Date/Time: Sat, 18 May 2024 15:56:54 +0000
Sierra Fix connection
View Count: 963
[2019-10-31 15:49:01] |
User521555 - Posts: 24 |
Hi, My broker is going to give me a Fix connection, how do I configure SC in order to receive datafeed and send orders ? Thank you |
[2019-10-31 15:56:53] |
What is the name of the system or service that this FIX connection would connect to?
[2019-10-31 16:12:13] |
I do not know the name of the service, I am in Brazil, if they have a service, probably it is unknow.... the broker told me that they are giving me the Fix connection access for trade and market data. |
[2019-10-31 18:06:28] |
Almost certainly this is not going to be compatible with Sierra Chart. FIX is not standardized enough for compatibility in this way.
[2019-10-31 18:14:55] |
I see, what about if I use ctrader platform? https://help.ctrader.com/fix Is it possible ? thank you so much |
[2019-11-01 05:44:52] |
There is not compatibility at this time with that system.
[2021-03-10 14:10:57] |
Hi, I would like to connect Sierra with Trading Technologies to draw charts and sending orders.... I would like to trade at B3 exchange, is it possible ? thank you |
[2021-03-10 16:28:44] |
This is supported through the Sierra Chart Order Routing Service : Sierra Chart / Trading Technologies Futures Order Routing Service The problem is you need to use our data feed for the B3 data. We do not have a good data feed for that. Check with the supported IQ Feed service to see if they have B3 data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-10 16:29:01
