Price Threshold Alert Volume at Price Threshold Alert V2 You can use it for coloring extremes or If you need others you can look on the CZ/SK forum. Maybe you'll find what you are looking for. Ackin's indicators (SCH users requests for studies) - Update list | Post: 193747 |
[2019-11-08 21:09:46] |
Unfortunately the coloring from the 'Volume at price threshold alert' study stays always beneath the background coloring of the numbers bars. It is therefore useless in this context.
[2019-11-08 22:00:44] |
ochocinco - Posts: 29 |
If you move the Volume At Price Threshold Alert to be below your Numbers Bar study, the coloring from the 'Volume at price threshold alert' will be on top. At least thats what i'm able to demonstrate Date Time Of Last Edit: 2019-11-08 22:09:38
[2019-11-08 22:12:30] |
calculation and visibility Chart Studies: Studies To Graph |
[2019-11-09 19:06:45] |
thank you!
