Date/Time: Sun, 19 May 2024 01:39:18 +0000
Pivot Range - Variable Period (Mondays range from Friday data)
View Count: 685
[2019-10-27 21:55:42] |
osaga - Posts: 53 |
Hello I am using the study "Pivot Range - Variable Period". I am using these Input Values for these Input Names. Time Period Type -> Days Time Period Length -> 1 This gives me the Pivot Range for the previous day which I see for Tuesday through Friday. Only thing is it does not show Mondays Pivot Range. I'm assuming because of Sunday. Is there a way to use Fridays HLC values to calculate Mondays range? Thanks in advance for the help. Oshine |
[2019-10-29 06:53:07] |
No, this is not supported. Make sure the chart is set to load weekend data: Chart Session Times: Load Weekend Data Setting (Chart >> Chart Settings >> Session Times) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-29 10:46:27] |
osaga - Posts: 53 |
Please let me know if this will be added in the future. Regards! |
