Date/Time: Sun, 05 May 2024 02:47:34 +0000
Please, give me some advice on which data feed to go and instructions on how to migrate.
View Count: 648
[2019-10-18 10:39:38] |
GiovanniD - Posts: 41 |
Hi, I'm one of those tired of with CQG. I am an AMP customer and want to understand exactly what data manager does for me and how to migrate. I work in scalping, fast operations, I make massive use of the volume analysis and the book (which must therefore be precise). The latency must be very low to avoid slippage as much as possible. I read that you have a solution with 2 servers: 1 for market data and 1 for operations management, with low latency. This belief can be a valid solution for me, but I don't know how accurate are the market data, even in terms of volume and book. For a short time I want to trade the CME (to do some tests) but then I want to be able to trade also the DAX. What do you recommend and how to migrate? My broker is AMP. Thank's Piero |
[2019-10-18 16:30:35] |
We do have this order routing solution: Sierra Chart / Trading Technologies Futures Order Routing Service Have a look and let us know if you have any questions. For migration you just follow the instructions on that page and once you complete that form for the trading account assignment, we will contact AMP. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-18 17:01:01] |
ok, do you know if it is possible to do a test in real with that data, even just one day on the CME, to verify that everything is working properly for me? Thank’s |
[2019-10-19 06:28:07] |
Solved, now I’m testing the Denali data feed, soon I will send my first impressions, which already seems absolutely positive to me. Thank’s |
[2019-10-20 08:48:22] |
Good.
