Date/Time: Tue, 29 Sep 2026 23:46:18 +0000
How to export Price Data and Studies in Excel
View Count: 7183
[2019-11-01 15:52:46]
babatunde yusuf - Posts: 2
I want to export price data and volume at price studies into excel spreadsheet for further analysis but do not know how to export data in excel. Any assistance will be appreciated.
[2019-11-02 12:42:10]
Refer to the following for exporting Price data:
Edit Menu: Procedure to Export Bar Data for Use in Spreadsheet Programs
Without using ACSIL and creating a custom study, the only way to get Volume by Price data is to use the Spreadsheet Study and turn on the option for Output Volume at Price Data. Refer to the following:
Spreadsheet Study Inputs: Output Volume at Price Data
You can then export the Spreadsheet data. Refer to the following:
Spreadsheet Studies Special Tasks: Exporting Sheet Data Containing Price and Study Data to Text File
[2023-05-28 21:24:21]
User906368 - Posts: 8
Just as a follow up question here, how can I download daily open and close data for futures?
[2023-05-29 08:36:20]
Sierra_Chart Engineering - Posts: 25005
This happens automatically when you open a Historical Daily Chart:
Getting Started, Opening Charts and Basic Trading: Open A Chart
There is nothing special to do.
[2023-05-30 02:36:41]
j4ytr4der_ - Posts: 947
Consider also that depending on what you are trying to do, you may not need Excel or any external spreadsheet program at all. I've done numerous types of analysis directly in SC using the Spreadsheet System for Trading study, which then allows me to have the whole thing running on live data, or on any historical period I want to see, without messing with any export/import at all. It's quite nice.
