Date/Time: Mon, 29 Apr 2024 10:29:28 +0000
[User Discussion] - sizing windows to screen
View Count: 1146
[2013-12-19 16:16:40] |
artfuls - Posts: 11 |
I have set up my workspaces on a lardge monitor and when i move it to my smaller monitor I cant get it to fit in the window only shows some of the window and dose not give me any scroll bars to see the rest or the ability to maximise the space to shrink the charts so they fir .....anyone no the answer thanks art |
[2013-12-19 17:12:04] |
vegasfoster - Posts: 444 |
I use a laptop with the same issue, as far as I know it doesn't adjust itself. This is what I do. Take your chartbook and save it as chartbook-small or equivalent. Then shrink the windows really small and move them to the top left corner so they will all fit on the smalls screen once you switch over and then save chartbook again. Then switch to smaller screen and adjust the windows to fit the smaller screen and save chartbook again. Then just switch back and forth between the two chartbooks when you switch screens. I only use one chartbook, but this may be a little tedious if you use many chartbooks though, so maybe someone else has a better solution.
[2013-12-19 18:03:49] |
thanks for that
