Date/Time: Fri, 03 May 2024 00:31:02 +0000
help with chartbook
View Count: 1107
[2019-10-16 01:46:28] |
User183272 - Posts: 13 |
I created a chartbook using numbers bar, volume profile and tpo using the equity tsla If I wanted to track these on a new symbol is there a way to use my chartbook and simply apply the symbol to the template I've created? I will leave my chartbook attached below. For example....If I wanted to plug AAPL in this chartbook while keeping the studies the same....what would I do? Date Time Of Last Edit: 2019-10-17 10:55:41
[2019-10-17 08:32:46] |
Just change the symbol for the chart under Chart >> Chart Settings. Refer to the following documentation: Chart Settings: Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Also, be aware of the Watchlist, which allows you to easily switch between symbols within a single chart: Setting up a Group of Symbols for Easy Viewing as Charts or Quote Lines (Watch List) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
