Date/Time: Sat, 18 May 2024 09:53:47 +0000
Possible to filter Unfinished Auctions based on volume?
View Count: 1651
[2019-10-24 17:24:48] |
j4ytr4der_ - Posts: 918 |
I'm exploring the use of the "Highlight nonzero bid&ask" feature on NumbersBars to display unfinished auctions, but unfortunately, they highlight absolutely every occurrence on every bar, and therefor generates so many as to be not very useful. Is there any way to filter this to only show UAs where the total volume is above a certain number of contracts? For instance if I could set it to 10, it would filter out a LOT of the noise and leave behind the more meaningful points. If this is not possible could it be added? Thanks! |
[2019-10-24 19:48:03] |
We will look into this possibility.
[2019-11-11 18:48:25] |
We have added a new Input to the Numbers Bars that will let you set a Minimum Threshold level that both the Bid and Ask must be greater than in order to highlight the Nonzero Bid and Ask at the High and Low of a bar. The Input is named Highlight Nonzero Bid&Ask at High/Low Threshold. You will find the documentation for this Input here: Numbers Bars: Highlight Nonzero Bid&Ask at High/Low Threshold This will be in the next Pre-Release (v 2010). When available, you can update using these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
