Date/Time: Sun, 19 May 2024 06:11:47 +0000
Stacking and Pulling
View Count: 695
[2019-10-22 18:21:14] |
User135370 - Posts: 160 |
Hi I have 191 Resting orders at the ask with over a 1292 pulling, doesn't make sense right? Is there a problem with my datafeed I use CQG and trade the ES |
Pulling.JPG / V - Attached On 2019-10-22 18:20:03 UTC - Size: 70.48 KB - 253 views |
[2019-10-22 18:35:44] |
This is explained in detail here: CQG Trading Platform Service: CQG Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-22 18:38:54
[2019-10-22 18:48:11] |
FoxKestrel - Posts: 9 |
Thank you is the Sierra Chart Data Feed restricted to showing depth as CQG only shows 10. I was about to change it for Rithmic but if Sierra has a decent depth of levels the. It’s worth a try for sure
[2019-10-22 18:58:56] |
The Sierra Chart Denali exchange data feed provides 500 levels of market depth.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-22 18:59:06
[2019-10-22 20:18:07] |
Just checked with AMP and they also recommended Denali issue is they haven’t told me how I can get it
[2019-10-22 20:39:37] |
Is Denali the SC TT on AMP?
[2019-10-22 22:54:50] |
You can ask AMP to bill your AMP account for the Denali Exchange Data Feed. Or you can pay for it yourself. If you want to pay for it yourself just follow through the step-by-step instructions on this page: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
